Question about Polaroid a300 Digital Camera
My poliroid camera keeps freezing when the lenze camoes out so i put my hand there to stop it from freezing and mybe it would work but after trying that several times the lenze is not coming out should i just get a new camera
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful. Please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 09, 2010
Lenz are still
You should take it to the photo shop to ask for repair service, I guess it works! Impact from shock(fall) can misplace the components in the camera and it can't resolve by only turning on and off the camera.
Apr 24, 2013 | Fuji Film FinePix JX500 14 Megapixel...
My camera samsung lenz keep saing CARD LOCKED when I turn it on
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Apr 16, 2010 | Samsung L100 Digital Camera
Lens is stuck and camera will not turn on.
there is a problum in your lenze block (optical assy) this problum is not remove at home so please go to your nearst sony service centre & repair the lenze block because no the child parts are avalable
Feb 12, 2010 | Sony Cyber-shot DSC-S730 Digital Camera
Shooter does not open we could not see anything
The camera lens could be dirty or some dust have prevent the lenz to zoom out. try to clean any dirt on the camera and try to remove the battery for a while, put back the battery and tap the lower back of the camera while pressing the ON button.
Hope this helps
Sep 16, 2009 | Canon PowerShot S2 IS Digital Camera
How do I clean the interior of the lenz for Powershot A640
Its a big job, If your petty handy, You have to start from the back of the camera, Remove rear cover,Then front cover, Next lcd Display unit, Hopefully your haven\'t put the battery\'s in the camera for a while because the flash has high voltage in it, if you have, You must discharge first, them take circuit board out,Then lens assy, Now the fun part, You have to take the lens apart from the back also, Like I said its a big job, Better when you get this far into the camera you just replace the lens, with a used one form a diff camera (same model )
Feb 25, 2009 | Canon PowerShot A640 Digital Camera
Samsung S760 Digital Camera - Not turning on and lenz stuck out.
Yes you are correct lens is struck
* Carefully inspect around it for dirt or debris
* If you see any dirt or debris around the lens, use canned air to gently blow it away
* After removing dirt and debris, turn the camera on and off
This should work
Hope this helps .
If your problem still continues you need to take to service center .
Thanks for using FIxya
SAM ANDERSON
Jan 30, 2009 | Samsung S760 Digital Camera
Fuji FinePix E550 Digital Camera stopped working after fresh batteries inserted
due to very low temprature some malfunction may have occured. keep it in normal temprature for few hours and then try switching it ON. even if this not solves take it to some service centre.
Dec 07, 2007 | Fuji FinePix E550 Digital Camera
Polaroid a300 Digital Camera Logo
Top Polaroid Cameras Experts
Greg Cann
Greg Cann
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
