Question about Goulds Pumps Goulds 1/3 Hp 115V 1 Phase Sump Pump 3/8" Solids
Diagram for 1/2 HP motor Gould Century 115/230 Volts
Wire diagram 4 gould gt20
Wiring diagrams for pump motors are usually on the inside of the cover of the wire access cover or on the motor tag. If this is a 1/2 HP motor it could possibly be wired 125V or 250V. Be sure to wire for correct voltage.
Nov 06, 2014 | Goulds Pumps GOULDS GT20...
Need wiring diagram for switching volts on a century magnetek 5hp air compressor
What is the model number? Most of the Century 5 HP motors are 220 Volt single phase. What did you want to change it to?
Aug 15, 2014 | Air Tools & Compressors
I need wiring diagram for Gould Century Pump motor 1081 Part # 8-142776-20 1HP 230v/120v
www.bestbuypoolsupply.com/media/motormanual.pdf
This manual has the wiring diagrams both hi and lo voltage for
part # 8- 142776 -20 gould century 1081m 1 hp , pool pump motor 230/115 volts.... plus several similar motors
May 25, 2012 | Plumbing
Century single phase 2 hp 3450 rpm type cs motor Frame f56
the motor is on 220 volts ,i like hook that up on 120 volts ,,thanks
May 10, 2012 | Air Tools & Compressors
I have a gould century 1 hp motor i need it to run on 115 and it had previously been tried at 230,i had it running for a sec but it isnt right ......i need to know the proper wiring ....also it has 6 posts...
There should be a wiring diagram on the motor name plate. If it isn't there, there isn't much anyone can do, there are literally hundreds of different wiring methods for single phase motors.
Jun 11, 2010 | Air Tools & Compressors
Goulds Pumps Goulds 1/3 Hp 115V 1 Phase Sump Pump 3/8" Solids Logo
501 people viewed this question
Top Goulds Pumps Tools & Hardware - Others Experts
Bill Boyd
micky dee
John Loiselle
Level 1 Expert
Are you a Goulds Pumps Tool and Hardware - Other Expert? Answer questions, earn points and help others
