Question about HP Photosmart D5160 InkJet Printer
Red exclmation mark Err 0,03,31,1F,F4,4D,DD,D6 (thats what is cycling through on the screen) also the green light by the USB port is blinking.
3 Suggested Answers
nalin_elliot
  • 224 Answers
SOURCE: problem of my printer photosmart d5160
Connect the printer dorectly to the wall outlet.try unplugging waiting for 30 seconds and replugging the printer.
Now check if you still face this issue then its a hardware malfunction with your printer no need to worry.
Call up hp at 1800-474-6836 and lets see what else can be done.
Posted on Jun 17, 2009
socialone75
  • 82 Answers
SOURCE: HP Photosmart D5160 gives error message
Issue
The product displays an 0x ... error code when printing (for example Error: 0xf0af8004). These error codes indicate that the product has an internal condition.
Solution
Use the instructions below to resolve the issue by restarting the product.
Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
Open the cover of the product and remove the print cartridges.
Close the cover and wait for the Insert Ink Cartridges message to display.
Disconnect the power cord from the back of the product and wait for one minute.
Reconnect the power cord. If the product does not automatically turn on, press the Power button.
Open the cover and reinsert the print cartridges.
Close the cover.
If prompted, print a calibration page.
Reconnect the USB cable, and try to print a print job from the computer.
If these steps did not resolve the issue, contact HP technical support for assistance.
Posted on Mar 05, 2011
Lacie d2 Quatra 500 BG ext drive Windows XP won't mount. light blinks sounds like it's cycling inside. Any solutions? Need new driver?
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps you
Sep 16, 2011 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Hp mini is not starting only orange light blink when charger is plunged in, after a few second stop blinking plz tell me whats wrong with my pc.
hope this helps
Aug 25, 2011 | Computers & Internet
I cannot get "green lights"
first make sure the power adapter if any is getting power to the usb hub
control panel administrive tools computer management device manager any yellow? ! question marks or red x will tell you that you need to reinstall the driver/s
to do this right click on the ? x ! select reinstall driver
also
control panel admistrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
hope this helps
Jan 04, 2011 | Computers & Internet
Scanner stopped in middle of scan . green light in front went out. later red light came on. message on screen said that the carriage was locked. I tried turning scanner on and off and green light comes on...
test the power supply to the scanner also test the leads that attach from the power supply to the scanner if its connected to a computer you might have to uninstall it then reinstall it this applies the driver aswell you can do this control panel admistrive tools,computer management,device manager scroll down you should see a yellow question mark? right click to reinstall drivers or ports(com&lpt)ECP printer port right click update driver
hope this helps
Oct 27, 2010 | Computers & Internet
This is a 2005 50 inch tv It has been getting darker over the last week or so and now it's black. there is a small circle below the screen which indicates (with a small green or red light)if the tv is...
Kindly tell me :-
1. Make and Model of the TV?
2. Count the Number of Blinks? Unplug the Unit for Few Minutes, say 10 Minutes and then Turn ON. then Count the Number of Blinks?
3. Do you have Tools like Multimeter to repair it?
Let me know, so that we could Proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Mar 27, 2010 | Televison & Video
Projector screen turns off after 10-20 seconds
Is the projector receiving a source signal? if not it will power itself down after whatever time you have it set to do so when no signal is present.
Just an idea?
Jan 03, 2010 | NEC NP-1000 Projector
Pendrive light not blink error massages.
W 7 First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically. for XP or earlier click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X you will need to update/reinstall drivers right click to reinstall drivers if you can see your usb drive but its not working ports (com&lpt) right click update driver if this fails to fix the problem Check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts if you need more help with this or if i have missed the problem post a reply
Apr 06, 2009 | Kensington Electronics - Others
The computer will not recognize it and i cannot listen to music
Green light then blinking red twice means that there is something wrong with the USB cable you are using. You will have to replace it. Any USB cable that fits the shape of your Zen Stone's port will work just fine.
Jan 31, 2009 | Creative Labs Zen Stone Plus MP3 Player
Kodak easyshare m853 digital camera
is the light that's coming on green or red?
if it's red, there's a charging error - contact kodak, they may provide a 5v ac adapter to resolve your charging issue
if it's green, was it blinking or solid? is the battery drained?
if the battery still has a little charge on it, please connect it to the computer then turn it on, check if there's power light
check if the screen is black - that means it's making a connection and the charging is the only issue - computer not detecting it, maybe resolved by kodak's software support
if the camera screen is active - that means there's definitely something wrong with the camera
arrange repairs with kodak, include the battery and usb cable
please visit
www.kodak.com/go/itg - troubleshooting and repair
www.kodak.com/go/usbcharging
Feb 13, 2008 | Kodak EasyShare M853 Digital Camera
No picture or sound - Power Save light blinks red 5 times - nothing on the screen
i also have the same problem with the flashing green light for a while then a different red light starts blinking on and off around 5 times....and i replaced my burnt bulb with a new one...still no picture.
Oct 24, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
HP Photosmart D5160 InkJet Printer Logo
272 people viewed this question
Seeker5211
Seeker5211
