Question about Linksys WRT300N Wireless Router
My wrt300n power light does not come on when trying to reinstall my wireless
  • Linksys Master
  • 6,487 Answers
If the power light on your router wont come on , there are 3 possible reason for that:
The power outlet where the router is connected can be bad so what you can do first is to connect the router on a different power outlet and check if same problem.
The power adapter of your router is bad , so if you can try a different power adapter that will be good.
The router itself is bad after you tried those steps and still wont power on , so if the router is still under warranty better have it replace of call Linksys support via this number 800-3267114.
Posted on Sep 10, 2010
Am using Linksys WRT300N v1.1 wireless router but all LEd are glowing except power led. and i am unable to connect through wired ethernet ports and also wireless is not working.
Try to reset the configuration of your router from the reset button and try that you getting the console with its default username and password.
Jun 18, 2011 | Linksys WRT300N Wireless Router
My Linksys WRT300N router will not show up on my network. Also the power light will not stop blinking no mattter what reset trick , option, whatever I try to do.
When the power light keeps blinking that means your firmware may be corrupt. Follow the directions on this link and it should solve your problem hopefully.
http://www6.nohold.net/Cisco2/GetArticle.aspx?docid=bdb4a0a3a85e49efb91cedc21241e779_3735.xml&pid=80&converted=0
Mar 19, 2011 | Linksys WRT300N Wireless Router
Problem with the Linksys WRT300N Wireless Router No wireless light on router.
No wireless light on your router is a sign that something can be wrong with it, this can be a configuration problem or a hardware/software issue on your router.
The first thing that we can do here to correct the issue is to do a reset on the router and then after that the wireless light back back ON, to reset the router press and hold the reset button of it using a pen or paper clip for 10 seconds while power is ON and then power off and power on the router and check if all the lights are back including the wireless. Then once everything is OK you can now reconfigure the router like running the setup disc.
Jan 31, 2011 | Linksys WRT300N Wireless Router
My linksys WRT300n doesn't work at all and all the light are on and it is only connected to power source, what can i do?or what are the light indicating?
Try to reset the router while it's and release the reset button after 30 seconds . (Use a pen) . Let me know if it's working. Add me in skype , my english_valet or yahoo ronaoclarit so that I can help you.
Nov 08, 2010 | Linksys WRT300N Wireless Router
Lost power on my WRT300N router. Power came back and now the power light is weak and all 4 port lights are on.
I had the exact same indications after a utility power spike.
Quite by accident, I discovered that the power supply to the WRT300N when fully seated into the router causes the lights (and the router!) to malfunction in this manner.
I pulled the power supply connection out gradually and the power light began to flash. Pulling the power supply even farther out eventually caused the power light to shine solid.
I don't know if this is a random manufacturer problem with just my WRT300N (V1.1) or if others may have a similar defect, but it's certainly worth a try!
Good Luck!
May 18, 2010 | Linksys WRT300N Wireless Router
I just rewired all my network connections, my wrt300n wireless indicator is not lit. The network is set up on a linksys broadband router on a cable modem and wrt300n was functioning properly when it was...
Try first resetting the router by pressing the reset button of the router fro 10 seconds while power is ON and then after that reconfigure the router.....
Dec 07, 2009 | Linksys WRT300N Wireless Router
Linksys wrt300N wireless light not blinking
the wireless connections says limited or no connectivity when it does not get IP address from the router.
There might be problem with the wireless settings of the router.
if your network is a secured network then you will need to check the network key.
You can try to upgrade the firmware of the router. that will be a good option.
Click Here for step by step solution
Oct 29, 2009 | Linksys WRT300N Wireless Router
Linksys Wireless WRT300N
Try going to the configuration page and check if it is sending a wireless signal.
Dec 24, 2008 | Linksys WRT300N Wireless Router
Linksys WRT300N Wireless Router Logo
479 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
