Question about Kenmore Kitchen Ranges
I have a self cleaning kenmore stove and I cleaned it today. It cleaned beautifully, but when it finished cleaning the clock did not come on; a code DR came on. I looked in my manual and could not find what that code means. Please help. Thank you
My mother cleaned her oven this weekend and she got the same message on her display. I could not answer what 'dr' stands for, but I was able to clear the message simply by unplugging and replugging the range.
Still if anyone know what it means, it would be a big help.
Posted on Sep 27, 2010
  • bettsnj Sep 27, 2010
    I solved my problem. After self cleaning my oven, a DR displayed.
    Press the switch, mine was on the left side to the door. As you are pressing the switch, at the same time press clear. Then close door and put self cleaning on again for about 2 minutes.
    DR will go off and clock will come on again.
What buttons do I turn on my 25 yr old Kenmore stove to use the cleaning feature
I think that range had a mechanical clock. On it, you have to set the start and stop time (and push or pull the knob(s) to activate it), close the lock lever, and set the temperature and function dial(s) to self-clean. Unfortunately, if your clock isn't working (which is a common failure on stoves this old), you won't be able to run the self-clean cycle.
Sep 14, 2014 | Kenmore Kitchen Ranges
Older kenmore electric stove
You could try to restart and stop clean cycle. Otherwise unplug stove and remove back panel to access locking mechanism.
Jun 24, 2014 | Kenmore White Electric Stove
I Have a C970-648229 and after self cleaning mode stove top stays locked out.
Have a similar problem. The range went on locked mode w/o it being used. Disconnected the cable & it unlocked but the touch panel would not work. The clock & the stove top continuos to work though. Appreciate any help. Thank you.
Sep 09, 2012 | Kenmore Kitchen Ranges
Kenmore self cleaning stove: cannot open door after cleaning cycl
F9 is your oven sensor im sure.Also try to unplug your range and plug back in.Some times that works.Hope i helped:)
Mar 13, 2010 | Kitchen Ranges
I have a Kenmore Gas self cleaning stove. I have
Try power cycling the range by turning it off at the breaker. Wait 10 seconds and then reset the breaker. Reset the clock. Sounds like the computer in the range needs to be rebooted. Hope this works.
Jan 11, 2010 | Kenmore Kitchen Ranges
Kenmore oven won't get hot
hi,,
check the following
  • The clock settings are incorrect (if you have timed baking or a self-cleaning oven).
  • The thermostat is defective.
  • The safety valve that prevents accidental gas flow is defective.
  • The selector switch is defective.
thank u
rate me
Jul 22, 2009 | Kenmore Kitchen Ranges
Kenmore Select Clean Self-Cleaning Electric Range Model 6659580
This means you hace a problem with your clock. Take the back off the stove and then pull the ribbon connector off the clock and clean the terminals. If that doesnt fix it replacing the clock should fix it.
Nov 16, 2008 | Kenmore 91112 / 91114 / 91117 Electric...
Cannot get oven unlocked after self cleaning
turn the circuit breaker off for several seconds
this should reset the system
Apr 02, 2007 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Kitchen Ranges Logo
302 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
