Question about Frigidaire FRT17G4B Top Freezer Refrigerator
Over the past few weeks their has been water accumulating on the top left side shelve.this must be cleaned daily. TKS ED
  • Frigidaire Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
Water Running in efrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Posted on Sep 11, 2010
Why is condensation in fridge?
Good afternoon friend, thank you for your post!
I understand that your Frigidaire refrigerator has moisture forming underneath the bottom panel of your freezer and that is causing water to drip onto your shelves. Would you be able to provide me with your model number that way I could research additional information for you please? You can locate your serial tag (which lists your model number) on the inside cabinet of the fresh food compartment normally on the left side of a top mount. On a side by side it can be found on the right hand side. I look forward to your response. -Matt
Jul 16, 2014 | Frigidaire Refrigerators
Tip
Bicycle Maintenance Tip.
Cleaning Your Bike
A clean bike will last longer than one that is dirty. The frequency of the washing will depend on the amount of use it is getting. If it's used daily, then once a week would be a minimum goal to set for your cleaning regimen. Bikes accumulate dirt, moisture, and other grime that when left on your bike can cause corrosion or rusting that often damages bike components.
You can clean your bike simply by using a bucket of water with dish detergent and a cloth. Clean the bike and then towel dry it to remove any excess moisture. If you discover dirt or grime in areas that are more difficult to reach, use a toothbrush.thanks aaaa
on Dec 21, 2010 | Cycling
Ice at bottom of side by side refrigerator
You are looking for the water source, two possible places to look. Look around the water filter and the glass shelves for water, also check the water tank behind the crispers, as I have seen them crack in the past. Good luck, hit me up if you need more information.
Dec 25, 2013 | GE (PSS26MSRSS) Side by Side Refrigerator
Water condensating in refrigerator side
Check for any air leaks within the unit's door and seal area. See if you notice any blockages in the damper door or switch that is between the two doors. Then contact a professional.
Dec 27, 2012 | Electrolux 25.9 Cu. Ft. Side-by-Side...
How to clean sunbeam humidifier swm5250
CLEANING AND MAINTENANCE INSTRUCTIONS (from the manual):
The following maintenance procedures must be routinely followed in order to ensure proper, efficient operation of your humidifier. The unit WILL NOT WORK CORRECTLY if it is not cleaned properly.
When the unit is in use, daily and weekly maintenance is recommended. Regular weekly cleaning prevents scale buildup on the heating element and base. It also prevents micro-organisms from growing on the base. This ensures that maximum efficiency will be achieved.
We cannot over-emphasize how essential proper cleaning is to the maintenance and continued use of your unit and to the the avoidance of algae or bacteria build-up.
DAILY MAINTENANCE
Allow to cool before maintenance.
1. Before cleaning, set the control to OFF (O) position and unplug the unit from the electrical outlet.
2. Remove the water tank then unlock the misting chamber by rotating the safety lock towards the front of the unit. Lift mist chamber from the unit's base.
3. Empty water and minerals from the base and place in the top rack of the dishwasher. This will remove any sediment and dirt that has accumulated in the base.
NOTE: It is imperative that the base is cleaned properly. The base is dishwasher safe (top rack ONLY) for easy cleaning.
4. Wipe the heating element clean with a soft cloth after it has had a chance to cool.
5. Replace misting chamber and engage safety lock. The Electronic Thermal Control Heating element is lined with a coating that is designed to provide the easiest cleaning and prolong the operating efficiency of the humidifier. DO NOT use any metal or hard objects to clean the Heating Element. Never use detergents, gasoline, kerosene, glass cleaner, furniture polish, paint thinner or other household solvents to clean any part of the humidifier.
WEEKLY MAINTENANCE
Remove Scale: Allow to cool before maintenance.
1. Repeat steps 1-5 in the Daily Maintenance section.
2. Clean the tray by partially filling the base with one 8 oz. cup of undiluted white vinegar. Let solution stand 20 minutes, cleaning all interior surfaces with a soft brush. Dampen a cloth with undiluted white vinegar and wipe out entire base to remove scale.
3. Rinse with clean warm water to remove scale and the white vinegar solution before beginning to disinfect the tank.
Disinfect Tank:
1. Fill tank with 1/2 teaspoon of chlorine bleach and 1/2 gallon of water.
2. Let the solution stand for 20 minutes, swishing every few minutes. Wet all surfaces.
3. Empty the tank after 20 minutes, and rinse well with water until the bleach smell is gone. Dry with a clean cloth of paper towel.
4. Refill the water tank with cool water; replace the housing and water tank. Repeal ALL Operating Instructions.
Jan 22, 2012 | Sunbeam Humidifiers
How do I clean / sanitize my sunbeam humidifier swm5250 with bleach?
I'm no expert, but a friend of mine loaned me her humidifier recently and she just put some bleach and water in the tank and cleaned the tank with that. It did leave a smell of bleach in the tank that could be smelled any time it ran, but after a few refillings, it went away, and I figure if it smells there must be a little left, which means it should clean the working parts fairly well too. (while you're running it the first few times) And the medicine tray in the SWM5250 is dishwasher safe, so I would just run that through the dishwasher, but bleach should be fine for that too.
Jan 27, 2011 | Sunbeam Humidifiers
My Maytag side by side refrigerator [mod. #MSD2656KES, Serial #50518503JL] is freezing everything on the frig side on the two top shelves. Coils have been cleaned. Temp set:Freez=3, Frig=2. One week ago...
I have this same refrigerator, also purchased in 2006. Same exact problem. Fridge freezes, starting actually in the water line, you will notice water on door does not work, then top two shelves start to freeze. Lasts for a few days, then prob does not happen again for 6 months almost to the day. I've had this problem for almost 3 years!!! My service tech said to buy another, glitch in this system he can't figure out. Replaced damper x2, control board, and thermostat x2. Not sure what else to do. I hate the thought of more food lost to spoilage!
Aug 09, 2010 | Maytag 25.6 Cu. Ft. Side-by-Side...
Treadmill maintence
Here is a typical guide for maintenance their may be a slight variation from different manufacturers all in all the same.
NOTE: To prevent electrical shock, be certain the treadmill is turned off and unplugged from the electrical outlet before performing any cleaning or routine maintenance. TREADBELT LUBRICATION For average use of your treadmill, factory recommends you lubricate under the treadbelt once per year. For heavy use, which is more than 10 hours per week, factory recommendation is lubricating every six months. . LUBRICATION PROCEDURE: 1. Turn off and unplug treadmill. 2. Cut off the end of the tube of lubricant. 3. Holding the tube in one hand, insert the tube underneath the treadbelt halfway between front and back and halfway between right and left. 4. Squeeze the full contents of the tube onto the deck in a circular pattern in the center 1/3 of the deck. 5. Plug in and turn on treadmill, then walk normally on treadmill at 0.5 mph for five minutes. CLEANING DAILY: Perspiration should be wiped from the control console and treadmill surfaces after your workout. CLEANING WEEKLY: You should wipe down your treadmill once a week with a water dampened, soft cloth. Be careful not to get excessive moisture between the edge of the digital display panel and the console, as this might create an electrical hazard or cause the electronics to fail. IMPORTANT: DO NOT CLEAN OR WIPE THE TOP OF THE DECK UNDER THE CENTER OF THE RUNNING BELT. MONTHLY: Clean dust and dirt that might accumulate under and behind your treadmill once a month. Small rubber particles from the soles of walking shoes will accumulate alongside the belt and also behind the unit
Apr 27, 2010 | Exercise & Fitness
Doesn't clean dishes, spray arms and filter look ok. Melted crayon in there a couple weeks ago?
Hello- This unit has a sump at bottom of tub that can get blocked, causing low or no water flow. Remove racks, water tube, and the accumulator cover to get to it. Clean the strainer and chopper screen. This should solve the problem. Let me know if this info helps- have more if needed. -Thanks- Ed
Mar 11, 2010 | KitchenAid 24 in. KUDI01FL - Multiple...
Kenmore refrigerator 106.72206201 - accumulating ice and water
Probably a clogged drain line in the freezer. Unplug it for 2 days and leave it open. Reset controls to 3 and C or factory settings clean the coils on the bottom outside with a vacuum and a brush and restart the fridge.
Sep 11, 2009 | Kenmore Refrigerators
Frigidaire FRT17G4B Top Freezer Refrigerator Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
