Question about Makita Tools & Hardware - Others
Makita hg650c 240v showing error code - 64h832 on digital display? blows air at a lowerrate and temperature.
3 Suggested Answers
  • 164 Answers
SOURCE: My 1997 Buick Century Limited, the digital
as far as i know-no bulb for digital readout on that one. sounds like control head is bad... check fuses etc. also looking at a diagram loooks like display power runs through the headlight switch? seems odd but a place to look. most likely head though try used or in dewitt ny there is a place called united radio that fixes-rebuilds these look em up i use them from time to time
Posted on Aug 24, 2009
  • 44634 Answers
SOURCE: 60000 BTU mitsubishi air.con is showing P8 error code and is blowing only hot air even temperature is set at 16 degrees. What might be the cause and how to rectify it.
go google and type in--Mitsubishi air conditioner fault code p 8-- and there are pages including a mitsubishi site that is a pdf version down load describing the fault
Posted on Dec 10, 2015
My air conditioner showing on the display is E1
The E1 Error Code The most common reason for an E1 error code to be displayed on your air conditioner's front panel is to remind you that the unit's air filter needs to be cleaned. Many models will automatically notify you of this via an E1 error code display after the unit has been operated for a predetermined number of hours. For example, many Sharp models will display an E1 code after 720 hours of use. Alternatively, you could have dirt or moisture in your front button controls, causing them to stick or not function properly. This can be a common problem with many models of Haier air conditioners, but the issue is not restricted to any one manufacturer. Your air conditioner could also have a defective thermistor, which is part of the thermostat.
For Samsung, the room thermistor needs replacing. This is a device that senses the temperature in the room.
How to Fix an Air Conditioner When It Gives You an E1 Code eHow
Jan 24, 2016 | Heating & Cooling
Dec 10, 2015 | Mitsubishi Heating & Cooling
Carrier Comfort Zone II Thermostat is blank and the 3 companion thermostats are all showing Error Code C1. What does that mean?
Hi Anonymous,
For all wall mounted and Artcool split system codes
Error code = C1 or CH1
Flashing Light = 1
Fault = Indoor temperature sensor open or closedcircuit.
Display = Indoor.
Indoor Operation = ON
Error code = C2 or CH2
Flashing Light = 2
Fault = Outdoor temperature sensor open orclosed circuit.
Display = Indoor Outdoor.
Feb 14, 2015 | Carrier Heating & Cooling
How to fix error code 25 for makita HG650C
Error on Makita HG650/651, or Weldy Plus means, that damaged can be: 1 Heating Element, 2 Electronic controller, 3 Switch - or everything.
Aug 02, 2014 | Makita Tools & Hardware - Others
Why is my airco not cooling?
I believe that error code refers to a defective Indoor Coil Temperature Sensor (Thermistor); probably an "open" or "shorted" condition.
Jul 08, 2014 | Heating & Cooling
My air conditioner want turn on or anthing and it shows e1, whats this mean
The E1 code is an error code that appears on the LED temperature display of some digital air conditioners. The error code could mean anything from dirty air filters to a damaged room thermistor, a safety connected to your thermostat that detects room temperature. Troubleshooting the cause of this error code may improve your air conditioner's performance
Sep 15, 2013 | Haier HWR06XC7 Air Conditioner
Kitchen aid wall oven Model YKEBS2780B1 SHOWS
Hello,4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock(ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock(ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3
Thanks
May 26, 2010 | Ovens
No heat coming out fan blows but no heat
there's a blend door actuator behind the dash. they are going bad all the times. however, check your coolant level first.
Feb 28, 2010 | 1996 Lincoln Town Car
AEG 57700 only blowing cold air, heater not working
CHECK VOLTAGE=240VOLTS NOT 120VOLTS,ITS TAKES 240V TO HEAT BUT WILL RUN ON 120V.
THEN START WITH HEATER ELEMENT ..SEE IT ELEMENT IS OPEN.
THEN START RUN ING TEST ON THERMO'S TO SEE IF CLOSED OR OPEN...
THANKS FREDDY
Feb 14, 2010 | AEG T57800 Electric Dryer
Light on clocks indicates eobd light and bike will not start help
To display what is wrong: turn off the ignition, press and hold the "A" button and turn the ignition back on. Than release the "A" button. The main display now shows "EFI", and the smaller display shows the error code.
Inputs
1.1 Throtlle Position Sensor (TPS) short-circuit to battery +
1.2 Throtlle Position Sensor (TPS) short-circuit to ground
2.1 Oil pressure sensor short-circuit to battery +
2.2 Oil pressure sensor short-circuit to ground
3.1 Oil temperature sensor short-circuit to battery +
3.2 Oil temperature sensor short-circuit to ground
4.1 Air temperature sensor short-circuit to battery +
4.2 Air temperature sensor short-circuit to ground
5.1 Battery HI
5.2 Battery LO
7.1 Fuel sensor short-circuit to battery +
7.2 Fuel sensor short-circuit to ground
Outputs 10.1 Horizontal cylinder coil short-circuit to battery +
10.2 Horizontal cylinder coil short-circuit to ground
11.1 Vertical cylinder coil short-circuit to battery +
11.2 Vertical cylinder coil short-circuit to ground
12.1 Injector 1 short-circuit to battery +
12.2 Injector 1 short-circuit to ground
13.1 Injector 2 short-circuit to battery +
13.2 Injector 2 short-circuit to ground
16.0 Fuel pump relay open circuit
19.1 Starter solenoid short-circuit to battery +
19.2 Starter solenoid short-circuit to ground
21.1 Stepper motor short-circuit to battery +
21.2 Stepper motor short-circuit to ground
21.3 Stepper motor open circuit
Functions 30.0 Generic ECU error
34.0 Signal panel (sensor discovery)
36.0 Speed (sensor discovery)
37.0 Immobilizer (key / transponder not found)
37.1 Immobilizer (antenna discovery)
37.2 Immobilizer (instrument panel serial driver)
37.3 Immobilizer (serial cable disconnected)
37.5 Immobilizer (key not acknowledged)
37.6 Immobilizer (immo virgin - ECU progr.)
38.0 Can line
Jul 18, 2009 | 2006 Ducati Multistrada 620
Tools & Hardware - Others Logo
458 people viewed this question
Top Makita Tools & Hardware - Others Experts
Jim Thurston
John Porter
Are you a Makita Tool and Hardware - Other Expert? Answer questions, earn points and help others
