Question about Emerson InSinkErator W154 NA Mini-Tank Point-Of-Use W154
Where do I buy a heating element for a ISE W154 water heater
  • 20 Answers
Try Ferguson Enterprises if there is one on your area.
Posted on Sep 16, 2010
Part number for standard heating element for eco smart 11.3kw?
Go to ecosmartus.com
Click products tab at top of page
Click on your model number
Click on replacement parts tab
Buy part from ecosmart
Or remove element from water heater and look to see if threads are standard water heater element threads... then look at volts and watts printed on end of each element... buy ordinary element if it will work.
http://waterheatertimer.org/How-to-replace-water-heater-element.html
Gene
Mar 18, 2015 | Element Water Heaters
Will well water cause a problem on the heat pump water heater
I would say yes.
Because element may not be easy to replace, or easy to reset unit after replacement
I would also suggest not buying heat pump... must be in at least 10'x10' room with 7" space around entire heater
http://waterheatertimer.org/Review-GE-Heat-Pump-water-heater.html
Gene
Oct 15, 2014 | GEH50DEEDSC GeoSpring Hybrid Water...
What is the part # for a Rheem 308 71 model heating element needed?
Any generic element will work.
Match wattage with current element.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#parts
Rheem wants folks to buy parts from them... so Rheem tries to convince people that Rheem electric water heaters require special parts.
This is not true... ordinary generic parts will function fine on Rheem.
Gene
Oct 14, 2014 | Water Heaters
I need part # for heating element 81V80D
Buy generic element from hardware store:
Copy following link to identify element and see installation tips.
80 gallon, non-simultaneous electric heaters usually have 4500 watt elements
Avoid promotion of 'lifetime' or 'resistorized' or 'all copper' elements as a waste of your money, ... but might be beneficial by adding surge to the economy.
Apr 02, 2013 | Rheem 81VP6S/430126 Water Heater
Have a reliance electric water heater model 606; have no hot water. I am having a problem finding the reset switch.
If it was working and recently stopped working, the heating element that heats the water probably went bad, no longer functioning. Check to make sure that there is or is not a reset button, and if there is, press and reset the heater. It's not difficult to remove the old heater element and replace it, but make sure the circuit breaker power to the water heater is off when you remove it. Take it to a water heating supply store, or large hardware store with the Brand and model number of your water heater (Reliance RELIANCE ELECTRIC WATER HEATER,model 606 ) to buy another one.
Sep 21, 2012 | RELIANCE ELECTRIC WATER HEATER
Reliance 501 Hot Water Heating element for 30 gal tank, where to purchase
You do not need special parts.
Wattage is printed on end of each element.
Buy generic elements at hardware store.
Apr 21, 2012 | RELIANCE ELECTRIC WATER HEATER
I have a rheem glas standard 30 gallon model # 81sv-30d water heater with upper and lower watages 3500. how do i know what size heating element i need?
Look on label on side of tank.
Wattage of tank will be element wattage. This is true if tank has one or two elements since both elements are never ON at same time.
Simply go to hardware store and buy 3500W element.
Take phone photo to store if needed for identification.
Wattage appears on end of each element.
http://waterheatertimer.org/How-to-test-water-heater-element.html
http://waterheatertimer.org/images/Voltage-printed-on-element-.jpg
Feb 12, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
After connecting a drain line to the pressure relief valve of my MR85245 water heater, I now have water leaking badly out of the heating element door.
Turn off the electricity.
Turn off the water valve going into tank.
Open a bathtub spout to let hot water pressure off the tank.
Check top of tank for any leaks.
Open the top access panel and see if element is leaking.
Open bottom access panel and see if lower element is leaking.
The reduced pressure on the tank will slow the leak.
If element is the problem, you can squeak by for a while by turning on the hot water heater only when you need hot water.
Order the 'Marathon MR85245 replacement element' online
http://www.gpconservation.com/rheem/marathon-sp213670-titanium-4500w-lower-element
These elements may be available locally, but they are not the same as 'ordinary' tank-type electric heater elements that you buy at the hardware store.
Buy more than 1 element because the Marathon elements have problems.
One of the reported problems with marathon elements is the high price of stainless steel replacement elements.
Drain tank.
Replace element.
Another resource for water heater information is:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Nov 04, 2010 | Water Heater Innovations MR85245 High...
We just bought a new water heater and it's not heating up water.
The heating element was bad. It's hard to believe that a brand new water heater would have a burn element, but that's the problem. I replace the heating element and its started working properly.
Dec 01, 2009 | Whirlpool Water Heaters
How to replace heating element for InSinkErator W154 water heater
take the front cover off, it is just snaped on, there you will see it, depending on the age of the unit insinkerator will replace it for free, you just have to install it, but for the most part it might be cheaper to change the unit
May 12, 2009 | Emerson InSinkErator W154 Water Heater
Emerson InSinkErator W154 NA Mini-Tank Point-Of-Use W154 Logo
314 people viewed this question
Top Emerson Water Heaters Experts
Donni Steen
Gil Shultz
ray gallant
Are you an Emerson Water Heater Expert? Answer questions, earn points and help others
