Question about ElectroVoice . Speaker
I have an old electrovoice PA30AT horn speaker, I need to know what its specs are, our group can't afford to replace it, but we need specs to be able to use it.
Is the Maxi-Cosi Pebble (UK Spec) comparable with the 2007 Honda Element (US Spec)?
I don't really know about the Honda element but I do know the maxi cosi is one of the most popular, reliable, trusted, affordable and safest car seats on the market.
Mar 03, 2015 | Maxi-Cosi Familyfix Pebble Group 0 Carseat...
No sound thru horn.
Either components in the SoundGard circuit are blown or the horn driver... VERY SLIGHT chance wires have become disconnected. Open unit an inspect. Use ohmmeter to check the polyfuse and the lamp for open circuit indicating they are blown. Your amplifier should be rated at NO MORE than 150 Watts RMS continuous for safety of the horn. Speaker ratings are based on advertising... so don't believe the specs on power handling... If you dig into the specs you will find for the horn a max of 150 Watts continuous.
Aug 08, 2011 | Peavey New Peavey Sp3 15" 3 Way PA Speaker
I think I need to replace the tweeter in my EVID 3.2. How the heck do I remove the grill without damaging the unit?
The grill is glued on and will pop off with a little effort. Use a small pick tool (small pointy tool with a sharp hook) and carefully pry the screen away from the speaker. Try lightly prying in several spots so you don't warp or bend the screen. Let my know if you find replacement parts
Feb 14, 2011 | ElectroVoice EVID 3.2 Main / Stereo...
Where can i buy a horn for a ev sx 300? how much?
You don't "buy a horn" as the horn itself is molded into the case and if the case is smashed that is fatal.
If it is the sctive element for the tweeter/mid you are after, the correct terminology is "compression driver". That should aid your search.
It is best to go directely to EV to get an exact replacement for this. Or try to find one at this site:
http://www.loudspeakersplus.com/parent_category/HFCD/High-Frequency-Compression-Drivers/1.html
They vary from about $30 to $500.
Sep 06, 2010 | ElectroVoice Sx300e
I have an old set of EV 1502 PA Speakers. One of my Cabs the 15" driver stopped working... I can plug the Horn and the 15" Driver in Separately and they both work which I think means I have a problem with...
The crossover network is a combination of a LCR circuit. since all these arre passive components you will not have a problem to find the actual fault. Since you have confirmed with the drivers, the line in to the network from the speaker wires must be traced for continutiy, use a good multimeter. now check carefully on the PCB-printed circuit board.- for any track damage on it, if so loop and connect. The main driver is usually in parallel to the main line but with a croos over of a cpacitor and a series inductor. This will be the culprit, either it has come off from the PCB or open out by burning off. replace or reconnect. I am sure it can be sorted out easily by your carefully analysis. Hope this helps. Good day
Jul 19, 2010 | ElectroVoice . Speaker
I have an ElectroVoice 15" Low Driver paper cone is torn can it be fixed or replaced? I am in South Africa Cape Town
Start looking for a replacement, you won't get it fixed. Try the makers website, they should put you in touch with someone or supply the part.
Jun 21, 2010 | ElectroVoice . Speaker
I am looking for original part numbers for EV Speakers
What is the problem with unit.Contact EV or go online for a manual unless unit is a low volume production or comm model.
Oct 06, 2009 | ElectroVoice Audio Players & Recorders
I have an Electrovoice MA-1212 That when I hook it up and power on all I get is a constant low frequency Hum. Checked the wiring and speakers on another amp and eliminated them? Any suggestions?
WIth the speakers disconnected, measure the terminals using a DC voltmeter. I suspect that there is DC voltage there where there should be 0V. If that is the case, the output transistors are shorted and need to be replaced.
Dan
Jul 31, 2009 | ElectroVoice...
Wiring tweeters.
Yes you need them. I always put them inline on the positive side. They are to protect the speakers against low frequencies. Actually, I use oil bath capacitors sometimes on pro systems. I don't see how they would work between the positive & negative that is unless they have a positive & negative side with an out and an in? Hope this helps,
Jul 06, 2009 | ElectroVoice...
How will i know if the horn has blown on my ev zx 5 speaker?(there is no top end at all) thanks.
first,try switching to a different output(if this is the left speaker,switch it to the right)if it does the same thing,then we need to pull the back off the speaker.to make sure the crossover is not bad your gonna want to unplug the horn & put a signal to it from your source(do this at a low volume with the bass turned down & trble turned up)if you have sound then there is a problem with the crossover(this is the pc board in the enclosure that connects to the speakers)if not your horn is gone.hope this helps,thanx for using fix.please rate all replys
Nov 17, 2008 | ElectroVoice Audio Players & Recorders
ElectroVoice . Speaker Logo
149 people viewed this question
Top ElectroVoice Audio Players & Recorders Experts
Michial Gueffroy
Vito Vacirca Jr.
 Grubhead
Grubhead
Are you an ElectroVoice Audio Player and Recorder Expert? Answer questions, earn points and help others
