Question about Sceptre X9G Komodo IV 19" Flat Panel LCD Monitor
Monitor almost never turns on. When this problem first started I was able to get to turn on by unplugging it and plugging it back in. My monitor is a Sceptre X9G-Komodo II. Any help or guidance would be greatly appreciated.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Sceptre Master
  • 848 Answers
Monitor almost never turns on. When this problem first started I was able to get to turn on by unplugging it and plugging it back in. My monitor is a Sceptre X9G-Komodo II. Any help or guidance would be greatly appreciated? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
http://www.wisiny.com/sceptre-lm004-power-supply-backlight-inverter-for-x9g-komodo
Posted on Mar 22, 2015
  • 11,361 Answers
Look for bad caps like the 17" version here:
http://s807.photobucket.com/albums/yy352/budm/Sceptre%20X7G/
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Posted on Sep 10, 2010
LG Monitor Not Working
that is a problem of capacitor inside the monitor open the monitor a capacitor in the secondary section will look expanded replace it
Apr 17, 2010 | LG 19" Widescreen Flat Panel LCD Monitor
Monitor says no input signal going in sleep mode
TRY UNPLUGGING COMPUTER AND MONITOR AND DISCONNECTING MONITOR FROM THE BACK OF THE COMPUTER. BE SURE TO UNPLUG AND NOT TURN OFF. WAIT ONE MINUTE THEN PLUG COMPUTER BACK IN . RECONNECT MONITOR TO THE BACK OF THE COMPUTER AND PLUG IN. IF THIS WORKS, WAIT FOR NEW HARDWARE RECOGNIZED TO COME ON. FOLLOW INSTRUCTIONS, IF ANY. RESTART COMPUTER.
Feb 08, 2010 | HP vs15 15"LCD Flat Panel Monitor
E-machine was working fine last night got up and it turns on but the monitor says check cable or power but all is ok.Computer wont display anything, can anyone help?
Do a reset: Turn the computer and monitor off. Unplug the monitor video cable from the computer and unplug the monitor power cord from the wall outlet. Let it sit for 5 or 10 minutes. Plug everything back in, turn on the monitor, then start the computer. Sometimes that will work.
If you still have the same problem, try to borrow a known to be good monitor from somebody. If it works, then you know your monitor is bad.
It's also possible that your video circuitry is bad. If the monitor plugs straight into the motherboard (onboard video), then you'll need to purchase a video card and install it. Disable the onboard video first.
Feb 25, 2009 | E-Machines (T2958) PC Desktop
Montior will not come on
internal board on the lcd has blown capacitors you will need to replace those on the power board to bring the monitor back up.
Nov 22, 2008 | Star Logic 17" LCD Monitor
No sound from monitor speakers. Worked fine for 5 years. Can hear sounds when using headphones plugged into CPU. Hope you can help even if only to tell me I need a new monitor. Sincerely Dizzyme.
Hi...there,
First of all, check if your audio cable are still plugged into the monitor and pc output (light green) audio jack. If not just plugged it back in... Still still got no sound... Then turned off the monitor and pc. Unplugged all the cables from the monitor and pc, wait for 10 second till all the surged built up are cleared out. Then you can plugged all the cables back Monitor should have 3 cables, a audio cable, a VGA or DVI cables, and a power cord... OK! now you got all the cables plugged back in...
Turned on the monitor and PC....and a few seconds....you should hear window started. Still... had a problems....just get a external speakers. Have nice day!
Oct 08, 2008 | Hansol H550 15" LCD Monitor
Strange delay.
I'm having the exact same strange delay problem as you.
I fixed my delay when I too took my machine to your girlfriends. LOL!
No seriously.... you solved your delay problem yourself when you UNPLUGGED the power cord from the back of the monitor.
My guess is that when you unplug the power cord, the monitor resets itself. It's only a temporary fix, but, IT WORKS.
1. Turn the monitor OFF
2. Unplug the power cord from the back of the monitor
3. Wait 10-15 seconds or so
4. Plug the power cord back in
5. Turn your monitor ON........DELAY ELIMINATED.
The delay returns eventually, but, I just unplug-n-replug and I'm good to go again.
Apr 07, 2008 | Gateway FPD2275W LCD Monitor
Mag innovision LT716s monitor
When I turn on my computer the monitor takes a long time to warm up and colors change and vertical lines flash across the screen from right to left before the screen becomes normal again. Now the power light even goes out upon turning on my computer and I have to unplug the video cord and plug it back in to start the screen back up which even takes longer.
Feb 19, 2008 | Mag Innovision LT782S 17" Flat Panel LCD...
DCLCD 19" flatscreen won't turn on correctly
Same problem here, but after using the plugging/unplugging method it eventually stopped all together. So, I took it to a local monitor repair shop (AM Stereo, Seattle). The problem is a power supply issue where the capasitors go bad. They fixed the monitor by replacing the capacitors for $70. In there experience, all monitors, regardless of brand, tend to use the same cheap capacitors which fail. He replaced them with better quality capacitors which may make this monitor better than it ever was. I'm back in business with a great monitor!
Oct 31, 2007 | Sceptre DCL 7A 17" Flat Panel LCD Monitor
Monitor
-Turn off both computer and monitor
-unplug monitor from computer(still plugged into power supply)
-turn on computer and monitor(monitor is still unplugged)
-After computer is on for about 30 sec. plug monitor into computer
-turn off both monitor and computer(now connected together)
-turn on monitor then computer and should be good to go!!!
Mar 25, 2007 | Sony CPD E230 17" CRT Monitor
Sceptre X9G Komodo IV 19" Flat Panel LCD Monitor Logo
223 people viewed this question
Top Sceptre Computers & Internet Experts
Cleverer2
Ricky Ostrom
Ricky Ostrom
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
