Question about Toshiba estudio 255 Copier
I have a toshiba e-255 that jam's right as soon as the paper starts too come out of the fuser and has the error code of e062. can any one tell me what is wrong.
SOURCE: Paper Jam
hi im jules_09.have you reassemble the fuser correctly?check again the inside of the machine for small pieces of paper its just there the machine wont flash the misfed if there is nothing stock in the machine.although sometimes the drum can cause the misfed,try to full out the drum.it cant be stock just see if the drum is rotating try to rotate it 360 then slowly full it out,also check if there are srews where the drum process unit is at
Posted on Oct 14, 2007
SOURCE: e studio 16
More than likely you have bad feed tires in the tray you're pulling from or if the drum unit is stuck there probably is paper jammed up in the unit.  Replace you feed tires and check your drum separation claws when you are able to get the drum unit out.
Posted on Oct 20, 2007
  • 168 Answers
SOURCE: Paper Jam
1st, you need to find out exactly where the paper is getting stuck.
Is the paper stopping just as it gets to the rollers, or
stops when it goes through the rollers and are getting stuck on the little fuser claws?
If the paper is stopping right when it gets to the rollers, then there is a problem with the fuser drive or drive gears.
This you would probably need to place a service call to have repaired.
If the paper is getting stuck in the claws, then make sure that the claws are not stuck down. All claws should be up against the rollers, both upper and lower claws.
Sometimes they get stuck down or the spring gets knocked off.
Other than that, as long as both upper and lower fuser rollers are in good condition, paper should pass through.
If you have any other questions, feel free to repost.
Good luck.
If I have helped answer your question, please remember to post a rating.
Mac =)
Posted on Mar 19, 2008
SOURCE: Toshiba 2060 Paper Jam at the fuser
I think i found the issue. There is this plasic actuator piece that has two parts to it and its melted. I think that is the piece that detects the paper leaveing the fuser. Here is a picture of the part that is melted. http://www.precisionroller.com/actuators-for-toshiba-2060/details_8856.html
Does any one have a repair manual that they can send me on the correct way of installing this part?
Posted on Jun 19, 2008
  • 117 Answers
SOURCE: toshiba 2060 jams (accordion/fans the
sounds like a broken fuser drive gear.The fuser operates a nearly 400 degrees Fahrenheit and the drive gear cracks and falls off.Lots of trouble for a 50 cent gear.They are mad of fiber or plastic.take a few of the covers off near the fuser and disconnect the cables and the fuser slides out
Posted on Mar 24, 2009
Toshiba e 355 is check the paper size setting on contralpanel for draw at 2 error code E062 what problem this
Make sure the actual paper size and the paper size settings on drawer 2 is same...otherwise this issue will happen following with paper jam...
Oct 13, 2015 | Toshiba Office Equipment & Supplies
Toshiba e 255 is error code E 030
E030 indicates jam on exit...It is intermittent jam or totally jam?
U need to check the paper transport from feeder to registration then up to fuser unit, lastly exit unit...
Sep 01, 2015 | Toshiba Office Equipment & Supplies
Error code e030
Code E030 Description Power-ON jam: The paper is remaining on the paper transport path when power is turned ON.
Aug 09, 2015 | Toshiba E-Studio 255 Digital Copier...
Error code C440
Toshiba eStudio 355/455 Full Service Manual - Tradebit.com
https://www.tradebit.com/.../155135538-toshiba-estudio-355-455-full-se...
Download Toshiba eStudio 355/455 Full Service Manual ... Configuring DepartmentCodes Configuring ... TSB-1013: C440 Error - Countermeasure .... DIG-ACC-145: MJ-1025 Bracket Change to Enable Installation on e-STUDIO205L/255/305
Aug 08, 2015 | Toshiba E-Studio 305 Digital Copier
Erro code e02 in toshiba estudio 181
hello
dear you have to verify all the exit sensor related
1. do u have look on fuser unit drive gears.
2. is the exit rollers are good some time exit roller got damaged they don't hold hold paper to run out from machine.
3. do u have clean the exit sensor.
4. do you have verify that the exit sensor actuator is free to operate the sensor.
5. some time exit sensor actuator broken.
Aug 28, 2014 | Office Equipment & Supplies
Error message 093-424
it;s usually an orange feed roller assembly in printer that gets warm and causes toner to cure on paper it is most likely close to being worn as the printer keeps history of how old the fuser is by counting prints or you will start getting paper jams as the feed roller wears down.
Jan 21, 2013 | Laser 3115cn All-In-One Printer
When i switch on my photocopier tohiba 2860, it asks for service and gives an error code 08221-918100. what could be the problem?
Hi tkasirye,
Welcome to Fixya.
You may need to check again the error code. According to the manufacturer's checklist for error codes, only the following are documented;
  1. Error Codes - Toshiba 2860
  1. "E01" Paper jam inside machine. "E02" Paper jam near the fuser. "E03" Paper jammed inside machine when power supply is switched on. "E04" Front cover open while copying. "E05" Paper jam near the aligning roller "E08" Paper jam at stacking area in the ADU "E11" Paper feeding jam at the ADU "E12" Manual feeding jam "E13" Paper jam from cassette 1 "E14" Paper jam from cassette 2 "E15" Paper jam from cassette 3 "E16" Paper jam from cassette 4 "E17" Paper jam from cassette 5 "E19" Paper jam from the LCF "E21" Paper jam in transport route 1 (LCF) "E22" Paper jam in transport route 2 (COPIER) "E23" Paper jam in transport route 3 (ALIGNING) "E25" Paper jam in transport route 4 (PFP) "E71" Original feed jam in ADF "E72" Original transporting jam in ADF "E73" Original exiting jam in ADF "E75" 2nd original feeding jam "E81" Paper jam before sorter "E82" Paper jam in sorter "E83" Sorter early arrival jam "E84" Paper in sorter when power is turned on "E85" Joint open jam while copying "E88" Paper jam outside the sorter bin "C01" Abnormal operation of the copier main motor "C04" Abnormal operation of the PFP main motor "C05" Abnormal operation of the ADU main motor "C11" Abnormal operation of the ADU side motor "C12" Abnormal operation of the ADU end motor "C13" Abnormal operation of the upper cassette tray "C14" Abnormal operation of the lower cassette tray "C15" Abnormal operation of the PFP upper cassette tray "C16" Abnormal operation of the PFP middle cassette tray "C17" Abnormal operation of the PFP lower cassette tray "C18" Abnormal operation of the LCF tray "C21" Optics carriage initialize error "C22" Lens initialize error "C23" Mirror initialize error "C26" Faulty exposure lamp "C33" Easy set-up is failed "C35" Developer material exists at the transfer separation adjustment "C41" Faulty thermistor or heater "C43" Faulty thermistor "C44" Faulty heater "C45" Sub thermistor is open
Shoulg you not find any of these mentioned error codes, I suggest you contact the tech support especially if the machine is still under warranty.
Hope this helps.
Takasashi
Jul 05, 2011 | Toshiba Office Equipment & Supplies
Paper keeps jamming in fuser, inner door and tray, can firmware upgrade fix this, its a c534dn
A paper jam as you describe could be caused by the following:
The fuser is defective and causing the jam.
The tray has a problem and it is not picking up the paper properly which causes a timing problem that results in a jam.
A bad sensor is stopping the printer from being able to tell if the right size paper is being fed through the printer.
Try printing from the manual tray to eliminate a problem with the standard paper tray. If it still jams it is very possible that your fuser has an issue and will require replacement. Are there any errors in the error log?
Mar 14, 2011 | Lexmark C534N Printer
Paper jam
You're not giving me alot to go on for your trouble. Your're not telling me where the paper is stopping at. There are several problems you could be having. If the copier is feeding from the top cassette and jamming or even not feeding at all then the feed rollers could be the blame. This could be the reason for the lower casette jamming. If the paper is stopping in the fuser then there could be damage or no rotation of the fuser rollers. This should give you an E007 error code. Then the fuser must be rebuilt or replaced. Hope this gets you started. Good luck.
Dec 06, 2010 | Canon imageRUNNER 2000 Copier
202.01 and 202.03 Paper Jam
The 202.03 error code has to do with an early life failure of the fuser. Try replacing the fuser. If that doesn't work, a tech is needed to replace rear door. Don't forget to reset maintenance counts when you replace fuser!!
Jul 01, 2009 | Dell 5310n Laser Printer
Toshiba estudio 255 Copier Logo
346 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
