Question about Jandy STEALTH 2 HP POOL PUMP 115230V
Pump is making a medium loud rhythmic noise (grinding?) when it is running. Possible problems and solutions? Thank you.
  • 331 Answers
Sounds like a bad seal and bearing combination. recommend you have service performed on it as soon as possible to prevent damage.
Posted on Sep 10, 2010
Testimonial: "Thank you for your help!"
My Frigidaire Gallery front loading dryer seems to be out of balance. It has become louder and makes a rhythmic grinding noise as it spins. Sometimes it starts with grinding noise that stops after a...
YOUR DRYER DEFINITELY HAS A BEARING RUNOUT PROBLEM (THATS THE GRINDING NOISE YOU HEAR - THE DRUM RUNNING ON THE SIDE OF THE CABINET ) . IT WOULD ALSO GRAB CLOTHES AS YOU SUGGEST . COST TOO MUCH TO FIX = GO AND SHOUT YOURSELF A NEW ONE IF U CAN .
Jul 26, 2011 | Dryers
I have a 2005 ford focus and am having transmission shift problem
No movement in any gear: pump failure, R&R, To check for pump failure, check fluid level with the engine off, then start the engine and recheck fluid level. If level does not go down when engine is running, the pump is broken.
Front pump bushing walked out. R&R. May have to replace converter also if hub is scored. Note that a leaking front seal usually means the bushing is walking out (i.e. call your local trans shop and schedule an appt.).
Loud bang, grinding sound, loss of all gears, and a binding driveshaft: snapped output shaft. Try to wiggle two end driveshaft (inner CV joint) - if more than 0.020" play, that's the sign. R&R.
These are just some of the things that could have happened to your transmission, regardless your going to have to have it sent in to a transmission shop for a repair, and grinding noise indicate a hard part is broken and not electrical issues.
Try not to run the engine or move the car or further damage could result. Good luck and thank you for using Fixya
Mar 09, 2010 | 1998 Ford Escort
Front end is grinding loudly in rhythm with well turns. I had the sway bar link break, replaced it but the loud rhythmic grinding is still there. any guidance?
if the noise is at wheel speed then what ever is causing the noise is rotateing, could be a drive shaft or wheel bearing, jack the car up at the wheel you think is the problem and ceck for ecessive movement to pin point your fault. hope this helps
Mar 03, 2010 | 2000 Ford Explorer
Rhythmic grinding noise front end - 98 chevy astro AWD
Could be low on oil, trans doesnt have fluid, wheel bearings are gone, or could be something stuck under the vehicle and either the tires or the drive axle is rubbing against it.
Feb 09, 2010 | 1998 Chevrolet Astro
Makes a loud noise like a grinding noise then smokes comes out and it smells like burning rubber? When I take the (rod) brush off with the belt then run the vacuum there is no more noise? Please help me...
Your belt is worn and stretched and so it is slipping on the motor drive shaft. That is why it is noisy and smells like burning rubber. You simply need to replace the belt. You can get replacement belts here:
Replacement Vacuum Belts
Nov 30, 2009 | Vacuums
Our shredder is making a loud, grinding noise.
simply try resetting the machine. unplugging it waiting for about 30 seconds then plugging it back in, also is the unit mounted properly on the unit? It might be one of the gears that is not broken...if you have a warranty now would be a good time to call them as they will fix or replace the part for the unit.
Apr 10, 2009 | Medium Universal Office 38082 Shredder
Grinding Noise
sounds like you have a problem with the cooling fan
Dec 31, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
Whirlpool Duet Washer Making Loud Grinding Noise
not nesseccarrily your pump, possible you have a rear bearing going bad, which will sound as if a helicopter is coming through your laundry room. ( noisy pump can be the issue , honestly a better and cheapre problem to have) in order to determine if its apump problem you can remove the lower access panel and unplug the pump then start the spinn cycle, if it still loud the pumpms not hte issue.
Nov 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Starting noise
http://www.2carpros.com/first_things/clicking_sound_while_driving.htm
i dont really know what is your problem but i have found the most closest/nearest possible solution to your problem.pls check this site and i hope i was able to help you solve your problem. take care.
Oct 12, 2008 | 2000 Audi A4
Kenmore refrigerator is noisy
my kenmore fridge is loud everytime the compressor comes and stays on. I have developed tinitis in the year because of this noise. Solution to this problem : I will never ever buy another Kenmore refrigerator.
Mar 05, 2008 | Refrigerators
Jandy STEALTH 2 HP POOL PUMP  115230V Logo
515 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
