Trying to set up the box on an old samsung tv and it has a green light on lock and is stuck on channel 31 i cannot control it via remote or set top box! How do i unlock the set top box?
  • 5,138 Answers
Try unpluging unit for 5mins then plug it back up to see if it unlocks.
Posted on Sep 10, 2010
My samsung lcd tv stuck on bbc 1 on mono it wont go off screen
pl.see whether the other channels were locked inadvertently 2)if you have set top box remove the connection and connect the cable to antenna slot if you could change channels set top box is defective other wise tuner problem
Feb 18, 2015 | Samsung LN32A330 32 in. LCD TV
Samsung HD tv
Your TV should be an output, only the cables are different.
Let me know the exact model of your tv, and what cable you are using to connect it, so that I can give you more information.
Sep 14, 2008 | Samsung TV Set Top Box Remote Control
I am trying to program my "Direct TV" remote to my Samsung LCD TV Series 5 and can not find the 5 digit code needed to do so.
If you have a DIRECTV white remote, press "menu" then "settings," "setup," "remote", and follow the on-screen instructions.
If using a gray or black remote,
  • Make sure your TV is turned on.
  • Slide the mode switch at top of remote to "TV".
  • Press and hold the MUTE button. This is located above the number 1 button.
  • While still holding down MUTE, press and hold the SELECT button until green light at the top of the remote flashes twice.
  • Then enter 9911, the green light on remote should flash twice.
  • Point remote at TV and press CHANNEL UP button. Tap the CHANNEL UP button repeatedly until the TV powers off.
  • When the TV powers off, press and release the SELECT button.
  • Sep 07, 2011 | Televison & Video
    Can set up th remote control for this tv with the direct tv cable remote
    Here's how to scan for TV codes on your DIRECTV remote
    1.Make sure your TV is turned on.
    2.Slide the mode switch at top of remote to "TV".
    3.Press and hold the MUTE button. This is located above the number 1 button.
    4.While still holding down MUTE, press and hold the SELECT button until green light at the top of the remote flashes twice.
    5.Then enter 991, the green light on remote should flash twice.
    5b. Press 1 again (it will flash twice again), then you press the power on button at the very top right.
    6.Point remote at TV and press CHANNEL UP button. Tap the CHANNEL UP button repeatedly until the TV powers off.
    *If you hit channel up very fast, you risk going past the code. Pressing channel down will back it up. I alway hit channel up very fast till the tv turns off, then back it up slowly till it comes back on.
    7.When the TV powers off, press and release the SELECT button.
    *Note: If the green light flashes three times before TV responds, then all codes have been cycled through. Our remote controls are guaranteed to program to your DIRECTV receiver, however your TV may not be compatible with our remote control.
    Mar 05, 2011 | Curtis LCD2425A TV
    My tv is stuck on a channel
    You have a problem with a internal circuit.you can try by, powering off the tv for about one day. then turn it on again
    Dec 15, 2008 | Proscan PS32125 32" TV
    20 year old Quasar colour TV (no remote)
    That is because the switches of the front panel buttons are stuck or defective.
    Try first unplugging power for ten minutes, this probably wont work.
    To fix this the TV must be taken apart from an expert, and front panel replaced.
    You can enquiry here for parts.
    What you can do at home, is getting a replacement remote and using TV with a remote, or buying a freeview box, and watching and changing channels through the box.
    You can get a replacement remote here: Replacement Remote Control orReplacement Remotes
    My suggestion, if it is supported in your area, get a set top box with 30 channels : Freeview - digital TV from Argos.
    Oct 11, 2008 | Quasar SP-2723 27" TV
    Connect ILO DVDR05 to a digital set top box tuner
    Just run your outputs from your cable to the ILO inputs, then your ilo ouputs to the tv inputs. Use Cable remote to control channels, use ILO source button on remote to access the correct input setting on ILO. AND YES< you have to do this EVERY TIME you turn the ILO on to watch tv.. I have mine hooked up this way to record from my convertor box and My husband hates it.(when he just wants to watch tv.)
    Nov 29, 2007 | iLO DVDR05 DVD Recorder
    Set top box and remote control
    I have the same problem. When I move the 8300HDC away from the TV, or power off the TV, the remote responds. There seems to be some kind of RF interference, which makes no sense since the TV shouldn't emit RF, and the the box should be using IR only for remote input. My TV is a 46" LCD Samsung. Try turning off the TV and see if the 8300HDC responds to powering on and off with the remote.
    Sep 16, 2007 | Hitachi 51F710 Rear Projection Television
    Televison & Video Logo
    24 people viewed this question
    Top Televison & Video Experts
    Electro Med Services...
