Question about McCulloch 16 Inch Gas Chain Saw MCC1635AK
May mac 110 starts then it stops. I choke it it fires then i unchoke it and it starts and stops running.
    Brigadier General:
  • 4,088 Answers
Try backing the choke off about 1/2 way after it pops, and allow it to run for a few moments on that setting. Once the engine warms up, you can back the choke off completely. My Mac mini has no primer bulb, which means using the choke in a similar manner. Don't forget to set the 'fast idle' button on the throttle before starting (blipping the throttle will release the fast idle button). Hope this helps!
Posted on Sep 09, 2010
It will crank and idle while choked but dies when unchoked
Could be a leaking inlet manifold, blocked jets or low float height in carb.
Oct 11, 2015 | ATVs
What causes my 1947 Chevy Truck to not start when warmed up
Here's what you seem to be saying. It does start when the engine is cold...cold enough to require choking to obtain needed fuel richness for starting. But then, when the engine has attained operating temperature, if you happen to kill the engine it will refuse to start. Logic and induction seems to suggest a flooding problem due to a choke that is not unchoking when it is not needed and is attempted to be released. So look to choke malfunction as the first problem needing to be resolved. Then, post again if the no-start problem still persists.
Oct 31, 2014 | Cars & Trucks
Fc420v
remove the main jet in the carby and clean out as it has gunk in it preventing the fuel to pass up to the venturi
Jun 16, 2013 | Garden
Won't stay running
you may need to disassamble the carb and clean it thoroughly.
May 09, 2010 | Poulan "Poulan" Push Mower
Hi i have a 1981 gsx1100et when i start it with the choke out number 3 cylinder does not run as soon as i push the choke in that starts running and number 1 cylinder stops,,, help
check your coil wires they are out of firing sequence. I believe they are 1, 4,2,3. if the firing order is correct. you may have removed the coils and and switch their position.
Feb 15, 2010 | Suzuki GSX 1100 E Motorcycles
My yamaha serow 225 does not start and run unless its choked, when running if unchoked, it will stop.. how to fix it?
clean the carburator withe gasoline..and .Use a compressor to clean and let blow all the dirt inside those tiny holes inside the carburator.If after you perform this and nothing happens,try to replace the carburator.
Sometimes also, the other cause of your problem is because the block is already lose compression.If ever thats the problem,then yo do a reboring.
Nov 09, 2009 | Yamaha Serow 225 WE Motorcycles
Dies in reverse and runs great chocked
FIRST CHANE THE PLUGS DONT CLEAN CHANGE
Jul 13, 2009 | Boating
How do i start a 2001 yamaha 426 motercycle
pull trigger press crank down till it stops let it go all the way back to the top pull trigger push crank just one click then kick it down hard also keep hand off throttle hold brake cylender instead choke once then repeat unchoke should start right up
Apr 25, 2009 | 2001 Yamaha YZ 426 F
McCulloch 16 Inch Gas Chain Saw MCC1635AK Logo
406 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
