Question about GE (PSS26MSRSS) Side by Side Refrigerator
I have a GE Fridge (approx. 1996 model) that was working perfectly, until we moved. Once at the new house, it pops the breaker as soon as it's plugged in. Any suggestions? I don't want to spend a ton on it, as it's just a spare, but by the same token, I'd like to fix it if it can be done reasonably cheap and easy.
  • GE Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Compressor got jarred around in the move and will not start...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 11, 2010
I just moved the fridge to a new house and now the fridge and freezer won't get cold. It had been sitting in storage for over about a year, but worked perfectly before that.
Its possible that during storage a few things may have happened. There is a small fan under the back that keeps the compressor cool while running. Its possible that during moving something shifted or bent the fan area and its not running. Could also be a small critter built a nest in that same area stopping the fan from running. Without that fan--- the compressor will run a very short time and then cycle itself off on the heat safety when it gets too hot. It will keep short cycling off the heat overload until the fan runs again. It will not run long enough to get to proper temp. Just guessing but check this first.
Jun 18, 2015 | GE Profile PFSS6PKX Bottom Freezer French...
Please help my side by side ge fridge freezer is tripping our power I have had it for 2 year we moved houses I left it unplugged for three days in our garage then moved it into the house and plugged it in...
Check to make sure that in the process of moving a "hot" wire under the refrigerator did not come loose and now is contacting a metal part of unit.
U have a classic short circuit which accounts for the breaker popping immediately. It is not a short in the compressor because that would have popped the self resetting clixon and not the house breaker.
May 01, 2017 | Refrigerators
Rcd tripping
Either the start relay in the compressor is grounding electrically or the defrost heater is (most likely start relay). To replace this yourself is difficult as it requires technical knowledge. If you are located in California, bay area I could help you personally
Apr 21, 2014 | GE Profile PSW26P Stainless Steel Side by...
Electrical problem with FA561XF
Could be the breaker. Sometimes breakers just get old and will not hold when a power surge goes through it as when an electric motor first starts up. You have already replaced the compressor with a new one so I would check out the breaker situation. STAY with the same size breaker
Nov 24, 2013 | Smeg Refrigerators
I moved a perfectly working KitchenAid fridge from inside the house to the garage and now it blows the ground fault breaker the second it is plugged in.
Almost definately, there is a wire or more accidently pulled loose while carrying the fridge.Check where the cable enters the fridge and the surrounding area.
Jul 19, 2010 | KitchenAid Refrigerators
The refrigerator trips the circuit.
possible failed start /run capacitor for the motorm
call a technician for a proper diagnosis
Oct 06, 2017 | GE Refrigerators
FIsher and Paykel washing machine won't stop beeping.
if you remove the back panel you can look under there, there should be atrouble shooter/techsheet that will let you know what the flashinglights mean. if not theres a tech support number to aid you as well
Mar 02, 2009 | Fisher Washing Machines
Fridge not cooling
Hello.
The most common thing that happens while moving a frig is when moving it they put the dolly underneath the condenser fan housing and bend it into the fan causing the compressor to overheat before it has a chance to cool down everything. If this isn't the case then I will send you a list of things to check out. Let me know.
Dec 07, 2008 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Popping the Breaker
Ok, first a couple of things, you didnt mention if it popped the breaker when you were using the oven, burners, of both or if it does it as soon as you plug it in. If it does it as soon as you plug it in, you have a short in the back of the unit. you need to pull the back panel off and look to see if the broil or the back element wires were touching the the back panel. This is a common short. If it only does it when you are using both the burners and the oven, you might have a weak circuit breaker that needs to be replaced in your house. Unfortunately, age has little to do with it, I've gotten new breakers that didn't function correctly.
May 24, 2007 | Frigidaire FEF326 Electric Kitchen Range
GE (PSS26MSRSS) Side by Side Refrigerator Logo
74 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
