Question about GE Profile PDW8400J Built-in Dishwasher
Hello, My GE dishwasher stopped draining. Model Number: VSD2304JOOWW I emptied out the dishwasher of the liquid, removed the cover and checked the filter. (Didn't look bad.) Checked the drain pipe under the sink and there was a little debris (slime) but very minimal. The garbage disposal was installed at the same time as the dishwasher 3 years ago (brand new place). What else could it be? Any advice would be helpful as my new home seems to be falling apart and it is getting pretty expensive. Thank you in advance. Lauren
  • 101 Answers
Drain pump either disconnected or jambed
Posted on Sep 10, 2010
Hello to my dishwasher got inside small screw and stop works, error i20 appear how can I remove it
As you realized, it is a small bolt blocked drain pump and therefore it is necessary to dismantle the drain pump and remove the bolt. You may need to replace it if is broken impeller. Access to drain pump is possible in two ways. From below and from the front side under the door of dishwasher. Be sure to disconnect the power supply voltage. Look the pictures.
Dado
Dec 10, 2014 | AEG 23 in. Favorit 86070Vi Built-In...
Dishwasher not draining
I am not familiar with this model, but in general, dishwashers have a grill or trap at the bottom near the back usually and it's held down by screws. SHUT THE POWER AT THE BREAKER PANEL AND SHUT THE WATER SUPPLY OFF! Then check the type of fastener and remove the cover. If it is obstructed by food debris, you'll see it there. Good luck and let me know if this helped.
Mar 29, 2013 | GE Dishwashers
Won't drain
I found a video that explains how to fix this issue, here is is.
Bosch Repair video
Feb 06, 2011 | Dishwashers
Hi I have a GE Dishwasher model gsd2200g -03 and I am getting C1 & C2 error codes but it seems to be working fine. I disconnected the drain hose and the water appears to be draining properly
hello there:
if you have installed a new garbage disposal make sure the knock out has been removed if removed then check the drain valve in the pump hope this helps you out sincerely D.Jones
Jun 08, 2010 | GE Profile PDW9880NSS Stainless Steel...
GE Nautilus dishwasher isn't draining... PLEASE HELP
Check floater valve.
Inside the unit. On the floor. Looks like and small upside down cup.
If it is jammed in the up position it will stop the machine. Lift, clean underneath. It should drop and the machine will run.
The float valve stops the machine from over filling.
Could also be clog in the drain filter. Remove the cover from the drain inside the unit. look for clog in the filer of the drain.
If none of the above it is the timer. The timer tells the unit what to do (fill, run, empty). If it is not working the drain function will not run.
Adrian
Mar 07, 2010 | GE Nautilus 24" Built-in Dishwasher
CDA dishwasher (model number CW496) , stops working at the rinse cycle, and does not empty, filter is ok, tried re-setting the programme but unless there is no water being held the programme won`t work
my dishwasher starts off with good intentions then a couple of minutes later it starts beeping non stop.I open the door to find it has turned on to the rinse cycle and will not do its job.I continue to start it again and then it repeats the problem again.Can you help?
Sep 21, 2009 | Dishwashers
GE dishwasher, model #gsd4000j00bb, won't drain.
I just posted the soloution that I found for this problem to another question. I found a bone stuck in the impeller of the discharge pump. Requires that you pull the unit out turn it on its side (rather messy and everything needs to get disconected as if you were going to remove the unit from the house and install a new one). Find the discharge pump and remove the cover (I pulled a 2.5" rib bone chip) remove the blockage, button everything back up, hook it all up slide it back in and now mine works.
Jan 06, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
Whirlpool model shf 5800 will not drain completely
Did you remove the knock-out in the disposer...if not that's why you are not draining.
Jun 02, 2008 | GE Dishwashers
Dishwasher doesn't drain
Greg, if the model number ends in GO1, your dishwasher has a piston nut assy. thats problably giving you the grief. If this assy. goes bad you will have water left in the tub at the end of the wash. A common GE problem. It's located under the filter screen in the back and just unscrews out. Part number is wd24x199. It's an easy fix. Look up the part on the net to get an idea of what it looks like. Catriver..post back.
Jan 25, 2007 | GE 24 in. GSD1000G Built-in Dishwasher
GE Profile PDW8400J Built-in Dishwasher Logo
208 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
jdthefixer
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
