Question about Hotpoint NVL333EY Electric Dryer
Okay my dryer has been popping the CB for the last three days, I through it was the two thermostat's were replaced. Ran the dryer ops checked normal, now when I put a load of wet clothes in it runs for about two minutes then the CB pops. I think it may be motor or motor form t switch or both? By putting a load on the motor it heats up too much and putting a large load on the circuit might cause the problem? Can you please help Thanks?
  • Hotpoint Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
I garee with you about the motor, but it also could be the heating element heating up and shorting out...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 12, 2010
I have changed my theremal fuse twice in the last three days. it seems that the dryer is getting too hot. When i change the fuse it works for one load, then the burner will not light any more. is there...
Yes, the thermostat needs to be replaced at the same time...
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 10, 2010 | Roper RGX4634KQ Gas Dryer
Dryer wouldn't work last week. Found the Thermal Fuse with no continuity and replaced it. After drying one load of clothes yesterday, dryer won't work again. I suspect the thermal fuse again. What else ...
Or your breaker. The dryer will work just won't heat with the thermal cutoffs or element or the breaker. Dryer won't do anything if the thermal fuse is bad. You might also want to check the outlet from L1 to N and L2 to N for 110 on each side. Good luck.
Aug 22, 2010 | Whirlpool Dryers
Just got the unit from a friend and had to change the plugs from four to three and it turns on but there is no heat. the dryer is less than a year old and worked three days ago.
the only difference is the 4 prong has a ground wire,if you put the white in the middle,the red where it was before on one side and the black on the other side it should work.check the back of the dryer to make sure you have the correct voltage,with a meter set on volts,touch the white and red wire and you should have 110,then touch the white and black and you should have 110.if not you have a problem with a fuse in the house.one fuse runs the dryer and another is for heat but if you have 220 or 240 in the back of dryer something is blown in the dryer.you'll need to check out the thermostats and the heater in the dryer.let me know what you find.your vent line could be clogged with lint and popped the high limit thermostat on the heater box
May 15, 2010 | Kenmore 63942 Dryer
Just bought a new HE5 dryer three days ago and used it for the first time---the sides of the HE5 dryer are extremely hot (could burn hand), is that normal and what could be the cause?
check the vent line,could be clogged with lint if you never cleaned it,you should clean out your dryer every year by taking off and cleaning out the duct that the lint filter slides into,vac out the inside of dryer and clean out the vent line,if it's a long run from the wall to the outside vent hood blow it out with a leaf blower,go outside and make sure the air is blowing out with force,all a dryer does is move air and if something is blocking the air flow the dryer will get hot,you'll start blowing thermostats or the thermal fuse because they are safety switches so if the dryer does run to hot they pop and shut down the dryer so hopefully you don't have a fire or damage the dryer
Jan 10, 2010 | Kenmore HE5 Electric Dryer
The transformer on my central AC/heater (luxaire model # A236A344T LH) keeps going out. There are 4 settings on the wall. Cool, off, heat and EM. Heat. The setting switches to EM. Heat each time the...
You might have some thermostat wires that are touching meaning the insulation has been broke off and getting a direct short. Check the wiring going to the outside unit and replace any wire that is in bad shape. let me know okay. Ken
Dec 11, 2009 | Honeywell Programmable Thermostat Heater
DLE2532W Not heating
ask for old the fuse ,,lg have resettable thermostat...keep me posted,,its a push botton thermosatat..also they replaced this thermostat with a higher rated one,,,if you need part # just ask onthejob keeps uint from having to be reset...
Jan 18, 2009 | LG DLE2532W Electric Dryer
Whirlpool dryer won't heat
Ended up replacing the solenoids and the burner ignited, flame stayed on. Problem appears to be solved. Thanks for your help and posting.
Jan 03, 2009 | Whirlpool LGR7646E Dryer
Hotpoint NVL333EY Electric dryer blows thermal fuse
I had the same thing happen, I replaced the thermal cutoff and made sure no lint build up. It lasted a week then blew again. I then replaced it again and got to thinking why it would blow. I then took apart the exaust inside the dryer running fron the drum to the motor and right before the motor was a build up of lint ane particals that was almost like compressed sawdust which was blocking half of the line. I cleaned this out and it seemed to work much better.
Jan 04, 2008 | Hotpoint NVL333EY Electric Dryer
Kenmore dryer. 80 series. 6 years old.
There is no reset button on these thermofuses unfortunatly. Sometimes you can have a timer go out and cause a fault in the thermostats, thermofuses, etc. Doesnt happen to often, but it does happen. Be sure before you spend a lot of money, that you thoughly clean and check you dryer vent tubes or pipe. A clogged vent tube will normally cause major league problems (i.e. burned thermofuses, busted elements, out-of-temp thermostats, slow or no drying conditions, etc.). You can replace these yourself pretty easy if you have some hand tools (call Sears to fix and you can buy a new one) and a couple of minutes. Let me know if you want further instructions or help. Good Luck!!!! JIm
Dec 29, 2007 | Dryers
Dryer won't dry
There are three possible parts that can cause this.
1. Thermal fuse
2. Thermostat
3. Flame sensor
https://www.repairclinic.com/Shop-For-Parts/a8b6d600503/Model-11072212100-Kenmore-Dryer-Parts
You can check the first two with a meter to see if they are ok. If they are then you should replace the flame sensor.
Mar 25, 2017 | Dryers
Hotpoint NVL333EY Electric Dryer Logo
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
