Question about Vacuums
My daughter pulled to hard on the ceiling fan pulling out the chain. i have taken it off and apart, nothing appears to be broken but im trying to figure out how to put it together so it retracks, i assume it has something to do with the tension of the small spring inside of it, but not sure how to put it back together im wondering if there is a internal diagram of this ???
    President:
  • 1,796 Answers
Don't even bother to repair the pull chain switch, get a new one at KMart, HomeDepot or similar store for less than $2.
Two times I've repaired one, it comes apart when I need it the most.
Good Day! Don't forget to rate this post!!
Posted on Sep 09, 2010
Intensity vacuum really loud
Loud vacuum is usually a broken fan which requires pulling motor.
Jan 26, 2014 | Electrolux Vacuums
Nothing going into dirt canister
Is there suction at the hose? If not it is either blocked or the suction fan is broken. If there is, then there is a blockage in the pickup section, something is lodged across the channel after the brushes and before the place where the hose plugs in.
I think there is a safety switch to prevent it from running with the canister out so hard to check for suction at the top of the motor/suction fan. Make sure nothing is over that part under the canister too! If you can figure out how to bypass the safety switch (if there is one), you should have good suction where the canister sets on top of the motor base.
Oct 06, 2012 | Dirt Devil UD40270RM Quick Power Compact...
I have a broken chain switch that will not allow me to use all four light sockets. presently only using two sockets. Question: can I by pass the switch by combining all the black wires from the leading...
The blue should be for the lights and you can ty this into the black. The red should be the incoming for the motor to the fans. Some models are different and I strongly believe you have got to be talking about a ceiling fan and not a vacuum. Is this a test question? Because it is a darn good one if you do not mind me saying so however you might have not noticed to check or uncheck a box for the fans. Good luck.
Nov 02, 2010 | Vacuums
I have a 11 yr old Hampton Bay ceiling fan with light kit. The pull chain to operate the fan broke (evidently inside of the fan) and I cannot figure out how to fix it. Do I have to take off the light...
I'm unfamiliar with your exact model but your description makes it very similar to the "King of Fans" branded models I fitted in my house twenty years ago and have fixed a few times. It might even be that yours are made by the same company as Home Depot source their Hampton Bay range from a variety of manufacturers including KoF.
You are entirely correct that you can access the pull chain once you have removed the lamp assembly. If it's just the chain which has snapped then it's normally straightforward to remove the short piece from the switch and install what's left onto the switch, but if your chain is the typical ball and link type and is more than a few years old then replace it with a new one if you can obtain the right size easily. They're not expensive, and the old one will have wear and tear making another failure highly likely. If either of the switches has failed (the pull switch or the fan direction switch) then they're also usually easy to obtain from any electronics store at low cost or you can contact Home Depot regarding spares, also check here and here. Your total repair cost should therefore be no more than a few £'s, $'s or whatever else you use locally: far cheaper and quicker than fitting a new fan.
I hope that my reply has been of use to you and saves you a lot of time and money. Please take a brief moment to rate my answer.
Oct 07, 2010 | Vacuums
I have a ceiling fan with 3 lights. We do not use the remote control and did not install it. The lights stopped going on today. The fan works, but the lights do not. I have tried changing bulbs, but...
Sounds like a loose wire. If you turn the lights on via a wall switch or a pull chain, I would start where you hooked the wire for the lights to the house electricity, most likely where the fan meets the ceiling. Pull the "bell" part of the fan down that covers the ceiling box and see if there is a loose wire inside. There should be a plastic cap called a wire nut that covers the wire connection. Make sure it is secure and if possible, put some electrical tape around it. Please let me know if you have questions.
Sep 12, 2010 | Vacuums
Won't turn on; no lights, no power.
Did you try a different outlet? The cord may have gone bad, most of the times I find that people don't pull the plug out of the outlet by the plug, they just pull the cord, or it got yanked out some other way and that will break the wire inside the cord. Other then that, it would have to be taken apart to find the problem.
Apr 24, 2008 | Electrolux Epic 6500 Vacuum
Vacums
check belt not broken - could have happened when you caught tassle in head
Apr 18, 2007 | Kenmore 23313 Whispertone Bagged Canister...
Vacuums Logo
125 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
