Hi
Follow the Engine Stop/Brake Cable to the Engine. Remove the Cover at the End of the Cable. Have Someone Operate the Cable and Watch the Lever Move. It Should Connect with the Small Stop Switch When the Bar is Released. The Cable May Need Replacing or the Spring on the Stop/Brake Assembly May be Broken or has Jumped Off.
From under the flyweel comes a wire.Check it.It is connected with the off position of the throttle. The kill switch wire is broken or has come loose. If it is a push mower, look at the end of the throttle cable where it touches ground when the lever is in the OFF position. If it is a riding lawn mower, follow the wires from the ignition switch, you will find a disconnection someplace near ground .
Please accept the solution if it’s helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
the motor runs great but it will not shut off!!!!!!!!!!!!!!
It is not quitting, That's the problem I can't shut it off
