Question about Hifonics Brutus BX 1605D Car Audio Amplifier
Bxi1610d value of resistor R42 - Hifonics Brutus BX 1605D Car Audio Amplifier
Jvc subwoofer will not power up
you can get the value from this link..
http://www.doctronics.co.uk/resistor.htm
Nov 01, 2008 | JBL LC-S960 Car Speaker
Resistor value of R704 of Sharp tv model 21v-fk200m
How do i unlock sharp crt tv model 21v-fk200m? i forgot the ...
www.fixya.com/.../t25439922-unlock_sharp_crt_tv_model_21v_fk200...
Feb 17, 2015 - Question about Sharp Standard (CRT) Televisions .... What is the valueof resistor R704 in SHARP TV model 21V-FK200M circuit diagram.
Sharp value 2 watt resistor Standard (CRT) Televisions ...
www.fixya.com > ... > value 2 watt resistor > Standard (CRT) Televisions
value of r707 sharp model #27c241 R707 is 27 ohm 1/2 watt carbon resistor,if you ... What is the value of resistor R704 in SHARP TV model 21V-FK200M circuit ..
Dec 28, 2015 | Sharp Televison & Video
Radio Shack Multimeter, 22-168a, shunt resistor value????
Go to the Radio Shack site and you may with the model number find a schematic or you can email/contact them for the value of the resistor.
I predict it is a precision value and type you will have to get from them if available.
PS: you posted in wrong catagory as this is TV section.
Mar 12, 2012 | Televison & Video
MY KLH E12DB POWERS UP. WORKS INTERMITTINLY, AND WILL ALWAYS POWER UP BUT NO SOUND
I HAVE SAME PROBLEM. CAN YOU CHECK RESISTORS R42 and R49. Its on the middle circuit board. I need color code
Aug 07, 2011 | Audio Players & Recorders
18 volt supply too low. resistor R42 burned. Q20 not installed. schematic shows 4700 ohm resistor with Q20 installed. What value if Q20 gone?
I would fit the same type, unless the schematic shows a change, which clearly it doesn't. However I would be surprised if R42 burnt up alone! Look at the schematic, is R42 linked to any other transistor or part? If so check them if you can.
By the way is R42 a fuseable resistor, for example is the symbol on the schematic or on PC board different to most other resistors?
Feb 18, 2010 | KLH ASW10-120 Subwoofer
Hitachi 50FX20B convergence problem
RK42 is 2.7 ohm 1watt
RK46 &RK54 are both 2.2 ohm 1watt
RK50 & RK62 are both 3.3 ohm 1watt
RK58 is 3.9 ohm 1watt
They are all metal film (flameproof) 5% resistors
Jul 20, 2009 | Hitachi 50DX01B 50" Rear Projection...
Sony resistor values?
It is recommended to use the same value due to the function of the resistors and their values.
A lower value will let the current flow a bit faster and the higher value will slow it down according to their design.
Try installing the same value of 220 ohms.
Hope this helps.
May 05, 2008 | Audio Players & Recorders
Hifonics Brutus BX 1605D Car Audio Amplifier Logo
60 people viewed this question
Top Hifonics Car Audio & Video Experts
Professor_V
Professor_V
Matthew Spark
Matthew Spark
Radames Pagan
Radames Pagan
Are you a Hifonics Car Audio and Video Expert? Answer questions, earn points and help others
