Neopost 7755 folder inserter document feeder is pulling document for folding through at a slant causing foldng to be uneven and not parallel to the page
2 Suggested Answers
ftw1952
  • 10319 Answers
SOURCE: Repair manual Neopost Folder inserter
here is the website to download your service repair manual
http://www.scribd.com/doc/36359094/Duplo-MD430-Service-Manual
Posted on Aug 29, 2010
Brother mfc j533ddw top feeder sends documents through crooked. Sometimes folds over top corner of first page of document.
Use a bright light source and examine the paper path. There may be a scrap of paper or some obstruction causing foldover.
May 19, 2018 | Brother Office Equipment & Supplies
At random times, when a user prints, a document, pdf, picture ect.., it's slanted. It also happens when a user scans to themselves. What can cause this to happen?
There mite be something in the path of the paper which the paper hits and so it is slanted have you tried scanning on the big glass instead of thru the document feeder does it happen then? Now the printing is something else are you talking about copying or printing. If print I would check the paper draws ensure the guide are snug up against the paper. Do you internal prints slant such as the meter count print out or the fax info reports. or the demo page? If the problem is coping then place the original on the big glass and see if the slant There are small mylar guides though out the document feeder if some one pulled the original document out in the wrong direction they mite have flipped on of them causing a corner of the paper to hit one slanting the original ALWAYS pull the original out in the same direction as the flow of the document. Try sticking a business card down thru the way the paper flows you mite be able to reset the offending mylar.
Jul 22, 2014 | Konica Minolta bizhub C250 All-In-One...
Neopost si 68 stops after loading paper.
Go To Below official Canon Printer Page For Your problem
http://software.canon-europe.com/files/soft35401/Manual/Canon%20MP270%20_MP250%20series%20EN.pdf Hope It's resolve all Your Printer Problem,
Or
Still having Problem Then follow Us For Canon Printer Support
Mar 12, 2014 | Office Equipment & Supplies
We have a scooter that it will not open..
While the scooter is folded, grab the neck and push it in and down at a slant. You will notice how it sinks in a little, once in and down at the right angle you can pull it open.
May 13, 2012 | MGA Entertainment Bratz Musical Stars Fold...
Black lines down on printed page
This is caused by dirt/debrise on the ADF (automatic document feeder) scanner glass. You need to open up the feeder where your originals are fed in and look for a strip of glass that runs from front to back. It is about an inch or so wide. You need to clean this glass to get rid of the lines. Some models have this glass just to the left of the large main glass, but in your case I beleive it is in the feeder itself.
Good Luck.
Apr 23, 2010 | Brother MFC-7820N Printer
How do i unfold the handle and the spiderman scooter
While the scooter is folder, grab the neck and push it in and down at a slant. You will notice how it sinks in a little, once in and down at the right angle you can pull it open.
Dec 25, 2009 | Street Flyers Spider Man SM3 Folding...
Document feeder
Most likely there is something in the path.
That feeder is easy to service. But first of all I would take a manila folder adn try and push it through the feeder paper path to clear it of any blockage.
Oct 01, 2009 | Xerox WorkCentre M20 Black and White...
Canon mx300 printer feeder pulls unevenly causing paper jam
the left side of the printer pulls the paper causing the printer to jam when trying to print
Apr 03, 2009 | Canon PIXMA MX300 All-in-One Printer
Document jam
There is a sensor in the document feeder that most likely is stuck on the frame or the spring fell off and is not resetting. Have you taken a minela folder and run it through the feeder to be sure there is not a small fragmant of paper on the sensors? If you havent try that, or a piece of paper folded in half twice and keep sliding it though the feeder.
You would have to take the feeder apart to get the sensor set, That is best accomplished by taking the back cover off, then the left side cover, ( looking from the front) and disconnecting the feedder connectors, then removing it from the scanner.
Apr 07, 2008 | Xerox WorkCenter PE120i All-In-One Laser...
Jamming of documents in autmatic feed for scan mode
One way to unjam that would be to take a stiffer plastic or manila folder and insert it slowly into the document feeder and the slowly push it through the feeder until you dislodge the jammed document out of the bottom of the feeder.
That is a common practice in removing jams in the feeder.
Mar 13, 2008 | Office Equipment & Supplies
k24674
jasbo
jasbo
