Question about Haier HVFM30A Wine Cooler
Need new motor for Haier model HVFM 20ABB - Haier HVFM30A Wine Cooler
My Haier Dryer Model RDE350AW only clicks when I press start button, any suggestions?
Since the start relay is clicking it is likely closing the circuit and sending voltage to the dryer motor. You may have a defective thermal limiter fuse blown, it is near the dryer motor so you must remove the back or front of the dryer to access it for testing. Always unplug the dryer before any work is done. You will need a DVOM meter (about $10.00) to check the fuse for continuity.
Dec 28, 2016 | Haier Dryers
Spin dry
I have washer Model # XQB60-91BF It do all functions eccept spinning when it comes on spinning drum does't rotate. I replaced drain pump but does't spin. Can you guide me about trouble.
Thanks. email: khansaleemuddin@hotmail.com
Jan 20, 2013 | Haier XQB60-91BF 1.92 cu.ft. Portable...
Dvd on tv/dvd combo doesn't work on fairly new haier tv
Dvd players don,t use (Heads) They have a (Lazer) Eye, The tray was probally Knocked out of (Alighnment) End needs to be Adjusted.Or with Haier from my expierance with there stuff,Its like a (Disspossiblle) Liter or (Flashlight) Once they Quit working fire it, The drive motors in there (DVD) Players don,t last to long.,I have seen some only a month old where the drive motor burnt out on them.
Oct 02, 2012 | Haier HLC15R 15 in. LCD TV TV/DVD Combo
The fan stopped spinning in my unit and a tech told me i need a new motor for it...where can i get that and whats the approximate cost? the brand is Haier window unit
Any HVAC supply house or you can try WW Grainger, but between the price of the motor and the time and labor to install it, it might be cheaper to buy a new unit.
Jul 20, 2010 | Haier hwr10xc6 Air Conditioner
Need UBS Cable Drivers for this model
To download the software enter the model number here:
Haier Download Center.
To purchase the cable, check the links below:
Haier M260 Data Cable $10.14 - Bloo Choo Haier M80 Data Cable $10.14 - Bloo Choo Haier P7 Data Cable $10.14 - Bloo Choo
Regards
May 29, 2009 | Haier Cell Phones
Making clicking sound motor gets hot but not cooling
Your PTC relay on the compressor is bad needs to be replaced.
First be sure to unplug cooler. Remove the cardboard cover that covers most backs of the units. Remove the plastic cover that is on the side of compressor. It is held on with a metal clip. Now you should be able to see the relay pry the relay straight off. note the wiring and position of relay. Only three prongs on compressor. Go to a parts house for appliance's and with your make and model number should be able to get a new one. Let me know if you need any more help. ken
May 03, 2009 | Haier HVFM20ABB Wine Cooler
Fridge not cold but freezer working great
I had the same problem, and it turned out to be a cooked fan motor.
I couldn't find a reasonable (less than $150) replacement motor from Haier places, but I just took the motor out and took it to an appliance repair center (in North Denver)
They said it was a standard part, charged me around $22 for a new one and I was all set.
For my replacement motor, it was a reversible design, and was initially set to go the wrong way, so I had to reverse it.
Apr 04, 2009 | Haier HTQ21JABWW Top Freezer Refrigerator
Need roller guide for Welbilt microwave model MR626T w/turntable - can u help?
Welbilt was sold to Haier Corp. So maybe this works:
Contacting Welbilt Phone (Haier): (877) 337-3639
Mail:
Haier America
1356 Broadway
New York, NY 10018
USA
Nov 17, 2008 | Welbilt MR626T Microwave Oven
REMOTE CONTROL CODE FOR HAIER TV
We have a Haier TV model 3 HL32R2a, the cable remote no longer turns the set off or on or controls the volume. We can only do that with the tv remote. Tried putting in the universal code, and the Haier code and it didn't work. Please help.
Dec 09, 2007 | One For All URC-4330 Remote Control
Haier HVFM30A Wine Cooler Logo
Top Haier Refrigerators Experts
John Tripp
John Tripp
doggzzz
Level 1 Expert
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
