Question about LG GT540 Cell Phone
Lg gt540 micro sd card won't open on my pc????????
You have to install your lgpc suite first to your computer if you can not do it directly remove the memry card 2 gb which is free when you bought it then removed it then connect it ti card reader and from it down load the lgpcsuite from your memory card to your computer then put your memory card to your cellphone then connect it thru usb then mount it or allowing your sd card to mount to your computer see the usb connection above the screen drag it down and youll se the word mount click it and then proceed to you laptop and click the lg pc suite and it is done
Posted on Feb 03, 2011
I am connecting My LG gt 540 into my pc, sd card is not open?
OK check to make sure that the SD card isn't write protected, either on the SD card or in the phones settings? Also try formatting it on a PC with a SD USB adapter format FAT16/32 and then put in the phone and if required format again with the phone after which you should be OK, if it still will nor work maybe try another SD card? as that one just maybe faulty?
Oct 16, 2011 | LG GT540 Cell Phone
How to format a sd card for lg optimus gt540
Go to Settings->SD Card & Phone storage->Unmount SD cardNow click on Format SD card.
Cheers,Mr.Maduraikaran.
Aug 25, 2011 | LG GT540 Cell Phone
My lg t300 isn't reading my micro-sd card, so what should i do to fix it?
Try checking locky micro SD card on hand just in case locked. Next do an anti virus scan on your PC, usually data files have Headen infected due to virus, or did the format but not before first copy the existing data and save it on your PC. Next copy and paste data on the micro SD card. nex on a micro SD card input, and open menu phonsel phonsel, next select memory. if still not read, error mean micro SD card, and replace with a new
Aug 22, 2011 | Gomadic Car Cup Holder for the LG T300 -...
I have an LG Optimus M. It says the SD card is not installed. I have 2 of them. I reformatted both and it's still saying that. My computer recognizes both SD cards but not my phone.
Hi Everyone,
I had the same problem, and fixed it by very gently bending the Micro SD pins up a little. See the picture below, remove battery first, get a very small screw driver or other implement and one at a time bend each of the 8 pins up slightly, you do not have to bend them much so be very careful. Make sure none of the pins are touching when finished. So the cause of the fault in my LG Optimus GT540 phone was the pins had flattened and were not contacting the contacts on the Micro SD Card well enough. Which is a bit of a design fault really because my original card stopped working because of this and ended up fried. I done the fix above when the new card I bought and checked that it worked on my computer, but when I put it in my phone would come up with the message SD Card removed.
Hope this helps!
Regards,
Peter
May 24, 2011 | LG GT540 Cell Phone
Hi, i m using LG GT540 mobile. The camera won't work. it ask the SD card. After i put the card, when i go to the camera, its not open. it just blink only. or sometime the message was appeared "sd card...
Sometime this occurs due to the format issue. Did you format the SDcard using Win32 or NTFS? those two are likely the culprits.
If not, it is time to replace the card.
Mar 04, 2011 | LG GT540 Cell Phone
I am not able to connect my LG to pc after i enable sd card also i am not able to open the drive
i thing your memory card problem you check anthor memory card to open in options.
Nov 23, 2010 | LG GT540 Cell Phone
How can i install application in sd card in lg gt540...
if you insert the card into the pc and try from that source and you are unable , maybe it can be installed like that just on the phone, some phone dont give the option to install on the micro sd just on internal memory
Nov 22, 2010 | LG GT540 Cell Phone
I can't connect my LG GT540 to Lg OSP some connection error, on the other hand i able to connect my phone on LG PC Suite. How can i put USB mode in PC suite mode. i cant find the settings.
The PC suite is found on your SD card. Connect the usb cable to your phone and when prompted enable SD card. Then select on your PC computer and you will see another drive being that of the SD card. Open the olders and you will see the install option for the suite. Install and follow the prompts.
Sep 24, 2010 | LG GT540 Cell Phone
LG KC550 PC Suite Problem
I speant Hours swearing at my phone because it would not read my music files, Tried the card on many different phones which would take Micro SD and all other phones read the music Just not the LG KC550.
I found that getting a Micro SD dongle reader, Insterting your 2GB Micro sd card in that and then putting your music files into the "sounds" folder works.
Instructions.
1. Insert Micro SD card into Card reader.
2. Insert card Reader to Computer Via USB.
3. Go to my computer and Open the USB Card reader.
4. Select the Music files from your pc Via Copy files
5. Go to open Tab (Where you can see your Micro Sd card) Open the sounds folder and Paste.
If you are finding it hard to get the 5 folders of images, Documents, Sounds, others and Videos on your Micro SD card. Format the card by going My computer, Right click the Card reader (with you Micro sd card inserted) and click format. Takes a few seconds. Insert the card into the phone, the phone will auto put the folders on the card. Then go to step 1 (above) and start again.
Hope this Helps guys.
Apr 04, 2009 | LG KC550 Triband GSM 5MP Camera MP3 Phone...
LG GT540 Cell Phone Logo
1,524 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
