Question about Proview PL926WBi 19" LCD Monitor
The moniter blacked out, blue light is saying the moniter is still on, but screen looks like there is no power. When you turn on the moniter, the screen shows up for a few seconds, then blacks out again! Please help!
    New Friend:
Unplug power. Unplug VGA cable. Remove back of monitor. (four small Philips headed screws along the bottom rear. Remove screws attaching Monitor to it's base. Carefully, lean the screen away from back of case. Gently unplug 25 pin cable from the screen.
Connect AC power.
Screen should power on Gray to White. Ble light comes on Blue.Flickers then changes to Amber.
Reconnect VGA cable. Monitor should work.
Close up the monitor in reverse order to opening it.
If these steps don't solve your monitor, consider replacing as cost of repairs may shock you.
Posted on Mar 27, 2011
SOURCE:
Viewsonic sreen isn't displaying the picture
More likely to have bad caps, see example here: http://s807.photobucket.com/home/budm/allalbums
Common problems to ALL brands, they all failed after a couple of years.
Jan 17, 2010 | ViewSonic VX2235WM Monitor
I have a samsung Syncmaster 2343 and I can turn it on just fine and my computer recognizes that it's hooked to a moniter but the moniter shows the screen for a few seconds and then it all goes black. It's...
If your up to opening the monitor it would do you well to look. It sounds close to what I experienced.Refer to Problems with Samsung SyncMaster 2053bw for info on opening.
Nov 11, 2009 | Computers & Internet
Screen goes black, but power light is on (not blinking)
The problem is not with your screen. Its the problem of Video Card of your system which is unable to send Video Signals to the Screen.
Apr 23, 2009 | Daewoo L700C 17" Flat Panel LCD Monitor
Screen black
if monitor light is on, check the connecting data cable if it is ok then consult a technician.
Oct 28, 2008 | Computers & Internet
I NEED HELP PLEASE!!!!!!! PROVIEW 19" MONITER.
Does the led on front of the monitor stay blue or does it become amber ?
If it becomes amber, then you are not getting a signal.
No harm in trying this : You can try to see if it is a contact problem.
With the monitor unplugged.
Use a small paper clip to run in and out of the blue vga plug holes a few times each to make sure they are not plugged or gummed up.
If that doesn't help and you know that your video cord is good, then I am afraid to say that more than likely there is a problem with yor video card.
If it stays blue then the signal is there but the screen isn't fully lighting up, leading to a failing power-inverter board or a bad bulb.
powerseller
bammbammfran
Oct 12, 2008 | Proview PL926WBi 19" LCD Monitor
Monitor goes blank less than a second after turning on.
the moniter may be having  some technical errors   maybe the IC's has got corrupt
you need to call the seller of the moniter
Sep 06, 2008 | BenQ FP71G 17" LCD Monitor
MONITER LIGHT IS GREEN BUT ONLY SHOWS A NORMAL SCREEN FOR 1/2 SECOND THEN TURNS BLACK
HI. I had the same problem with mine. It would flash the screen on for a split second and then turn black, the whole time the power light remained green. Upon opening up the case, I pulled the combo power supply board/inverter board out for inspection. I noticed one of the capacitors had a bulge on top indicating it was bad. It was the the 680uf 25v capacitor. I desoldered it, and soldered in the new one. After hooking everything back up, bingo!! Monitor now works perfectly. I couldn't find an exact match to the capacitance locally, but I had a 1000uf 35v cap in my utility box. It worked fine as a replacement. You can usually go within 30 percent of tolerance and be alright. Just don't go under on capacitance or voltage. I hope this helps.
Nov 25, 2007 | LG Flatron L1710M 17" LCD Monitor
Proview PL926WBi 19" LCD Monitor Logo
312 people viewed this question
Top Proview Computers & Internet Experts
 Mike M
Mike M
Siul Oyaratgam
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
