Question about Hotpoint WMA44 Front Load Washer
Water leaking from the door and drawer and is there a filter that should be cleaned
  • 101 Answers
No might have tear in gasket
Posted on Sep 10, 2010
  • 30 Answers
SOURCE: Hotpoint WD64, leaking water from soap drawer
try turning down your cold water pressure. some times the pressure it is so great that the water hits the soap dispense and spill over. this is a common problem with front loaders??
Posted on Aug 15, 2007
SOURCE: water is leaking out of the washing powder drawer
the spray holes in the soap manifold are partially blocked and spraying at an angle. try to reduce the water flow pressure at the feed tap and clean the water holes in the soap tray manifold (above the tray).
Posted on Feb 16, 2008
  • 118 Answers
SOURCE: Water leaking from Door and Draw from Hotpoint Aquarius Extra
is the pipe were the water gose in clear it is leakiing by the door cus the water flows down the machine and own from the door hope this helps.
Posted on Sep 02, 2009
  • 215 Answers
SOURCE: water coming out of drawer & door
Hi Gary,It sounds to me that you have a blockage within the pressure systemas this is a classic sign. If you take the top off the machine you will see a round switch with a few wires going to it.This is the pressure switch. at the bottom of this switch is a thin pipe,normally black or clear. there is a small spring clip holding this pipe to the switch, If you remove this pipe and gently blow down it you will probably find it is blocked. You will then need to follow this pipe to the bottom of your machine. At the bottom of the machine where this pipe is fitted you will see there is a chamber and it is this chamber likly to be blocked.Some times you may clear this with a small piece of wire by removing the small pipe and poke wire through, but best way is to see how this chamber is removed and remove it for cleaning.Ensure machine is off at mains. this chamber fills with water and causes air pressure within the switch at the top of machine, which in turn tells programe when machine is full and also when empty. If this fails then machine will not turn off water supply as long as it is on. there fore when you reconnect parts ensure they are tight and clips back in place. Good luck and hope this works. Failing this working you may need to call an engineer to check switch and possible fault on board.
Posted on Feb 13, 2010
SOURCE: my miele washing machine is
miele washing machine leaking water
Posted on Nov 29, 2010
My double drawer kitchenaid dishwasher sold red light and beeping during cycle wont turn off and runs even with door open, turned breaker off
If you using upper or lower drawer and this shows up it means the dishwasher has water under the filter board which located on the bottom under the lower drawer. You have to disconnected power,removed the lower drawer, clean the water, replaced filter board, check the dishwasher for leaking.
Nov 26, 2017 | KitchenAid Dishwashers
Refrigerator RF323TE how do I change the water filter?
The filter for the french door refrigerator is probably behind the vegetable drawer, if you do not see it in the upper right hand corner of the refrigerator compartment. Remove the veggie drawer and turn off the water coming into the refrigerator. Rotate the old filter to the unlocked position and remove it. Then take off the protective cap from the new cartridge and insert it into the refrigerator. Rotate it to the locked position. (Rotate the filter to position the label before you insert the filter. Then the filter goes in correctly.) Reinsert the vegetable drawer and close the doors. Then turn the water back on and fill several glasses with water to clean the filter. Pour that water down the drain at your sink.
For pictures of how to hold the filter, see http://www.samsung.com/us/support/owners/product/RF323TEDBSR/AA . See the FAQ on replacing the water filter. I hope this helps.
Mar 31, 2013 | Samsung RF323TEDBSR 31.6 Cu. Ft. French...
I have a Miele W4840 front load washer and there is water leaking from the door. I've checked the seal and it doesn't seem to be damaged, but there is a definite leak. Please advise.
first make sure your detergent drawer is not popping open. water will run out from beneath the drawer, run over to the top of the door, run down the door, and then straight down to the floor. If you are not leaking out of the detergent drawer, the next thing down is the bottom of the glass door. look at the glass where it contacts the door seal at the bottom. It should be clean and smooth. Most likely you will find lint, hair, and soap residue. that needs to be cleaned off. any surface imperfections will cause a slow drip or trickle of water to come out of the lowest part of the door. If that is fine, and it is still leaking, open the cover to the drain pump on the bottom right of the front of the machine. Make sure that drain pump filter is tight. run the machine with that little drain access door open and see if you are leaking from there. If none of the above helps, and you are still getting water leaking from the door, miele has designed a new clamping ring for the door seal. Call them and make arrangements to have it replaced.
May 09, 2011 | Miele W 4800 Front Load Washer
Hi Door to my ariston a1600wd is leaking any ideas? I cn't afford to get a technician out, I am willing to try and fix it myself. Is is a seal or a door problem?
Is it definately the door? ive had the water leaking from the top drawer but looked like the door! Ive just cleaned the filter from the drum to the water pump and it was blocked, which makes me think the pump cant pump the water out quick enought on the spin cousing water to rise. U can get to the filter from the rear of the machine by taking the plastic cover off at the bottom and removing the black gater where the filter is inside
May 23, 2010 | Washing Machines
Loads of slimey grey water in filter drawer and horrible smells
First of all, you need to confirm if the leak is from the filter or the pump.
You can replace the filter seperately to the pump.
If you replace the filter, and it still leaks, then you are going to have replace the pump.
I would suggest that that you check and clean if needed the outlet pipe where the water enters the outside waste pipe.
Make sure that you do a boil wash periodically, to ensure that the drum and other internal parts are clean.
Clean the door seal and dry after each wash, it helps to leave the door slightly open
Please leave any comments that may have as regards to my suggestions.
Thankyou.
Nov 25, 2009 | Washing Machines
Top drawer works but bottom drawer shows code u3 and bottom drawer started leaking water before the u3 code showed up
U3 code generally relates to drain pump blocked. This could mean the water is not able to drain out. Leaking of water is not a good sign. Shows the vacuum seal is not working.
Clean the drawer door from inside and make sure the seal lining is sitting properly. Also the filter plate and the motor cavity needs cleaning. You will need to see the user guide on how to do this.
Nov 02, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Hi I have a Hotpoint Ultima 6kg WMA 76 washing machine - had for 6/7yrs. It has just started leaking water from the drawer when it changes from the wash cycle to the spin cycle...have given the drawer and...
You need to check the pump filter, and clean same.
Remove lower rear cover, locate and remove large black hose, remove and clean filter inside hose.
Please rate my solutioon.
Thanks.
Jul 26, 2009 | Washing Machines
Had the same problem. I unplugged the machine from the mains. pulled it out from the unit and removed the lid. checked the black rubber hose which leads from the drawer to the drum. it was full of water. i carefully squeezed the pipe and tried to clean it out with warm water to see if it was clogged. still leaking. i then Removed the green paddle on the inside and turned the drum to line up with the black rubber hose that leads from the drawer. I very carefully used a wire coat hanger to put through the gap in the drum left by the paddle. Moved left and right, oh look.... A sock! I manipulated it out of the gap, checked the hose. Water had gone. Put everything back together. No leak. All done in under an hour :-)
Mar 02, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Kenmore elite he3
ck for blockage between dispenser and where it comes into tub just above door have known dry detergent if used not disolve and cake up blocking inlet to tub also be sure drawer is clean and ck above drawer in washer and clean small holes
Jul 30, 2008 | Kenmore Elite 45986 Front Load Washer
Hotpoint Ultima WT965 - Water gushing out from door and soap drawer
in this case i would remove the pump (bottom, back, right hand side)
this is easy cleaned.... then remove dispenser and dropdown pipe and clean out clogs
Jul 29, 2008 | Hotpoint Ultima WF840 Front Load Washer /...
Hotpoint WMA44 Front Load Washer Logo
66 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
