Question about Danby Heating & Cooling
I was given a used Danby DPAC 7299 unit. It appeared very well maintained and in fact looked new. The only thing missing with it is the window exhaust kit and adapters. What solutions can you provide so I can get this working again. Thanks!
bestdarngood
  • 3037 Answers
SOURCE: In Dry and Air Condition
It is leaking water correct? Check your hose for clogs or a crack, follow it up and find where it is exactly coming from. If you need a part replaced, let me know and I can find you a replacement. If you have questions about accessing parts, let me know but the outer panel should be held together with simple screws.
Posted on Aug 13, 2008
david04928
  • 102 Answers
SOURCE: Danby dpac 7599 PC board fuse keeps blowing
Sounds like the Start capacitor might be shot.  I think  you need a professional to service it.
Posted on Mar 11, 2009
SOURCE: Actually it's a DPAC 13009. We need to extend the 2 air pipes 4 to 5 feet each to reach upper windows over patio doors to keep doors locked and secure. Does Danby provide air pipe extensions? Thanks.
No solution possible, given that the air ducts going up over the patio doors are quite an eyesore. This building is entirely fieldstone outside, so either the patio doors or windows above them are the only way to go in or out.
We will return the unit and get instead one that can be placed in the upper window and activated by remote control. Thanks.
Posted on May 19, 2009
  • 233 Answers
SOURCE: unit does not cool with the exhaust pipe connection covered
you need to get the exhaust air out if the structure or it will never work, you can use regular duct from a supply house as a temp fix
Posted on Jul 12, 2009
  • 68 Answers
SOURCE: I have a Danby DPAC 8020-5 air con unit. Air con
is there a flashing light on the unit? If so it will correspond to a needed repair. check your manual to match the number of flashes to the warning it is giving you.
Posted on Aug 03, 2009
We have 2 Danby air conditioners. One is a Danby Designer, Model DPAC 10060 and the other is a Danby Silhouette Model DPAC 12006. The venting hoses have broken to pieces and we need to buy new ones that...
You can purchase similar hoses at most home improvement center. Take a section of the old hose with you to get the right diameter and use the existing fittings to attach them to the unint and the window exhaust. What you may find is a better quality hose/duct, than what came with the unit. You may have to buy more than you need in length, but then you'll have some left over, if you ever have to replace it again.
Hope this helped. Good luck.
Jul 18, 2011 | Danby Heating & Cooling
I want to use my danby 7599 as a heater, do I need to have the exhaust tube vented to the outside on the back?
As per instructions on page 4 of the manual I printed out from the internet (which I cannot find again) :
The exhaust/window kit must be installed AT ALL TIMES WHEN THE UNIT IS OPERATING UNDER THE AIR CONDITIONING MODE.
There should be at least 11.8" clearance between the unit and any other objects or building structure. The unit should be installed on a level surface. The window kit does not have to be installed during operation of the remaining three modes. (Heating (DPAC 7599) /Dehumidifying/Fan)
Nov 21, 2010 | Danby DPAC7599 Air Conditioner
Replace window mount for dpac 120068
GO TO DANBY.COM AND GET FULL SPECS FROM THE MANUFACTURERS WEB SITE. IF YOU WANT TO KNOW IF YOUR MAKING A GOOD TRADE OFF, LOOK FOR BTU'S , WATTS, AMPS, STAR RATING PER YEAR ETC...IF YOU WANT TO REPLACE JUST THE WINDOW MOUNT, THEN GO TO DANBY.COM, OR LOOK IN YOUR OWNER'S MANUAL TO ORDER A REPLACEMENT MOUNT. IF YOU JUST NEED TO KNOW HOW TO RELACE THE MOUNT , THEN CONTACT SUPPORT AT DANBY.COM AND ORDER WHAT YOU NEED, A MANUAL , INSTALLATION INSTRUCTIONS, GUIDES, AND IF YOU ALREADY HAVE THESE MANUALS , THEN JUST READ THE MANUAL ON HOW TO INSTALL A MOUNT OR REINSTALL A NEW ONE.
Apr 13, 2010 | Danby Portable Air Conditioner
I have a Danby Mod.# DPAC 10061 portable A\C, the
This sounds like it could be a power supply problem. It may be very simple. I think I would first just unplug the unit, open it up, look for the PS connectors, and check/wiggle them to make sure there is good contact.
I went to the Danby's website:
https://www.danby.com/
And I was unable to find any service or owner's manuals in PDF format. The site does however have a locator for service shops. Good Luck!
da Marty
Dec 31, 2009 | Danby DPAC10061 Air Conditioner
Using the DPAC 8020 AIR Conditioner (Danby)
these portable units will usually have a knob reading from low to high. set it about half way and adjust as needed. half way is usually low 70's
Aug 03, 2009 | Danby DPAC8020 Air Conditioner
Jul 29, 2009 | Danby DPAC8020 Air Conditioner
May 16, 2009 | Danby DPAC12031 Air Conditioner
Jul 08, 2008 | LG Goldstar GWHD5000 wall/window Air...
Heating & Cooling Logo
336 people viewed this question
Top Danby Heating & Cooling Experts
Dan Webster
Dan Webster
Dennis Boxerman
mintvl
Level 1 Expert
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
