Question about Kitchen Appliances - Others
My Pelonis water dispenser has warm to hot water coming out the cold dispenser side. The model # YLRS0.7-5V/C-15. I also noticed when I turned the switch off in the rear for a few minutes. The fan in the back was making a funny sound because it wasn't moving. When it did start moving it was a slow process and the cooling light never went off.
4 Suggested Answers
SOURCE: Pelonis Hot & Cold Water Dispenser, water not cold
I too am having just room tempature water coming out of the cold
dispenser and I have had mine for 1 month.........
Posted on May 20, 2010
  • 28 Answers
SOURCE: pelonis model ylrso.7-5v the water does
cooling fan is not turning. it is a 12 volt fan and can only be bought from the manufacturer. the unit has been discontinued and parts are not available. if you could find the cooling fan, you would have to disassemble the entire unit to replace it and it takes about 3 hours. but it will work again for maybe 6-10 months before it goes out again. the average fan life is 8 months.
Posted on Dec 14, 2010
THROW IT IN THE TRASH MINE DOES THE SAME I HAVE RECIEPT BUT NO CONTACT INFORMATION FOR THE COMPANY FOR EXCHANGE OR REPAIR ITS JUST A PIECE OF GARBAGE
Posted on Jan 19, 2011
Hot water not dispensing
I ve glacier bay hot/ cold water dispenser - new product. Cold water is coming but no hot water. Water is not coming. What have I to do it is a week old machine.
Nov 20, 2013 | Vitapur Water Dispenser. Hot, Room and...
Admiral atw4675yq doesn't dispense warm water
Guest,
So I was lucky enough to buy the extended warranty with your same unit and when I noticed the same issue, I called the technician.
What he tells me is that this time of year, city water is too warm to require the addition of hot (71 degrees as read at the flow). Apparently to meet the Energy Star requirement, the temperatures were lowered from what they used to be.
He suggested that I wait until Dec/Jan until my cold water temp gets into the 60s and then listen for the hot to kick in intermittently.
From what I have read on the web from other customers of various other makes and models, this problem does not seem to be restricted to Admiral.
Hope that helps. Take care and have a good day.
Mar 14, 2013 | Admiral 3.4 cu. ft. Top Load Washer in...
I am getting warm water when we have selected colc/cold. I have checked the cold water intake and it works. In fact, if I shut the hot water intake, I only get cold water for the wash. What is causing...
If you turn off the hot water line, and you have cold water then suspect the water inlet valve. Unplug the unit and turn off the water to disconnect the water hoses. Pull out the washer and remove the back of the unit by the water hose inlet. The new valve is around $65.00 and is on connectors, which make it an easy fix.
Feb 22, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
ZFSB26DRESS water runs warm and freezer not staying cold.
It sounds like the condenser coils , the coils by the compressor , need cleaned badly . This (and the compressor cooling fan) , can cause the compressor to cut off on overload (due to the heat) , thereby not circulation refrigerant thru out the freezer coils .
The water line goes from inside the freezer door ( cold ) , under the refrig ( warm ) , then to the inside refrig water reservoir ( cold ) . After that , you should get cold water , until the reservoir is drained of cold water .
Nov 19, 2009 | GE Monogram Side by Side Refrigerator
Nov 03, 2009 | Kitchen Appliances - Others
The water in the in-door dispenser is coming out hot
If this freezer is like most, the water going to the dispenser is looped around many times in the refrigerator section near the back. Make sure that this is still true. It must have a lot of water cable in the refrigerator section so that the water has time to cool down before it goes out the dispensor. If for some reason the water tube is touching either the compressor motor or another hot part of the external refrigerator it could cause it to be to hot to cool down in time during its travel through the refrigerator as well as it will start to warm up the refrigerator section as well.
Also, I am sure you have tested, but make sure that you are plugged into the cold water supply and not the hot water supply. Check the water at the connector and see what the temp is at that point before it enters the refrigerator.
My guess is that the coil of water tubing that is usually in the back of the refrigerator section has been either lessend in length or the water entering the refrigerator is too hot to be cooled down in time before it reaches the dispenser.
hth
Feb 03, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Warm water out of water dispenser
If this is a new hook-up please be sure that your water line is connected to the cold plumbing on the house and not the hot.
IF it is on the hot the fridge is cooling it down to warm.
Please let me know if this helps you.
Jan 06, 2009 | Whirlpool Refrigerators
Whirlpool water dispenser
IS THE FRIDGE OMPARTMENT COLD ENOUGH AS THE TANK THAT HOLDS THE WATER IS LOCATED IN THE FRIDGE COMPARTMENT.PLEASE FEEL FREE TO ASK MORE ADVICE.MOHAMED
Jul 07, 2008 | Whirlpool ED2FHEXN Side by Side...
Kitchen Appliances - Others Logo
189 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
