Question about Dishwashers
Kitchenaid model kudso3ctblo, Type 577-0 Ser. FU3202943 When the dishwasher is finished, the soap tablet is still inside the dispenser & the door is still closed. We can open the door by hand & see that the soap has not dissolved. We found a tiny spring on the floor last week. Is there a metal spring in the dispenser? Could this have broken off & now keeps the door from opening?
  • 1314 Answers
SOURCE: Dishwasher soap dispenser won't open during cycle
both have a wax motor on them that needs to be replaced you just remove the panel and replace the wax motor is what its called
Posted on Feb 16, 2008
rylee_smith
  • 8619 Answers
SOURCE: Neff S5433 Dishwasher - Detergent tablet not dissolving
Hi!
Please run the machine without detergent for 2-3 washes. Also try using a little hot water. Also, don't used cleaner and softener together but add softener on the last rinse.
Posted on Feb 22, 2009
landsend
  • 1066 Answers
SOURCE: sears dishwasher soap dispenser door wont open-loose spring
with new parts ...yes.
Posted on Mar 13, 2009
SOURCE: Dishwasher soap dispenser sticks
Your soap is clotting because there isn't enough water being sprayed around inside.  The water spray washes the soap out of the dish, if all is working well.  My machine had the same problem.  I had sufficient water level, but the spray head wasn't spinning very well.  I found the end-most hole in the spray bar to be plugged.  It is the end hole that provides a jet that makes the head spin.  I cleaned a bunch of debris out of the hole and the mchine started working and cleaning like it was new.  That was quite an axccomplishment since the machine is 15 years old.
Posted on Jun 07, 2009
VtToolMan
  • 704 Answers
SOURCE: Dishwasher 3 in 1 detergent tablet not dissolving.
I believe that the instructions for using these 3-in-1 tablets is to place it in the open dish detergent cup, rather than in the closable compartment, since the tablet needs to get doused by a lot of water in oder to fully dissolve and be effective in getting the dishes clean.
Since the tablets are designed to dissolve more slowly, they are able to be used for the entire range of washing cycles. If it's a constant problem and you don's have an open detergent cup below or next to your closed detergent dispenser, just toss it into the bottom of the dishwasher instead.
The reason that the tablet isn't getting dissolved fully is because the door is preventing the tablet from dropping all the way out and the door is shielding the tablet from quite a bit of water spray.
Another option is to take a look at your owners manual for the dishwasher and see if they recommend these all-in-one tablets versus regular powered detergent and liquid rinse aid.
Hope that helps and best regards!
Posted on Jul 31, 2009
My dish washer soap does not dissolve, whether or not I put the tablet or the pillow into the soap dispenser. Is it the soap dispenser door? Would hard water buildup create low water pressure so the soap...
The most likely causes are the you are using a tablet in a gel coating but putting the tablets into the dispenser drawer when the dispencer drawer is damp, thus causing the tablet to stick inside the housing; or, if the dispenser drawer is releasing the tablet into the bottom of the cabinet then I would say you have a problem with your water heater. In which case you would need an enginner to come and replace the heater.
Hope this is of help
Jan 25, 2011 | Maytag MDB7100AWB Dishwasher
Kitchenaid dishwasher soap dispenser will not open during cleaning cycle
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Aug 24, 2010 | KitchenAid 24 in. KUDS01FLBL Built-in...
Soap dispenser will not open during was cycle.
Probably a faulty solenoid on the dispenser. Not replacable new dispenser needed
Jan 20, 2010 | Dishwashers
GE Nautilus 24" Built-in Dishwasher. Main Soap dispenser still has soap at end of cycle
Raise your hot water temperature to at least 140 degrees, try using FINISH tablets.
Jan 09, 2010 | GE Nautilus 24" Built-in Dishwasher
Soap does not dispense from cup.
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
heatman101
Sep 07, 2009 | KitchenAid KUDK03ITBK Built-in Dishwasher
Soap block not releasing while washing
I urge you to only use Electrosol or Cascade powder with your (or any) dishwasher. Most ultra-cheap powder will not clean effectivly. If the dispenser does not open with the powder inside, a service call is the next step.
If you reply, please tell me the Make and model of your dishwasher.Good Luck!
Mar 23, 2009 | LG Dishwashers
Soap dispensing problems on a kenmore dishwasher elite 577-0
is your soap door open when this happens if it is then make sure there's no water or other liquids in the dispenser from loading the washer one tablespoon of water in there will clump up the soap and it won't drop when it pops open
Dec 25, 2008 | Kenmore 24 in. 15252 / 15254 / 15259...
Dishwashers Logo
130 people viewed this question
Top Dishwashers Experts
