Question about Dyson DC25 All Floors Bagless Upright Vacuum
The cleaning brush does not rotate. If I remove it and turn the vacuum on, the black "gear" does not turn either.
  • 1,040 Answers
Sounds as if you need to replace the brush belt.
Jim
Posted on Sep 09, 2010
  • mark41750 Sep 09, 2010
    Called Dyson Service. They advised to hold down the brush button for 20 seconds. It worked.
Brushes will not move
Try to turn the brushes by hand. If they won't turn remove the brush assembly to see if it is seized, if it is, take it apart and clean the brushes and the gears. If it is nor seized the turbine might be seized.
Dec 26, 2013 | Hoover SteamVac Carpet/Upholstery Deep...
Brushes not rotating
If your unindentified vacuum cleaner is an upright, the belt may be stretched and unable to rotate the roller brush. The roller brush ends could be clogged with debris, preventing it from rotating freely. The solution is to disconnect your vacuum cleaner from the power and turn it upside down for inspection. It may be necessary to remove the roller brush and remove the end caps to clean inside. Replace any worn parts
May 07, 2013 | Vacuums
Brush roller not spinning. belt, spindle okay. roller taken out and cleaned, no thread. replaced but no dice. ???
Use only BISSELL Style 10 Replacement Belts (#32074) in your BISSELL PowerForce Bagless.
  1. Unplug cleaner from electrical outlet.
  2. With Rotating Floor Brush removed from vacuum cleaner, grasp old Drive Belt and remove from Motor Pulley. Discard old Drive Belt.
  3. Place new Drive Belt over Motor Pulley and stretch other end over Rotating Floor Brush in the space between the bristles.
  4. Place ends of Rotating Floor Brush down into slots on sides as shown.
  5. Turn Rotating Floor Brush by hand several times in the direction of Motor Pulley. If properly installed, Drive Belt will center itself on Rotating Brush.
  6. Reposition Brush Cover and snap back into place. Check to be sure all three latches are secured.
  7. When you turn on the vacuum, do you see the motor that spins the belt spinning at the bottom? If not, it sounds like you may have a burned out motor.
If suggested solutions do not correct the problem, call:
BISSELL Consumer Services 1-800-237-7691
Monday - Friday 8 a.m. - 10 p.m. ET
Saturday 9 a.m. - 8 p.m. ET
Jun 01, 2011 | Bissell 6594 PowerForce Bagless Upright...
Need to replace belt and cannot figure how to take it apart to get at the belt --- Took Screws off on the bottom but could not get to the belt
You have already removed the screws so lift the brush cover off. Then grasp rotating floor brush at both ends and lift. Clean strings,hair and other debris from rotating brush, paying close attention to the brush ends. Clean the debris from motor pulley and drive belt areas.Grasp old drive belt and remove from motor pulley. Place new drive belt over motor pulley and stretch other end over rotating floor brush in the space between the bristles. Place the ends of the rotating floor brush down into slots on the sides. Turn the rotating floor brush by hand several times in the direction of motor pulley. If installed properly, drive belt will center itself on rotating brush. Reposition brush cover and screw back into place. I hope that this helps you!
May 26, 2011 | Bissell 3591 CleanView Bagless Upright...
The beater brush wont spin because the brush roll is always in the off position. Moving the carpet/hard switch doesn't turn it on.
Hello :
Try this please :
Switch the carpet/bare floor dial back & forth 5 times, ending on carpet. Tilt the handle back as if to vacuum upright & lay the vacuum on its side so it is resting on the side opposite the carpet/bare floor dial. Turn the vacuum on.
Or Maybe the belt is broke. You will have to replace the belt before the roller can spin. You must have run over something in the carpeting like string or whatever to have it break. Happens all the time. Get several replacement belts to keep as spares while you're at it as nothing is worse then having to vacuum and no spare belts.
Try this also please :
Things You'll Need: Phillips head #2 screwdriver Replacement belt for your vacuum model Spray lubricant, such as silicone spray or teflon lube.
1: Unplug the vacuum. Never work on an electrical appliance when it is plugged into an electrical outlet.
2: Turn the vacuum over and locate the plastic or metal plate that covers the rotating brush. Remove this plate.
Note: This plate is typically attached by a small number of Phillips head screws or by levers that turn and lock the plate in place. In either case, removing this plate is a simple task.
3:Identify the vacuum's rotating brush. This brush should have a black rubber belt wrapped around it, and stretched around the metal shaft of an electrical motor mounted somewhere toward the back of the vacuum.
4:Verify that the brush will rotate freely. Examine both ends of the brush to ensure that no threads, string, yarn, etc. have become wrapped around the ends and thus inhibited a free rotation.If there is foreign debris, remove the brush by sliding it up, away from the bottom of the vacuum. Remove the debris
5:Lubricate both ends of the rotating brush with the spray lubricant. Replace the brush into the grooves which hold it in place
Replace the existing belt on the brush assembly, or replace a broken belt with a new vacuum belt.
6:Verify that the brushes now turn freely when back in place and that the motor shaft turns as the brush rotor turns.
PLEASE DON'T FORGET TO RATE !
Apr 22, 2010 | Hoover U6630-900 WindTunnel Bagless...
The brushes stopped turning. I cleaned the filter
Can you rotate the brushes manually (grab some of the yellow bristles and rotate the brushes). If they are not jammed, then your air fan drive is clogged or broken. Air must pass through the fan to spin the brushes... so confirm air flow by powering the machine on and feeling for decent air flow. Clear any obstructions that my restrict air flow....
Nov 24, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Brushes not turning
If your brushes are rotated by a black rubber belt, chances are that they belt has stretched out or has been worn and you need to replace that belt, also , check and remove any black rubber residue from the brushes and where the belt loops around. Also check for obstructions thru the hoses restricting air flow.
Aug 29, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Irobot roomba 570 brush not spinning
Unscrew and remove the side brush. There is probably a wad of hair and dirt underneath it that's keeping it from spinning. When it's clean, *snap* the brush back on, then screw it into place. If it still doesn't turn, you'll need a new module. Call support: 877-855-8593. Good luck.
Jul 02, 2009 | iRobot Roomba 570 Robotic Vacuum
Carpet setting not working
there is a belt in the nozzle that is driven by a small motor in turn will drive the roller when set to carpet. did you completely dis-assemble the nozzle? ie, to remove the roller and clean the endcaps? this would also show the belt. The gear on the motor wears very easily and could also be worn. I would change the nozzle or get a new Flair. new nozzles cost about $25-$30.
Jan 12, 2009 | Hoover S2220 Flair Bagless Upright Vacuum
DC 07 BRUSH BAR DOES NOT TURN BELT OK
Stand vacuum up and with it plugged in. Rotate knob between carpet and bare floor and back 5 times leaving it on carpet when finished. Rotate vacuum back from upright position and lay vacuum on the floor, rotating it onto its side. Turn vacuum on.
Jun 16, 2007 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC25 All Floors Bagless Upright Vacuum Logo
144 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
