Question about GE Refrigerators
Refrigeratorand freezer snow Models ZIR36NMRH & ZIF36NMLH
  • 101 Answers
Get a trained tech on this complicated job
Posted on Sep 10, 2010
My may tag fridge GS2126PADB seems to run fine but the freezer is not blowing cold air and fridge & freezer are warm.
There are more than reason: first check the fan in the upper part of the freezer (you have to unscrew 3 bolts of the cover),second check the freezer door sealing,third is to check that the cooling tubes inside the freezer are cold enough without heavy snow (you have to unscrew about 6 bolts of the cover),Heavy snow reduces cooling and it means that the timer is not working or the heater is not working.I hope to help you in reform
Jun 27, 2014 | Amana ARS266ZBS Side by Side Refrigerator
After cleaning the refrigerator still has a strong odor. It also grows mold.
put an open box of arm & hammer baking soda on the top shelf that absorbs the odor. The mold is a byproduct of the odor.
Jan 24, 2011 | GE Monogram ZIR36NMRH Refrigerator
Ice form at bottom of refrigerator ZIR36NMRH GE
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jun 02, 2010 | GE Monogram ZIR36NMRH Refrigerator
Snow in the freezer
If you are noticing that you often have "snow" if the freezer, this is an indication of one of two things. 1. Are you putting food into the freezer while it is still hot? This will cause condisation to form, and if it is done often enough, this will lead to "snow" 2. The other reason that this might happen, and the more likely of the two is that the door is either not being closed completely, or the door seal is leaking allowing room air to enter and condense in the freezer. Hope this helps.
Apr 01, 2010 | Freezers
Kenmore Coldspot model 106 - Snowing in freezer!
its not defrosting. check heater operations. bimetal near heater. check defrost timer
Feb 08, 2010 | Refrigerators
Temperature on both freezer and refrigerator running at 2 and 41 what should I check I lower the temp and it goes back up
Sir, To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant. I suggest you to contact the service authority.
Thanks for contacting Fixya.
Sep 08, 2009 | GE Monogram ZIR36NMRH Refrigerator
Freezer suddenly is creating mounds of freezer "fluff"
That snow is the condensate build up on the evaporator coils behind the rear panel of your freezer. Normally the freezer will go into defrost about every 10 hours and this snow will melt and drain out the defrost condensate line below the evaporator and go to a pan under your refrigerator and return back to the air inside your home. I believe your freezer is missing the defrost cycle either because the controls for the defrost are defective or the defrost heater and defrost thermostat is defective. I would be watching for an increase in refrigerator temperatures soon, due to loss of defrost. We will need to unplug and examine the evaporator coils behind the rear wall of the freezer. If frozen or covered with snow then defrost with a hair dryer and lets check the defrost heater and all its related components. Sea Breeze
Aug 20, 2009 | KitchenAid KSRS25ILSS Side by Side...
Excessive frost build up inside the freezer
Your problem is not a recall it is the fan and how many items you have in your freezer. Is it stuffed pretty full?
Jun 01, 2009 | GE PFS22SISSS Stainless Steel French Door...
Freezer has layer of frost on back wall - refrigerator not working
Defrost circuit problem, the snow means that your freezer coil is not being automatically defrosted. This could be a problem with the defrost heaters or defrost timer. Also in the newer models a module
controls this operation. Call for service. Removing ice or snow from the back wall is not the solution. The coil behind the back wall is also frozen and no air is circulating.
May 15, 2008 | Maytag 22.1 cu. ft. Bottom Freezer...
Refrigerators Logo
53 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
