I have the 42" Tower - love it. I noticed it has been decreasing its air flow and last night it stopped. The indicator lights work fine, but no air is coming out. Any ideas? ~Dennis
    Master:
    Sergeant:
  • 449 Answers
Check to see if it has a filter and if so clean it
Posted on Sep 09, 2010
2001 Monte Carlo battery goes dead over night
check for loose / dirty ground wires and points
indicates a voltage circuit being broken and the ECM is loosing voltage to work
Jun 27, 2017 | 2001 Chevrolet Monte Carlo
Want to know when and how to replace water filter on a ge side by side refrig
The water filter status light or indicator, present on some models, will help you know when to change your water filter. The light, or indicator, is located either on the temperature control panel in the refrigerator compartment or on the dispenser control panel on the freezer door.
The indicator will be one of two styles.
If the indicator is a light or series of lights, the light will change from green to yellow. This tells you that it is almost time to change the filter. It is recommended that you replace the filter when the status light changes to red or when water flow to your water dispenser or ice maker noticeably decreases.
If the indicator resembles a stack of bars, the bar height will decrease and the status display will change from "Good" to "Order." This tells you that it is almost time to change the filter. Replace the water filter cartridge when the water filter status display changes to "Replace" or when water flow to your water dispenser or ice maker noticeably decreases.
If a filter status light/indicator is not present, the filter should be changed at least once every 6 months. Your filter may need to be replaced more frequently depending on your usage and water quality.
If the water flow to the water dispenser or ice maker noticeably decreases before 6 months have passed, you may need to replace the water filter cartridge more often. Decreased water flow is a sign that the filter is clogged and needs to be replaced.
If the filter is clogged and you are not able to immediately replace it, remove the filter so the water system is in bypass mode. With the filter removed, the water system will continue to operate, bypassing the filter, and the clogged filter will not cause slow water dispensing or low ice production. However, in order to have filtered water, you will need to install a new filter.
The filter status display will help you know when to change your
water filter. When the display reads 10%, order a new filter. It is
recommended that you replace the filter when the display reads 10% OR when water flow to your water dispenser or ice maker decreases.
The filter should be replaced at least every 6 months depending on your water quality and usage.
Step 2
Press the eject button to release the filter from the base grille.
Step 3
Pull the filter straight out.
Step 4
Turn the cap counterclockwise to remove it from the filter. IMPORTANT: Do not discard the cap. It is part of your refrigerator. Keep the cap to use with the replacement filter.
Step 5
Align the ridge on the cap with the arrow on the new filter and
turn the cap until it snaps into place.
Step 6
Remove the protective covers from the O-rings. Be sure the O-rings are still in place after the covers are removed.
Step 7
Push the filter into the base grille. The eject button will pop back out when the filter is fully engaged.
Step 8
Flush the water system. Use a sturdy cup or glass. Depress and hold the
water dispenser lever for 5 seconds, then release it for 5 seconds. Repeat this process until water begins to flow. Once water begins to flow, continue depressing and releasing the dispenser lever. Hold down for 5 seconds and then release for 5 seconds. Do this on/off process for about 2 minutes. This will flush air from the filter and water dispensing
Hope this helpout in changing the water filter......
Aug 10, 2010 | GE Refrigerators
Headlights wont work, just suddenly stopped!
recheck them fuses sometimes they dont look blown but they are if not there must be a loose connection somewhere i know you have checked but retry
Jul 28, 2010 | 2005 Suzuki SV 650 S
RS Focus registered yesterday 19th March Keyless entry but remote fobs do not lock or unlock car. The car was driven back yesterday hav ing now covered 114 miles alarm was going off last night but thats...
should not be using fob buttons for entry or locking for emergency only .if keyless entry walk up to car with fob do not press any buttons see if door opens then walk away from car with fob about 20m then go back to car without fob and see if door locked if so all working fine .indicators will not flash if the above dont work take back to main dealer for diagnostics keys may need to be reprogrammed
Mar 20, 2010 | 2009 Ford Focus
Power Issue 42" plasma flat HDTV Pixel Plus
you ip board is bad go t0 this site partstore.com typ in the modle of tv and buy it . works like brand new .trust mr it did and saved a lot
Apr 07, 2009 | Samsung SPN4235 42 in. Plasma HDTV
Dishwasher worked fine last night, this morning it is not working
In some supply systems, there is a safety valve ( commonly referred to as a shuttle valve) that has a small ball bearing that blocks the water from flowing if a water line bursts.. This is supposed to be a safety feature to prevent flooding but can be an annoyance if that ball moves and blocks water flow from coming in.
That, or your water inlet valve may be the prime suspects for this problem..
Hope this helps,
Regards,
Rick
Dec 13, 2008 | Bosch Dishwashers
1993 Varvan, Not Turn Signals, No Heater Blower, And AIr Bag Light Now On
boy, that sound like a major circuit to cause all that. either a main fuse under the hood or a main circuit wiring harness connector. there are no unfused circuits that could indicate a short unless there has been past fuse blowing problems
Sep 28, 2008 | 1993 Dodge Caravan
Heating & Cooling Logo
14 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
