Question about Amana ABC2037DES Stainless Steel Bottom Freezer Refrigerator
I have an amana abc2037des. Freezer won't defrost. I replaced the defrost heater and the thermostat defrost kit. Still won't defrost. Now what? I am thinking the control board is bad? thank you, Chris
  • cbenjamin155 Sep 09, 2010
    Forgot to mention that the temp is set at 3. Also, the unit NEVER turns off, runs constantly. Drives me absolutely nuts.
    Thanks,
    Chris
  • cbenjamin155 Sep 10, 2010
    Thank you for the suggestions. I'll check for what you suggested. I had to defrost the unit yesterday, again, it has been running continuously since, with the frost building up again. Gotta admit, will never buy an Amana again as this is not the only issue I have had with it. Sadly it is made by Maytag, so I guess I won't be buying a Maytag either. What happened to refriges lasting 30 years? Oh yeah, profits, I forgot. My dad was a repairman for 35 yrs w/ GE. He said they just don't make them like they used to. Sad.
    Thanks again,
    Chris
  • Amana Master
  • 17,970 Answers
In both cases it was the defrost timer, an electric clock switch that turns the defrost on & off. On these, you can check this by manually advancing the timer until it goes into defrost. On my ~8 year old Amana, the timer can be advanced at a recessed screwdriver-slotted red knob on the ceiling of the frig portion just behind the panel with the temp controls. If yours has this, advance the knob & see if the defrost turns on (you can tell because the switch clicks and if the compressor is running at the time, it shuts off).
Easy and cheap to replace, if that's the problem. Also if the thing's iced up you can defrost it a couple times this way and get air moving again until you can replace the part.
Other guess could not thermostat. That doesn't control defrost. First check for power on the defrost heater. If none then check deforst timer for power in. If present then change defrost timer. That is where power comes from to the heater. If power then bad heater.
Thermostat controls the compressor. When the temp inside goes up the thermostat turns on the compressor to cool the fridge or freezer. Here's the diagram. It looks like if the thermostat is "open", the heater won't run...
Also, in thius links, can check info...
- applianceaid.com/defrost_cycle.html
- applianceaid.com/frig_notcold.html#ff
Hope helps.
Posted on Sep 10, 2010
    President:
  • 1,796 Answers
Hi!!
If your fan is working fine and the temp. is set about 1/3 of the range ie, if your dial goes from 1-9, set it on 3.
The fault could be the control board, ice obstructing the air duct or a small refrigerant leak. When the refrigerant pressure is low, the evaporator coil also freezes up.
Good Luck!!
Posted on Sep 09, 2010
  • Rene J Solis Sep 10, 2010
    One last thing to check is the relay/start capacitor, it may be defective and keeps unit running all the time. If the capacitor is OK, the only thing left that can keep the unit working at all times is the control board, one or more of its components is defective. REPLACE IT.
  • Rene J Solis Sep 11, 2010
    Yes, you're absolutely right, they do not make them the way they used to. Thanks for using FixYa.
Amana ssd21sw stop cooling freezer side frost in rear wall any sugestions
Defrost cycling problem which will affect cooling the fridge compartment by struck the freezer fan's function.To solve defrost problem:
First, locate the defrost timer which may hidden behindcorners of the fridge at the back bottom, in some models located in the ceilingof the fresh food section or behind the cold control cover. Once you locate thedefrost timer, slowly turn the screw in the middle of the defrost timer withstraight screwdriver until the fridge shuts off. Now it's in defrost. If thedefrost heater(s) starts, replace the defrost timer and defrost thermostat. Ifthe heater(s) does not start, unplug wire cord to check ohm test for continuityof heater. If continuity is there, plug cord wire which gives power 120volts(check specification) to heater. If heater no starts, bypass defrost thermostatby join the 2 wires in the defrost thermostat. If the heater now comes on,replace the defrost timer and defrost thermostat. If the heater itself is bad,replace it. Thanks and hope helpful.
Feb 01, 2011 | Amana 22.6 cu. ft. Side-By-Side...
Freezer is cold, but cold air is not circulating in refrigerator
Check freezer fan is working.If ice formed over freezer fan by working. It's a common problem due to irregular defrosting. Keep freezer setting temp at 5 degree. And check defrost timer, thermostat,heater are working properly.
Turn timer with small tip screw driver to shut off fridge. If not shut off, replace timer. Turn counter clockwise defrost thermostat. If fridge not shuts off replace defrost thermostat.Check heater by join the 2 wires in the defrost thermostat. And after 1 minute, unplug power and keep your arm on heater. If it's warm heater is o.k. Otherwise, replace heater.
Once heater starts work at regular interval controlled by thermostat and timer, defrost will be good and effective cooling will also be in fridge compartment.
Jan 24, 2011 | Amana ABB2524DE Bottom Freezer...
Top half of both fridge and freezer appears to have stopped working.
Your defrost heater or defrost thermostat may be bad. Test defrost heating element for continuity. If heater is good, replace the defrost thermostat. In most cases, replacing both is advisable.
Dec 17, 2010 | Amana ASD2622HRQ Side by Side Refrigerator
Freezer part of my amana side by side is cold but not freezing
DEFROST PROBLEM
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Part 1541 on this diagram is your timer. It's under the front behind the kick panel. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=21463&diagram_id=646025#d646025
Apr 24, 2010 | Amana SXD524VW Side by Side Refrigerator
I have an Amana fridge with bottom freezer that keeps freezing up. I replaced the defrost timer and that fixed it for about two weeks and now it's freezing up again. I think the defrost timer has broke...
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Oct 16, 2009 | Amana 22.6 cu. ft. Side-By-Side...
My Amana bottom freezer frig is freezing up. thawed it, took 3
If you need help finding your model number see here> http://www.appliancepartspros.com/modelnumber_locator.aspx
To locate your timer, motherboard, control or adaptive defrost control , enter your model number and search for the part or post back on Fixya.
http://www.searspartsdirect.com/partsdirect/index.action?psid=26129238&sid=PSx20071217x00001a
Oct 01, 2009 | Amana ABB1927DE Bottom Freezer...
Maytag (Amana) ABC2037DES Refrigerator not cooling
Hello TraciK,
It is likely you could fix it YOURSELF
for less than the cost of your ruined food...
(we can do this).
Refrigerators... while divinely simple... are self
sufficient (noble) appliances that are designed to
take care of themselves. Clean them, love them & they
will serve faithfully for DECADES...
ELSE... comment me back (I do love'em).
I have a '94 Amana.. Counter depth, STAINLESS,
water/ice door service...
(the only appliance that survived our "kitchen refresh")
Likewise mine also DOES NOT have a DEFROST TIMER...
but an electronic PC (printed circuit) CONTROL BOARD...
Mine (of course) is MANUFACTURER DISCONTINUED
so count yourself "LUCKY" ...
NOT only are your parts available... but
reasonably priced... (see below).
If you "refrigerator" has been UNPLUGGED for
three days... (and I am right) it should run NICELY
for a week or 10 days... before FAILING on the "REFRIGERATOR" side...
(frosting up... blocking AIR FLOW).
You are most likely suffering from a DEFROST
circuit FAILURE.
Not unlike the simple TIMER the DEFROST circuit
operates 2 or 3 times each day...
(about 45 minutes).
As the entire interior of your "FRIG" is soft
plastic... going above 55 to 60 degrees Fahrenheit
could/would case serious damage to your
REFRIGERATOR'S soft plastic interior...
Ergo... your defrost heater is under the
control of a DEFROST THERMOSTAT... designed
to go "OPEN" (no connect) at temperatures
above 55 degrees (room temp (chilly))...
This is ENOUGH to melt frost but not affect your
food... nor cause damage to the soft PLASTIC
REFRIGERATOR'S interior.
To test for DEFROST issues on a single EVAPORATOR
refrigerator (yours)... you need only look through the vents of one that has been running a COUPLE of WEEKS.
You will likely see an EXCESSIVE build-up of FROST.
/If you look into your defrost pan... it s likely quite DRY...
Testing with a clean, fresh piece of typing paper ..
would QUICKLY leave water marks on a fresh [piece
of paper...
(Same as testing for a leaky valve under your sink).
((a single drop will QUICKLY mark the paper)).
There are only 3 parts to YOUR defrost circuit:
- Defrost PC Board
- Defrost Thermostat
- Evaporator Heater element
The only other (REMOTE) possibility would be the
AIR-FLOW is being blocked by a bad "DAMPER"
(also has video instructions (see below)).
Video
http://www.appliancepartspros.com/whirlpool-board-jazz-wpw10503278-ap6022400.html#autoplay
Part: PC Board (WPW10503278)
http://www.appliancepartspros.com/01-cabinet-back-parts-for-amana-abc2037des.html
Damper Control (part number WP67003903)
http://www.appliancepartspros.com/whirlpool-control-damper-wp67003903-ap6010385.html
Happy hunting!
Carnac the Magnificent
Parts
PartSelect Appliance Parts and Repair Help
More parts
Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Mar 05, 2017 | Refrigerators
Amana side by freezer fan frozen will not run
Fan not operating could be caused by the excess frost buildup in the freezer coil. Defrost problems are related to a failure of the timer, heater, or defrost thermostat. Locate the timer and rotate the clutch head screw clockwise until you hear one audible click. That puts the system into defrost mode. If the system restarts after 18-22 minutes your problem is in the heater circuit. Heater and defrost thermostat is located behind the back wall of the freezer section.
Jun 29, 2008 | Amana ACD2232HR Side by Side Refrigerator
Refridgerator not cool enough.
sounds like the probable cause is defrost heater. get someone to test the element.
May 27, 2007 | Amana ABB1927DE Bottom Freezer...
Amana ABC2037DES Stainless Steel Bottom Freezer Refrigerator Logo
176 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
