Question about Bosch Exxcel WFO 2264 Front Load Washer
Bosch excel 1200 express any program runs to 1 minute and keeps washing. Will drain and spin when selected manualy is it main board?
  • Bosch Master
  • 12,061 Answers
Yes I would expect so, it indeed sounds like a main Controller fault, especially as you can manually select the functions, and it actually works, . BUT to make sure you need to contact Bosch, and ask them for a service manual, now in the manual, there are troubleshooting steps to perform.I have searched for on online but have been unable to find any.
If you do not wish to DIY, then i recommend that you call Bosch service and arrange a visit, now when they arrive, ask them for a "Quote" before allowing any work to proceed, this way you can make an informed decision on what to do.
Posted on Sep 10, 2010
  • Duncan Harris Dec 13, 2011
    Hi, I have a similar issue. Did you get a solution?
BOSCH WASHING MACHINE CLASSIXX6 1200 EXPRESS
Possible that the main controller board is a suspect, please also check the following link: Control panel
Jun 27, 2012 | Bosch Washing Machines
I have a Bosch clasixx 1200 s express washing machine, When I select a program the machine buzzes but the cycle doesn't begin. The drain cycle works and the spin works. if i select freshen and rinse the...
Bosch clasixx 1200 This video will show you How to find the fault on a Washing Machine that Won't Drain or empty the water away on Bosch
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Feb 26, 2011 | Bosch Classixx WFL 2066 Front Load Washer
Machine selects a program fills up with water then does nothing, but still makes usual clicking noises. If drain is selected machine indicates 12 mins as normal starts to drain then shows 1 min and does...
This sounds like a bad main control board. Try unplugging it for 10 minutes then replug an try again. If you get the same results replace the main controller.
Jun 16, 2010 | Bosch Exxcel WFX 3267 Front Load Washer
Bosch exxcel 1200 express spinning slowly
I would suggest that you remove the motor, and check the brushes for wear.
If they are less than 3 or 4mm long, then they need to be replaced.
Hope this helps.
Jan 07, 2010 | Bosch Exxcel WFO 2465 Front Load Washer
My Bosch classic 1200 express washing machine wont drain or spin
Possibly a blocked filter or pump.
Ths filter should be at the bottom right front of washer, sometimes behind a removeable cover at the bottom of washer.
To clean it, unscrew anti-clockwise, remove and clean.
Dec 09, 2009 | Bosch Washing Machines
My bosch classixx 6, 1200 express washing machine keeps displayin
Bosch classixx 1200 express washing machine won't drain
Mar 29, 2009 | Bosch Washing Machines
Bosch Classixx 1200 Express wont spin!!!! HELP
Make sure that all the water has drained from the washer, if it has a filter, remove and clean, it is located behind a removable plastic panel at the front of the m/c, if it still does not spin, suggest you remove motor and check the brushes for wear, this is often the reason it won't spin, but will wash o/k.
Plz rate my solution.
Thanks
Dec 22, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Bosch Exxcel 1200 Express Washing Machine spin not working
I had the same problem- machiine not spinning and a few days later not turning at all. Display would go from 11min to 1min.
I did 2 things - 1) changed the brushes on the motor- cost £7.50 .
2) whilst working under the machine disconnected pipe from drum to pump and emptied it- found 2 coins in the bellows.
Nov 09, 2008 | Bosch Washing Machines
Bosch classixx6 1200 express
my classixx6 1200 express is flashing f21? what is wrong with it?
May 16, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Bosch Excel 1200 wahsing machine, when trying to activate spin, it shows the normal 10 minutes, but then goes straight from 8 mins to 1 min and items arent properly spun
bosch exxel 1200 washng machine
has error message 04 and wont drain or spin
what does this mean?
can you help?
have lost instruction book
Mar 27, 2008 | Washing Machines
Bosch Exxcel WFO 2264 Front Load Washer Logo
132 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
