Question about Dryers
When dyer turned on makes a loud whriling noise and then shuts off
  • Dryers Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Sounds like the blower is full of dirt of the blower wheel came apart...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 12, 2010
My dyer is working it's just making a really horrible loud noise what could it be?
possibly worn out Support wheels.
Worn out Idler off the motor
Jun 03, 2015 | Dryers
Ge profile is making loud squikei noise how to fix it
is it a scraping squeak or a squealing noise?
Jun 09, 2012 | GE Dryers
When operating dryer makes LOUD thumping noise. Is this fixable?
this sounds like rotator wheel(s) are broken. It is some what an easy fix. The drum dyer needs to rotate those wheels. Usually you need two.
Jan 05, 2011 | Asko T741 Dryers
The dyer still works but it makes a loud noise and doesnt produce the same amount of heat as before
LOUD CLUNKING NOISE WHEN THE DRUM TURNS? IF SO, YOUR ROLLER BEARING IS BAD. AS FOR THE LESS HEAT, YOU NEED TO CHECK YOUR VENT, MAKE SURE IT'S CLEARED. IF SO, YOU HAVE BAD COILS
TIMOTHY DO 714-334-1998
Aug 04, 2010 | Frigidaire Dryers
Drum not turning-very loud sound coming frm dryer when turned on
There could be multiple problems with you whirlpool dyer depending on the type of noise you are hearing. If the noise is a low grumble or loud buzzing sound this could indicate a bad motor. Which could explain you not hearing the drum turning. If however you hear a grating or grinding type noise but the drum is turning, this could indicate that something is rubbing or has become jammed inside the blower fan that circulates the air. if this is the case it too may have to be replaced. Also the drum can sometime come off the drum support rollers at the back of the dryer, but this is very uncommon, and only happens if they are very worn or broken. This can easily be diagnosed by a technician and if the motor is fine, will cost little to repair.Hope this helps.
Thanks
Nov 07, 2009 | Whirlpool LER4634J Electric Dryer
Fisher & Paykel top load electric dyer makes loud squeaky sound
to be honest i doubt that a bad belt would make a squicky noise and for a high class dryer like that i would suggest just call repairman  they are very complex
Jun 08, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Kenmore 970 C81062 10 Electric Dyer WILL NOT
It sounds like the drum may be stuck. Turn the dryer on with the door open, just keep the button pushed. Then try to turn the drum by hand, and see if it will start to turn.
Jun 04, 2009 | Dryers
Loud noise
could be that one of the bearings that the tub rolls on is wearing out and needs to be replaced or the belt pulley running to the motor is worn and needs to be replaced. Hope this helps
Mar 10, 2009 | Maytag PYE2300AY Electric Dryer
Dryers Logo
42 people viewed this question
Top Dryers Experts
