Question about Korg Mr1 Digital Mobile Recorder
Dobry den. Vlastnim korg mr1000,som snim maximalne spokojny.Dokupil so si novy korg mr1,no nahravky z neho von do aparatury zneju uz na ucho ako 4-5 kopia, su basovejsie a vysky su menej vyrazne.Prosim Vas o nazor,moze byt vysledny zvuk rozdielny medzi tymito vyrobkami alebo mal by byt stejny pri dodrzani stejneho postupu.Nakolko moj zaujem o mr1 pretrvava za odpoved Vam vopred dakujem. s pozdravom Jaroslav Rak.
Korg m50 gm sound not plying on my keyboard
try resetting it to its factory setting,
Sep 05, 2016 | Korg Music
Repairing Korg D-3200 Digital Recording Studio
If you have electronic expeerience, take it to a repair shop. You can cause more damage okiong around if you don't know what you're doing.
Past that, contact Korg customer service for the schematic and parts list. The part should be available from Korg directly of from Mouser
http://www.korg.com/us/support/contact
Korg Parts Parts Is Parts Guitar Parts Amplifier Parts Korg Keyboard Parts
Mouser Electronics Electronic Components Distributor
Korg Full Compass
Jul 15, 2016 | Korg D3200 Digital Studio
How to reset pa 50
The manual should the factory re-initialization procedure. If not contact Korg customer support
Dec 10, 2014 | Korg Pa50 Professional Arranger Keyboard...
Wont save over 1 song and always turns off
Try asking here:http://www.korguksupport.co.uk/page.cfm?pageid=370. Hope this helps.
Aug 23, 2009 | Korg Mr1 Digital Mobile Recorder
I can't figure out how to change my metronome (A Korg Metronome MA-30) to 2/4 instead of 4/4
Turn on metronome. Make sure that metronome is not operating. If it is operating then press metronome switch to stop it. Now press up (^) or down switch. This will change the time signature. When u get appropriate time signature, press Metronome switch once. It will start operating with selected time signature...
Mar 17, 2009 | Korg Ma30
MR-1 cannot be mounted via USB
I cannot connect my Korg MR1 to my computer MSI wind with Windows XP via USB port. The computer does not see the hard disk
of the Korg MR1
Jan 19, 2009 | Korg Mr1 Digital Mobile Recorder
Korg mr-1
While this is Mac-related, the information regarding the reset button is helpful and seemingly little-known. This comes from a Korg rep, by the way:
Did you first manually eject the drive from the Mac before disconnecting it by either moving the drive into the trash or using the Eject option from the Finder menu? If you try to exit USB mode without ejecting the drive on the computer first and then disconnecting the cable, this can cause the unit to lock up. Additionally, you’ll notice there is a tiny hole below the volume controls on the side of the unit. You can use a paperclip to push in a button within this hole to manually reset the recorder however this is only recommended in extreme circumstances. Look forward to hearing from you.
-Matt
Sep 02, 2008 | Korg Mr1 Digital Mobile Recorder
Korg Mr1 Digital Mobile Recorder Logo
21 people viewed this question
Top Korg Music Experts
Michial Gueffroy
Are you a Korg Music Expert? Answer questions, earn points and help others
