Question about Cycling
If the axle on the wheel is bent slightly, would this effect the truness of the wheel?
    Scholar:
  • 128 Answers
Hi!
It won't affect the wheel itself but it will change the performance of the wheel cycle and decreases instability of riding the bike. Also keeping a bent axle on your wheels will affect the gasoline consumption (applicable on bike using gasoline) otherwise if you are using a bike without a motor to run the wheels the effect on the rider is on the stamina and energy consumption.
Should you have any other questions just please leave a message.
Cheers~
Posted on Sep 09, 2010
Cause of rough ride at 23,000 miles?
Sort of depends on what you mean by "rough ride". It could be a bent wheel, bad shock, broken shock, bad bushing, wheel out of balance, bad CV joint, bad wheel bearing, more...
Any competent mechanic should be able to ride in it and diagnose the problem. Unlikely the car's computer will tell anything useful, and, unfortunately, most "mechanics" today are simply "parts replacers".
May 05, 2015 | Ford Cars & Trucks
Whats causing my rear tire on my 2004 chevy trailblazer wobbles
Check for a bent wheel by fitting another wheel if it is ok the rim will be bent if its the same check for bent axle.
Aug 18, 2014 | Cars & Trucks
Manta 4 channel rc quad-copter will not calibrate properly
Sounds like the axle is slightly bent and warped from the initial crash. Try replacing the axle and this should solve your problem.
Apr 19, 2014 | Protocol Manta 4-Channel Radio-Controlled...
FRONT END VIBRATION
The dealer is not going to replace something if they can not prove to the company the part is defective. The company won't pay the warranty claim.
A bent axle was my next guess. A garage could find out by using the same dial indicator used to check for a bent rim.
The dial gauge is placed against the shaft and the wheel is turned, if the axle is bent the dial will move.
I don't know what Road Forced balanced means, but most balancing machines duplicate road speed of about 30MPH. So a tire or wheel can balance ok on a machine but still have a vibration at speeds above 30 or 40mph. The easiest way to make sure is move the front tires to the back and see if the vibration travels too.
If you are describing the problem correctly, it almost has to be in the transmission, the axles, or the wheels. There is a slight chance a strut or strut mount could be faulty and allowing a small bounce to be amplified.
Sep 16, 2012 | 2006 Chevrolet Uplander
I have a new trike that may have ome shipping damage (bought at flea market) The rear axel appears to be bent. severe wheel wooble. is there some adjustment in those set screw type bolts in the center of...
The set screws in the center of the axle are there to keep the axle centered in the frame. Only the right wheel is powered which also means only the right wheel brakes when operating the rear brake. This is because the rear wheels must be able to spin independently when turning because the outside wheel will move faster. Unfortunately no one builds differentials at this price.
If you have wheel wobble you need to determine if the axle is bent or the wheel is not true. Prop up the rear of the bike on a stand and remove the problematic wheel. Manually pedal the bike and check the axle as it spins. If the axle is wobbling then it is bent and will need to be replaced. If it spins true then the wheel is the culprit.
The axle is relatively inexpensive and can be ordered through a Schwinn dealer. Any bike shop should be able to true a wheel for around $15-$20.
Sep 23, 2010 | Schwinn Meridian Adult 26-Inch 3-Wheel...
Car has a grinding sound and a slight vibtation
Not likely the caliper , could be wheel bearing , bent axle , bent rim , steering or suspension part way worn out.
Apr 18, 2010 | 1995 Pontiac Bonneville
The truck shakes in the rear at 55 to 65 mph...Had repair work done after a collision behind the cab broke the driver's side rear leaf spring...The spring was replaced and had 4 wheel alignment done, new...
well i bet the tyers are all out of ballance,,,check that first if there all ok have a look at the drive shafts and the prop shaft one may be bent?
Nov 18, 2009 | Refrigerators
Hi I have the Schwinn M3 Jog Stroller and it has a slight pull to the right. Can you tell me how to fix it?
Is the each wheel on straight and tight?
If so, spin each wheel with the tire facing you and see if you notice any wobbling or warping effect. It's possible that either the axle of the wheel is bent or the spoke/rim is not true.
If the wheels have spoke nipples that can be adjusted, you may need to take it to a bicycle shop to see if they can true the wheel or otherwise it'll need to be replaced unfortunately.
Nov 07, 2009 | InSTEP Schwinn Titanium M3 Jogger Stroller
Left rear wheel wobbles
put on your spare doughnut tire and see if it's bent to .. if it is then you bent the axle not the rim.
Jan 06, 2009 | 1993 Nissan Altima
Cycling Logo
64 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
