Question about Acer Aspire One PC Notebook
After I bought acer for the first time it was installing programs into itself. I denied three programs assuming that they were crank. They were C:ProgramData\fiyulake\fiyulake.dll, C:\ProgramData\nisuhaki\nisuhaki.dll and C:\ProgramData\welincla\welincla.dll. Can you help me?
  • 480 Answers
Actually they are malware or malicious software. There are a lot of option that you can do about removing or deleting it from your computer.
ving the infection out of your computer, you have to subscribe to a security software on your computer for future protection.
You can try to download 'malwarebytes' from this site
www.filehippo.com / and after installing it ang updating the definitions, run a full system scan. and after removing the infection. dont use the computer yet until you are subscribed to a security program. ok
Posted on Sep 09, 2010
Avital 5303 kills engine while driving 1998 honda civic
you check to see if the engine was hot or something like if the water level in the radiator was down the sensors in the security system would pick it up
Jan 27, 2014 | 5303L 2Way LCD Remote Start Security...
Aps57c can't learn tachometer
Yes, the seven flashes indicate that the system did not learn tach. Do you have the tach wire connected at the coil or an injector? If so, turn the ignition on, press and release the programming button three times, turn the ignition off. Press and hold the programming button, start the vehicle. Continue to hold the programming button. The parking light should be flashing at this time. after about 15 seconds, release the programming button, the parkings will come solid and then go off. Turn the vehicle off, the tach is now programmed. Test the system.
If the tach wire is not connected, you can program the system for tachless/voltage.
Turn the ignition on, press and release the programming button three times, turn the ignition off. Turn the ignition on,off, on, then press the programming button 5 times ( the parking lights will flash five times, press the lock button on the remote three times. This will put your setting at voltage. The setting for crank time is still set at averging so, you will have to start the vehicle four(4) times with the key so the remote starter can average the crank time.
Oct 03, 2012 | Remote Start APS57N
I accidently switched off my mains before the system had completely shut down. As a result I'm unable to boot up, tried several times from all angles.\r\n\r\nGetting a message to the effect: The...
Acer Process 4/12 eRecovery Management indicates that the recovery process never finished - you will have to run it all over again.
As for MS Office , it came as a one month trial in your laptop - if you had it for more than that then you bought it. In that case the activation key must still be in your possession, just insert it when asked.
In the absolute worst case (the reinstall never finishes, no matter what you try) you will have to get a separate recovery disk from
https://secure.tx.acer.com/RCDB/Main.aspx?brand=acer
and use it to reinstall.
Silverlight is an separate program that can be downloaded at any time by you from
http://www.microsoft.com/getsilverlight/Get-Started/Install/Default.aspx
Aug 21, 2011 | Acer Aspire M3641 Dual Core E2200 PC...
I installed the Windows 7 Home Premium upgrade (store bought) and now my Acer Aspire 5735 gets blue screens, shuts itself down, and random programs get the "**** has stopped working" message.
you shouldn't of installed it because if you would of ran the windows 7 compatibility thing that is on the disc, it would say that your computer is incompatible. You should buy another copy of windows xp and install that.
Jun 16, 2010 | Acer Aspire 5735 Notebook
How do you use your webcam on an acer aspire 5517?
go into start menu.click all programs then go to acer chrystal eye webcam. i just found mine on the acer apire 5517 so im assuming all the acers with webcams have pretty much the same folder.
Jan 14, 2010 | Acer Aspire 3610 Notebook
When i try to install a critical update it was denied access by 7 zip. even after uninstalling 7 zip and installing winzip i still get the same response when trying to install updates 7 zip access denied....
Install Winrar, Here is the link
http://www.rarlab.com/rar/wrar391.exe
if you double click the file,the files will be extracted in the temp folder,so after installing winrar,right click on the file and select extract here. and try to install the update now,
Sometime when you extract files and it contains Malware or Trojan,Anti-Virus which support real time scan just block the files and the access denied message is displayed.
Scan the extracted files before installing so that you know it's Virus free.
Sometimes,even if you have administrator right,sometimes due to malware infection, you are denied access to some system hidden giles like folder under Local settings.
Dec 30, 2009 | Compaq Computers & Internet
Bluetooth driver (bluetooth hands-free audio) wont install, access denied
me too have that problem, i updated me XP SP2 to SP3 and failed to install bluetooth, then i removed SP3 and re install bluetooth, it worked fine, as my comment, reinstall ur OS to windows XP SP2 and try.
May 03, 2009 | Computers & Internet
Pop-up acer edata security management each time open laptop
I would go to the program file itself (it might be on the desktop, might be in the start menu, or might be in a folder in C:\Program Files) open up the acer e-manager and look for an option for settings.  You should be able to un-select options for security notifications and automatic updates.  I do not have the program on this computer, but I have seen it before on other laptops.  Most all programs like that will let you change the settings.  The security updates are not entirely necessary, so long as you have an anti-virus program installed on your computer.  So just turn off the auto-updates and the notifications through the program itself.
Mar 26, 2009 | Acer Aspire One PC Notebook
Acer crystal eye webcam not working
hi
i have an acer aspire 5720, my crystal eye web-cam doesn't work either, well most of the time, it says a program stopped it from working, i have moved all photos into a new documents folder as suggested, but still doesn't want to work, any help would be much appreciated.
thanx
Mar 04, 2008 | Computers & Internet
Acer Aspire One  PC Notebook Logo
32 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
