Question about Kenmore Elite Oasis 27052 Top Load Washer
I am getting a F1 code Serial # CT3570155 Model # 110.27052600
  • 15,935 Answers
The F1 error code on this washer indicates a Primary Control Board failure.
It is likely that the machine control board will need to be replaced to correct this problem.
The part number for the machine control board is undetermineable because you have not provided me with the exact model # of your washer.
The procedure for replacing the machine control board is provided HERE
LINK: http://media.fotki.com/1_p,wfgstgtftbtkrrdxgtqsskgwtqkq,vi/gfsfgfsgqxgfqtqtgwf/1/1303472/5961857/image55806img-or.gif
NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem.
A pinched or twisted air hose can cause this fault code.
When you open the console, check the air hose connected to the pressure switch on the machine control board.
If it is pinched or crimped, I recommend rerouting the hose to resolve this problem.
This may fix your problem without replacing the control board.
NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself.
As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 16, 2010
Spinning cycle noise and F1 code
I wrote the comment about the jet engine noise and the F1 code on my WTW6600W Cabrio washer. Today I called Whirlpool Service at 800-253-1301 and have your model and serial numbers ready. I mentioned the F1 problem first and then explained about the noise. She did a little research and informed me that the F1 problem and the bearings problem are connected and she arranged their service people to repair both at no charge to us! It's so worth the call, we almost bought a new washer. HUGE SURPRISE!!
Sep 08, 2012 | Whirlpool Cabrio Washing Machines
Have problem with Maytag CWE 9000 the beeper keeps going off even after you press cancel Code is F1, any idea
likely the problem is a bad control board, aka a clock/timer. Usually F1 error codes do refer to main board or main control error in which you would have to replace the control. You can also try shutting off the breaker for 7 minutes which sometimes does make the control reset but this only works maybe 10 percent of the time due to the F1 error code. If you need the part number of the control message me back your full model number and serial number as well.
Thank you
Rick
Nov 19, 2011 | Ovens
F1 appears on my oasis washer what is f1?
F1 is a base code you need you put unit in to service mode to find out the fault code, to put it in service mode press 2 rinse on for 4 sec. off 4 sec. on 4 sec. off 4 sec. on for sec. and that code will tell you what is wrong if it is a f-68 code it will need a new main control. sears will replaced it if you call them with a model and serial # for free in most cases
Sep 27, 2010 | Kenmore Oasis HE 27062 Top Load Washer
Code F1 Appears
It is the RPS sensor, cover by whirlpool. Get your model number and serial number ready and call the 800 number on the machine, tell them you heard it here that it is a recall so you don't get the run around. The sensor is located on the stater motor and comes with a new harness and cost you nothing.
May 15, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My washer was supposed to go in to spin cycle and alarmed with I believe F1. Is there anything I can do to fix this problem
There is a recall for the Cabrio for having the "F1" error(I had mine fixed by whirpool for free). Sounds like you are getting the F1 error code. If you have not had the washer repaired under the warranty program then you should give Whirlpool a call and get it repaired under warranty. When you call them say that you are getting the "F1" error code and have read on the internet that there is a recall. Have your model number,serial number and date of purchase available. They will send someone out to inspect the washer and repair if they have the control board in stock(they had to order mine and it took 2 days for it to arrive). I also located the phone number you will need to call for service...1-800-253-1301
Jan 22, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
F1 fault is flashing and machine is stoping
Code F1 means the central electrical control unit, i.e. the onboard computer, has fatally failed
Widespread problem, lots of machines have had this issue. I think there is a recall on this machine. Check it out-
Whirlpool Cust Svc. 1-866-698-2538 Have the model & serial off the back handy
Dec 29, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Only runs 2 mins then shows F and i clear it try to restart it it will start to fill then shows sd
Dec 05, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
F1 error code on Kenmore Oasis He
Moister can get in between the contacts,is it in a high moister environment? Try using a hair dryer on the panel to dry it out.Also unplug it to reset.
Hope this helped.Let me know by rating me
For more help go to live chat.
lenwest
Jan 31, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Oven beeping f1 and f3
Im having the same problem I have model arg71000 serial 9809185133 Hook me up with the solution please
Dec 22, 2007 | Kitchen Ranges
Kenmore Elite Oasis 27052 Top Load Washer Logo
51 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
