Question about Whirlpool Calypso GVW9959K Top Load Washer
What does LS on the display and dont end the cycle?
  • 15,935 Answers
The control should flash this error code if it cannot detect the lid switch opening and closing properly.
This error code may also be used if there is a disagreement between the motor and machine controllers on the state of the lid switch.
The control should not allow the unit to run in this condition. This code will also appear if the user presses the START key while the lid is open.
Open the lid or press STOP/CANCEL to clear the display
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 21, 2010
Zanussi dishwasher beeps once and end of cycle light flashes
Most likely your dishwasher finds fault.
Appliances without a display will show the alarms by a number of flashes of the LED "end of cycle".
For example: one flash = i10, two flashes = i20
..........and so on
So, count how many times LED "end of cycle" flashes and you will know the error code.
Dado
Aug 24, 2014 | Zanussi Dishwashers
Samsung front loading dryer the display shows rotating circle rather than time remaining
Rotating blinking lights in the display is probably an indication that the Wrinkle Prevent option has been selected. Wrinkle Prevent will continue to tumble the dryer without heat after the cycle has ended to help prevent wrinkles from setting in. When this option is selected by pressing the Wrinkle Prevent button on the control panel, the display will count down the estimated cycle time; when the cycle ends, the display will show lights blinking in a circular (or actually rectangular) motion.
To deactivate, simply press the Wrinkle Prevent button again so the light is not illuminated.
Jul 28, 2014 | Washing Machines
Monitor vga connection hdmi
You can check these:
1. Connection: Make sure that both ends are connected properly,
2. Monitor: Most newer monitor has 3 options: VGA or DVI or Automatic. Test the "Automatic" and "VGA" options.
3. Cycle your display option using your laptop keyboard (Alt + F4). Please tap the F4 several times (to change the option to Mirror, Laptop Display only, External Monitor only)
Dec 25, 2013 | Packard Bell iMedia Computers & Internet
Rear end leaking and making noise in 2000 lincoln ls
Bad News, your rear end needs rebuilt.
Jun 21, 2013 | 2000 Lincoln LS
1993 grand cherokee how do you fix the overhead console
sometimes because of oxidation or cold solder problems those overhead displays cause troubles. they dont show at all or they show wrong info etc. you need to remove it and you need to resolder every soldering point own by own. this can save your unit. i did mine, it worked.
if it displays nothing there is a chance of being at end or its life cycle( i mean the blue colored display itself not the whole unit), if so try to find a replacement on ebay.
Nov 20, 2011 | 1993 Jeep Grand Cherokee
Windows wont boot up on my new motherboard 865gvm2-ls
Test your power supply unit if the PSU units fans not working its faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive boot up
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
one bad lead will end with a computer error computer error a computer needs its connections continue its cycle and have an end to function hope this helps
Apr 09, 2011 | MSI 865GVM2-LS Motherboard
My 2004 lincoln ls air conditioner is blowing hot air. The ac filter light is on and so is the check engine light. Please help. What could be the problem? Does the system just need to be charged?
Your issues can not be answered easily or definitively, as the LS is very complex and all electronic.
I would need the stored codes,that set the check light (MIL Light)
You can cycle the right dash display to ACFilter and Reset,with the top row of buttons,in center of dash. There is no sensor on the Cabin Filter. All the dash displays, are just reminders,you can set any way you want, % wise.
Possible issues--Fuses
-- Coolant control valve
--DATC module
You will need a really good Technician,not a general mechanic, to diagnose your problem
You need to put a professional scanner on it, to start any diagnostic work
May 19, 2010 | 2004 Lincoln LS
Whirlpool calypso washer
Code LS=Lid Switch. I had the same problem and found that if you pressed down firmly on the lid when closing I would not get the LS code. An uneven load will sometimes cause enough vibration to the lid to stop the washer and display the LS code again. Just lift lid and press down firmly again and start. Eventually I will open it up and adjust the switch.
Mar 08, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
46 people viewed this question
Dan Webster
Dan Webster
Sal De
