Question about Linksys Wireless-G WRT54GL Router
Changed internet provider and my wireless computer & printer will not work - Linksys fixed laptop but not printer
SOURCE: configure WRT300N wireless Router to connect internet using PPPoE
Often the nets and subnets are NOT the same.. ie The Fixed connection often uses 192.168.0.1, 192.168.1.1, however sometimes the wifi is setup 10.1.1.1, or 10.0.0.1 etc, have you checked this? Esentially tho ya router is an "Acess Point" and ya Lappy etc is ya "Client" the links below has a lot of tutorials to help have a look. http://portforward.com/routers.htm http://portforward.com/guides.htm
Posted on Aug 05, 2007
  • 53 Answers
SOURCE: Need to add Linksys WRT54G-TM wireless router with Linksys SPA 2102 phone adapter
your SPA2102-R seems to have one ethernet connection and one internet connection.
your WRT54G-TM seems to have one internet connection and 4 ethernet connections.
What you are trying to achive is; plug a ethernet cable into the ethernet connection on your SPA2102-R then plug the other end into the internet port of the WRT54G-TM
hope this helps, I have assumed that you intend to use a DSL broadband supplier not ADSL.
if you are changing service from DSL to ADSL then your WRT54G-TM needs to be first in line configured and working. then plug the internet port from the SPA2102-R into any of the WRT54G-TM ethernet ports.
Posted on Nov 06, 2008
rcsnet
  • 15 Answers
SOURCE: Linksys WRT54G wireless router not compatible with Aztech modem?
Darvin, gotta love your ISP. Never fear......
if it isn't too much of a problem (knowing you have wireless setup done already), then do a factory reset on your router ** remember to copy the WEP Key if you have, or recall the PASS PHRASE so you won't have to reset all wireless devices ** Reset is located on back, you need a ball point pen to reach the reset switch.
Reset process: unplug, take ballpoint pen & insert into reset switch & plug unit back in. Sometimes tricky, but you should notice green light goes to yellow/orange upon resetting.
RESET or NOT - you want the Linksys set for ::
Connection Type - AUTOMATIC (for automatic discovery)
Router IP Address - 192.168.2.1
DCHP - ON, Addresses - 192.168.2.100 and allow 5-50 users
(for security, assign the number of DESKTOP + WIRELESS expected users +1, this way you don't get overrun without knowlege)
Take the cable from Aztech ETHERNET OUT to WAN on Linksys. (usually BLUE) (??) not 100% sure as I have the little silver pocket edition of the same Router. - power cycle (turn both DSL modem & Linksys off for 20 seconds. turn on DSL Modem, wait till it's about as ready as possible, turn on Linksys, should only take 20-30 seconds to power up & recognize.
VERIFY SETTINGS: access router - 192.168.2.1, goto STATUS. you should see IP Addressing, SubNet, DNS1 & DNS2 settings. If you do not, then you have no internet connection.
ALTERNATIVE,
Setup Linksys Router with COnnection Type: PPoE, you will need your ISP assigned ID & Password. Follow all other instructions properly.
If you still have problems, please contact me at 906-495-1707 or via Yahoo IM junodr@yahoo.com or through this website.
once
Posted on Jan 13, 2009
alfi819
  • 65 Answers
SOURCE: Need settings for Huawei HG510 with Linksys wireless WRT54G
You could reset you router to default settings.
On the back of you router, you will find a little hole
using a pen, press that reset button.
Posted on Mar 27, 2009
  • 145 Answers
SOURCE: I have Time Warner Cable for internet and Vontage
If you purchased a Linksys wireless roter then you shoul not need the switch anymore-
Try going directly from your time warner modem into the Interner/WAN port on the router and then plug your desktop computer and the vontage phone system into 2 of the ports on the router. After everything is hooked up you will probably need to power cycle for it all to work correctly.
Please power cycle in this order:
Reboot modem - then Router- then Vontage phone system.
Hope this helps
Posted on Apr 09, 2009
How to connect my Linksys router with my wi tribe modem?? my laptop pick up the wireless signal and can connect,,it says "connected" but when you open a page it says either "invalid server...
The Linksys Wireless router is fine, but your latop is not configured for DHCP (Dynamic Host Configuration Protocol). The computer is connected to the router at layer 2, whereas HTTP (Hypertext Transfer Protocol), sits
atop the TCP/IP (Transmission Control Protocol/Internet Protocol) layer, and seems to be trying to
query the ISP's (Internet Service Provider) network for a nameserver (via DNS (Dynamic Name Service) protocol) that doesn't exist on the ISP's network. Configuring the laptop for DHCP and specifying no nameserver will fix this (the ISP's network will dynamically assign a DNS).
Its also possible (though a remote possibility) that your Linksys wifi router may be configured to disallow TCP/IP virtual circuits to/from your computer's IP address - but this is a really advanced
capability of your Linksys wifi router - few know this capability even exists.
Connecting multiple wifi devices to the Linksys router should be no problem, just configure them all to interact with the router using DHCP.
Jul 04, 2011 | Linksys WRH54G Wireless Router
I have a Linksys wireless wrt54g router. Service provider is cable and lost signal for a couple days. Had to reset modem & router and everything worked fine for 3 days. On the 4th day, 2 out of 3...
Hi, the gateway is your cable modem, so if that 3rd laptop can't find the gateway, it can't make its way out onto the Internet. Do you know if you're using DHCP (to automatically assign IP addresses to your computers)? If you're not sure, you probably are, and all you'd need to do to fix the problem is to open a command prompt on that laptop with the problem (in Windows XP, go to Start > All Programs > Accessories > Command Prompt; in Windows Vista or 7 you can just type "command prompt" into the search bar) and at the command line, type "ipconfig /release" and then, once the command completes (which might take a minute) type "ipconfig /renew". This will force your laptop to re-acquire its IP address, complete with subnet mask and default gateway address.
An alternate way to do it is to right click on your wireless icon in the system notification area of the taskbar and select Repair. It will accomplish the same thing as above, but Windows will do the legwork for you.
Hopefully that should fix your problem. If not, leave a comment and we'll go from there. Good luck!
Jan 17, 2011 | Linksys Wireless-G WRT54G Router
So I really need help. I have a Linksys (WRT54GS) wireless router upstairs connected to the internet, printers, etc. and a Netgear (WGT624) downstairs connected to a desktop, xbox and laptop. I don't want...
More information is needed.
Is the 'WAN' port on the Netgear router connected to anything?
(cable-modem? DSL-modem?)
How many friends will come over at the same time?
How many 'LAN' ports are on the Linksys? How many ports are "free" ?
How many 'LAN' ports are on the Netgaear? How many ports are "free" ?
How many "spare" Ethernet cables do you have?
Is your goal to provide computer-to-computer connectivity,
or are you just trying to provide Internet access for everybody?
If you are "downstairs", is the wireless signal from the "upstairs" router strong-enough to provide wireless coverage "downstairs"?
If you are "upstairs", is the wireless signal from the "downstairs" router strong-enough to provide wireless coverage "upstairs"?
Jan 04, 2010 | NetGear WGT624 Wireless Router
Linksys rouder suddenly stoped alowing other computers net access
I would recommend upgrading the router firmware, if you have not done this already.
Download the firmware file from the Linksys website:
http://www.linksysbycisco.com/US/en/support/
Typically, the upgrade is done by pointing your web browser at the IP address of the Linksys router. Linksys should provide specific instructions at the site above.
Nov 01, 2009 | Linksys Wireless-G Broadband Router
Laptops stopped connecting wireless
how about to reset your router and setup it the proper address by your internet provider..
laptops only connect to the router automatically if you enable it reconnect and detect its network without manually connect internet, this procedure can see in your wireless properties by enabling it.
And also ask your internet provider if theres a problem also with their internet connection.
Jul 18, 2009 | Linksys WRT160N Wireless Router
HP Laptop does not connect to internet unless directly
Hello dstoller,
You description is very confusing to sort exactly what is or isn't happening.Let me try to sort out what you have:
You have a Laptop
You have a Desktop
Desktop has a printer attached
You have a DSL modem with a wireless router
Laptop via ethernet: Good
Laptop via wireless: Not Good?
Desktop via wireless: Good
Not sure exactly what you are needing help with...
- Vincent
Still not sure what
Nov 22, 2008 | 2wire (1000-000005-002) 802.11g/b Wireless...
Drivers 4 Linksys BEFW11S4 ver. 4
Your wired network adapter will talk to a wired router without a driver for the router on your computer. Your wireless adapter likewise will talk to your wireless router without a driver for the wireless router on your computer. Your wired and wireless adapters however do require drivers and the wireless adapter can require configuration. Please provide the manufacturer and model of your computer so I can learn about your wireless adapter and we can work to get it connected to the router.
Do you currently have your router connected to your internet service providers connection and do you have another wired or wireless computer successfully using this device to access the internet?
Dec 09, 2007 | Linksys BEFW11S4 Wireless-B Broadband...
Configure WRT300N wireless Router to connect internet using PPPoE
Aug 05, 2007 | Linksys WRT300N Wireless Router
Linksys Wireless-G WRT54GL Router Logo
79 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
