Question about Lexmark E250dn Laser Printer
My printer won't let me double side while printing. When I go into the options, it isn't possible to click on the double siding, it's greyed out.
  • Official Brand Answer
  • 3,344 Answers
Perhaps this article on How to Enable the Duplex Option in the Driver Settings (Software) might help. Just click on this link: http://bit.ly/9cTKs1. If you need further assistance, don't hesitate to contact Lexmark technical support. Thank you for choosing Lexmark.
Posted on Sep 10, 2010
Double side printing HP LaserJet M1120 MFP
Hi Franziska,
HP has not yet released Driver software for your MAC LION however there is a solution for this.
In order to print 2 sided ( duplex printing ) you need to install drivers and it is possible by doing Apple Update.
The link below will give you more details information of how to install the drivers.
MAC LION Driver Update
Once you have done the Update and installed the drivers, you will find the Printer name in Printers list.
Click on Printer Utility and under Layout you will find options to choose 2 sided printing
Regards,
Sean
Apr 19, 2013 | HP LaserJet M1120 MFP All-In-One Printer
Interact s605 printing upside down
You can change the settings under printing preferences, just follow the steps below:
1 With a document open, click File > Print.
2 Click Properties, Preferences, Options, or Setup.
3 Navigate to:
Advanced tab > 2-Sided Printing area > select On
Note: To use the settings defined in the printer, select Use Printer Settings.
4 Select either the Side Flip or Top Flip option. Side Flip is the setting most often used.
5 Click OK to close any printer software dialogs.
6 Click OK or Print.
To return to single-sided printing, navigate to:
Advanced tab > 2-Sided Printing area > select Off
Sep 01, 2012 | Lexmark Interact S605 Wireless All-in-One...
Bizhub 211 double sided printing inactive
It was the same problem. To enable drop down menu open "Device Option" tab where you will see list:
Duplex Non Instaled
Tray2 Not Installed
Tray3 Not Installed
Just double click on "Duplex Not Installed" and it will changes on "Installed" and Double sides drop down menu become active.
Jan 20, 2012 | Konica Minolta bizhub Office Equipment &...
How to set a MG5220 printer to do 2-sided copies?
The Canon MG5220 has a built-in auto duplexer and can print 2-sided documents. On a Mac, click print, and in the print dialog box select Duplex Printing & Margins (drop down options below Printer and Presets). Check the Duplex Priting box, and selected the Stapling side. Then click Print. That's it!!
Feb 05, 2011 | Canon PIXMA iP90v Printer
How to get a Canon MG5220 printer to print 2-sided copies
If you have a Canon MG5220 you certainly can print two-sided. I have one and I print two=sided pages. When you bring up your print menu underneath "Orientation" is a small window that likely says "layout". Click that window and you will have various options to choose from; color matching, paper handling, cover page, quality media color options. borderless printing and duplex printing & margin. Choose Duplex & Margin. Once you've clicked that you'll see a check box for duplex printing, click that box. You have other options for for reduced or normal printing (your choice) and then if you're stapling there's options for the side you'd prefer but the point is once you've checked off that box for duplex printing you're set to go.
Feb 05, 2011 | Canon imageCLASS MF7480 Laser Printer
How can I do double-sided printing with my Canon MP460?
Hi there!You printer does not have an automatic duplex(double-sided printing)so you have to make a manual double-sided printing.When you start to print something , in the widow of the printer click on the preferences and look for the option "Print on both sides" or "Manual double-sided printing".When you start the printing the printer will print page page 1,3,5,7..... on the one side of the paper.After the printer finish you have to take the papers and put them back in the printer with the other side of the paper.Then the printer will start print page2,4,6,8,.....If you need any other help please replay!Tghaky for using Fixya!!
Dec 18, 2010 | Canon PIXMA MP460 All-In-One InkJet...
How to print on double side of a paper?
Open your printer settings by right clicking on the printer and choosing properties. (easier way is to print something and click on advanced options). Checkmark, double side print and hit okay.
Apr 02, 2010 | HP LaserJet 2200dn Printer
Double sided printing
Firstly ensure that the duplex unit is installed by going to start - Settings- Printers and faxes.
Then right click your printer and select properties. Select the last tab at the end of the properties screen which reads "Option"
Then under the options where you see the Duplex unit option select "Installed" from the drop down menu.Click Apply and OK
Alternately you can insert the ip address of the printer and select the gather option information...
Now for double-sided/duplex printing
1. Open the document you want to print eg: MS Word
2. Click on the "file" menu select "Print"
3. Then Select the printer from the drop down menu
4. Click on the "properties" box next to the printer you selected
5. In the first screen on the "Setup" tab find the Binding option and select at the Print type "DOUBLE SIDED"
6. Click apply and this will enable double sided printing.
7. you can leave the binding position on "Auto"
Hope this helps
Regards
Rene Fernandes
Feb 18, 2009 | Konica Minolta bizhub C250 All-In-One...
Printer prints double sided only even though set for single
This is cause duplex printing option is enabled in the driver. If you have win XP, go to control panel and then printers & faxes.
Right click on your LJ P2015 printer driver and click on properties.
Click on the tab 'Advanced' and then click Printing Defaults.
Remove the check mark for 'Print on both sides' under the 'Finishing' tab.
Click Ok and Ok again.
Nov 21, 2008 | HP LaserJet P2015dn Printer
Lost reverse side printing option
Yepperz
The double sided printing option relies on Status monitor working correctly. If information cannot travel from the printer to the computer, the option will be greyed out.
Make sure you have a direct connection to the computer without any hubs. If that doesn't work, try the following.
1. Open START, SETTINGS, CONTROL PANEL, PRINTERS
2. Right click on your Epson printer name, and click CANCEL ALL DOCUMENTS.
3. Confirm cancelling all documents.
4. Right click on the Printer again, and select DELETE.
1) Click on START, SETTINGS and CONTROL PANEL.
2) Double click on the SYSTEM folder and select the Device Manager tab.
3) Click on the "+" for "Universal Serial Bus Controller"
4) Right click on "USB Printing Support" and select "Uninstall" and confirm it
5) Disconnect the USB cable and reconnect it.
Try Printing
Sep 07, 2007 | Epson Stylus R265 InkJet Photo Printer
Lexmark E250dn Laser Printer Logo
162 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
