Question about HP Office Equipment & Supplies
My printer scanner does not work anymore, I get a message that says computer cannot detect scanner. Everything is connected the way it was when it was working. Please help!
  • 47 Answers
Take your HP software that came with the printer and innstaler this again after you have done this then restart your computer again.
txexixs
Posted on Sep 09, 2010
I cannot scan anymore and the message is saying that the scanner is not connected, however the printer is working so it must be connected.
Sounds like the twain drivers for the Epson scanner part of the unit are not installed. When that happens the computer won't see a scanner, just the printer. Try re-installing the Epson software that came with the unit.
Apr 13, 2015 | Epson Office Equipment & Supplies
I haven't used my scanner for some time and now it won't work. A message says can't communicate with scanner, check scanner, may be not connected. we took it with us this winter but have checked all the...
Hello.
Either the driver is corrupted or the scanner component is faulty.
Reinstall the driver for your device. If still a problem and the other functions work, but not the scanner, the scanner part is faulty.
Hope this helps.
Apr 10, 2010 | Canon PIXMA MX310 All-In-One Printer
Printer works scanner does not
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Scanner:
  • Unplug the Scanner cable from the computer.
  • Unistall the Scanner drivers from Device manager and also unistall the all the Scanner appications
  • after installing drivers and software it will ask you to connect the Scanner.
  • then you can connect the Scanner and and try to Scan.
Hope this help. Please Rate My Response! Thanks!
Aug 20, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Problems with the canon
try to unplug while the printer is on..in order to reset everything..^_^
May 14, 2009 | Canon PIXMA MX310 All-In-One Printer
I dont know how to connect the MFC-230C printer to my Dell Computer...HELP!
Use the USB Cable supplied with your printer then connect it to your computer....your computer will automatically detect the new hardware then will ask if you have the install CD of your scanner, insert then install.....
Let me know if everything is going fine....
Apr 12, 2009 | Brother MFC-230c Printer
Scanner not detected
first shut down ur pc disconnect the power cable and usb cable from scanner put the power cable of scanner and see if light is coming if itis coming connect the usb cable check in device manager if it is detected also check the adapter voltages and try replacing usb cable if required
Feb 24, 2009 | Lexmark X2250 All-In-One InkJet Printer
My computer says the scanner is not hooked up to the computer
Hi mil0153, go to this web site: http://welcome.hp.com/country/us/en/welcome.html#Support
Make sure your printer is connected to the computer & the printer is turned on.
In Step 1. Click the emty circle next to, "Download drivers and software (and firmware)".
In Step 2, click "Start Detection >>" button. Allow HP to install some software. HP will scan your system & find your printer. HP will install the correct updated software & or tell you what is needed for the LaserJet 2840 to function correctly. Follow all on screen instructions.
Good luck mil0153!
Thank you for using fixya
Merry xMiss!
Mike
Dec 17, 2008 | Office Equipment & Supplies
IHAVE A PRINTER SCANNER LEXMARK X1270 1200SERIES AN IT WANT HOOK UP TO MY COMPUTER PROPERLY
when you try to hook up your printer in your comuputer is the printer detected? where you able to install the driver for your printer? was the printer configuration setting specially type of connection set to usb if the printer is connected to usb.
Jun 20, 2008 | Lexmark Office Equipment & Supplies
All in One Scanner/Printer problems
Go to this link and type "cannot communicate with scanner" in the search box. Click Search. Then select the "ERROR: Cannot communicate with scanner" link. You will see several things to try to correct your problem. Usually, this error shows up if there is another USB device connected which prevents the computer from "seeing" the scanner, even though it can print without problem. So do try to disconnect any other USB device (except mouse or keyboard) and reboot the system.
May 20, 2008 | Canon PIXMA MP160 All-In-One InkJet...
I can't get the scanner to work on my mp160. The printer and copier work fine.
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
prirweto-i-13
Feb 25, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Seeker5211
Seeker5211
