Question about Dryers
I have a whirlpool dryer,model #LGR8648PWO. I have a replacement ignitor but I don't know how to remove the dryer cover to get to the old one. Any help Any tips for replacing the old one would be welcome too...thanks
  • 4 more comments
  • woodsideny Sep 10, 2010
    thank you. i followed your instructions and the ignitor is now working (hank you) but the dryer is still not getting hot. When i restarted it, the clothes briefly got hot and then it got cold again or should i say it stopped drying again. what do you think?
    ru there
    I have a whirlpool model #lgr8648pwo,serial # ms0804177 and it does not get hot. the ignitor has been replaced but it still does not heat up.
    thanks but you must be looking at an old question. i was able to replace the ignitor but the dryer is still not getting hot.....?
    where is the thermostat and sensor and how could i tell if they are working properly. how do i tell if the gas vavle is working properly. when i look through the small hole at the bottom of the front plate i can see the ignitor lighting up but no flame. is there supposed to be a flame like an oven...not sure?
    that is helpful thank you...do you recommend replacing the gas valve
  • 11,896 Answers
Posted on Sep 10, 2010
  • 1 more comment
  • Nate Stansfield
    Nate Stansfield Sep 10, 2010
    Have you tested or replaced the thermostat check and tested the temp sensor? How good is the coupling and gas valve? Is allowing gas to the ignitor and pilot? Is the internal probe of the pilot cleaned?
  • Nate Stansfield
    This is supposed to have a flame like an oven. If there is not flame, then either the spring on the gas valve is worn and valve is not staying open, or the internal probe of the pilot is dirty and not keep a certain temperature therefore not lighting the pilot. You can see parts and diagrams and manuals at partselect .com or repairclinic . com
  • Nate Stansfield
    If you are not getting any sign of gas, can't hear it, smell it, feel it, then Yes I would. If you are getting gas, then check or replace the pilot
  • 5,911 Answers
To access the burner assembly on your dryer, follow these steps:
1. UNPLUG the dryer and remove the lint screen.
2. Remove the two screws that were under the lint screen and lift the top panel.
3. Unplug the door switch connector plug and any ground wire that may be installed on the casing.
4. Locate the two screws that hold the front panel in place. There should be one screw on each side in the cabinet interior.
5. With the door shut, lean against the front panel and remove the two screws that hold it in place. Once the screws are removed, grasp the front panel at the top center and lift straight up to remove.
You should now have complete access to the dryer interior.
6. Remove the dryer drum. Release the belt tension, by pushing the idler pulley (tensioner) to the right (away from the belt) and remove the belt from around the motor drive pulley. Leave the belt wrapped around the drum and use it as a handle to lift the entire durm out of the dryer cabinet.
You should noe haver full access to the burner assembly and other interior components. NOTE: With the drum removed, this is a good time to do a good general inspection and cleaning of the dryer cabinet.
Once you have completed your igniter installation, reinstall the drum and reassemble the dryer as follows:
1. With the ribbed side facing the drum surface, leave the belt wrapped around the drum and lift. Lower it in place inside the dryer cabinet.
2. Lower the front of the drum slightly and place the back groove of the drum on the drum support rollers first.
3. Slowly rotate the drum until you feel both drum support rollers engage into the rear groove of the drum.
4. Lift the the front of the drum up so that the rear felt seal seats against the cabinet back.
5. Hold the drum in place with your shoulder and reinstall the drive belt around the belt tensioner and drive motor pulley.
6. Loop the drive belt around the dryer drum with the groove side facing the drum. (Try to line the belt up with the wear marks already on the drum from the previous belt).
7. With the tensioner in your left hand, insert the clip end of the idler pulley into the grooves on the dryer bottom casing with the idler wheel pointing to your left. (The grooves are directly in front of the drive motor.)
8. While holding the tensioner in place, insert the belt UNDER the wheel with your right hand and push the wheel to the RIGHT while pulling the belt over the drive motor pulley.
If this does not explain it well enough, you can also verify by going to repairclinic.com. Click on the Repair Help link and look for the "Dryer Belt Diagrams" link under the Special Features section on the next page. Look for WHIRLPOOL and refer to diagram H (This model Amana is manufactured by Whirlpool).
Replacement parts (if required) can be ordered on line at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
If you still have the teflon glide type tensioner (does not have a wheel), Whirlpool recommends you replace it with a conventional roller type idler pulley. The teflon type tensioners caused premature wear to the drive belt. The part number is 691366.
Once you have the belt installed, re-install the dryer front panel by holding it as you did previously. Line up the holes on the inside bottom edge of the front panel with the small mounting cleats on the front edge of the side panels. This can be done by yourself, but an assist may make it easier. Once you have the front panel in place, lean against it to hold it in place and install the mounting screws.
NOTE: Don't forget to reconnect the grounding wire and door switch connector plug. Without the door switch connected, the dryer will not run. Lower the top panel back in place and reinstall the two screws.
NOTE: Placing a piece of duct tape over the dryer vent chute will help safeguard against dropping anything down in the blower fan assembly. If you drop any screws down the chute, you will need to remove the dryer back panel to retrieve them. If you have any questions about this repair, please post back and let me know. I hope this helps you.
Posted on Sep 09, 2010
  • Jeff Rockwell
    Jeff Rockwell Sep 10, 2010
    If the dryer still isn't getting hot, you need to do a thorough inspection of the exhaust ducting to ensure it isn't clogged anywhere. A restricted exhaust will cause the dryer to exhibit poor heating, or no heat at all. In addition, you need to locate and check the Thermal Fuse (located on the blower fan housing) to ensure it is not blown.
  • Jeff Rockwell
    Your initial question was how to take the dryer apart to get to your ignitor. I took the time to research the material, based on the model number you provided, and answered the question. If you need further assistance on heat related issues, it is advisable to provide feedback BEFORE giving an adverse rating.
I have a whirlpool LGR8648pwo. Runs not heat and timer doesnt move. I found a 4 prong sensor in the back of the unit. 2 prongs have continuity and the other 2 dont. Is that bad.
If no heat at all i suspect this part HERE. This is the fuse. It kills power to the gas assembly if junk gets into the filter housing and cause an overheat condition. On electric models this same fuse kills the whole dryer. On gas models it just kills the gas. If that is good the next thing to check is the flame detection sensor mounted out side of the burner chamber. It's job is to power up the ignitor. If it is open no power can get to the ignitor. If it is good then the next thing to check is the ignitor. If the ignitor is good AND you are getting power from that control klixon you mentioned with the 4 wires on it AND you can get a little heat at first but then none at all them coils need to be replaced. Here is my home video:
Dec 09, 2012 | Whirlpool LGR8648 Gas Dryer
I have a Whirlpool Gas Dryer Model LGR8648PWO that will not heat
You will have to remove the back panel to access this part. Be sure that you unplug the machine before starting. Once the back panel has been taken off and placed aside the thermal switch will be located on the left lower side near the blower housing . It will be thin and long and located near the cycling thermostat that has for prongs on it. On certain machines, the thermal fuse is located in the front. To access this you must remove the kickplate, which can be done by pushing the clips, one on each side jsut above the top of the kickplate, in between the top and abottom portion. The part numbers are the same for either style dryer. To test this part you can either take the wires off it and tie them together then plug the machine back in and see if it heats, or you can use amultimeter and check to see if there is continuity, if there is its good, if not, bad. The thermal fuse will usually be white, and if located in the back, be thin and long with two wires on it, left and right. If in the bottom front, it will be front center on the exhaust duct. In some cases the ignitor or the gas coils will go bad. Here is a good process of elimination.
1)Verify that the thermal fuse is good. If you don't have a meter bypass it and turn the machine on. If heats, thermal fuse is bad, if not leave connected and continue
2)When the dryer starts and thermal fuse bypassed, the ignitor should start to get hot and glow, if your thermal fuse is in the back you are going to have to have to the top of the dryer up to see down inside near the front for the glow. You can do this by taking the lint trap out and removing the two screws and popping the top up. If the ignitor comes on more than likely the gas coils are bad and if it doesn't the ignitior is bad. (this is while the thermal fuse is bypassed so the ignitor has power to it regardless)
Jun 04, 2012 | Whirlpool LGR8648 Gas Dryer
LGR7646EQ0 Dryer runs but no heat (new ignitor)
check all the thermal fuses with an ohm meter if one of then is not showing any continuity the replace it this should help good luck
Jan 23, 2010 | Whirlpool LGR7646E Dryer
How do I locate coils
you need to remove the four door screws,
take off the door , remove the white cowel
remove the top dogs
open the top and look behind the tumbler
Sep 29, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer blowing cold air
UNPLUG the dryer. This model you need to remove the two screws under the lint screen. Now use a flat blade screw drive and insert it in the gap between the top and the front panel and pry the top up. Now locate and remove the screws on the inside of the front panel in upper corners. The front should lift off. You will see the ignitor attached to the burner. You can try and replace the ignitor without removing the burner. Sometimes it is just as easy to remove the burner. Make sure the gas is shut off before removing the gas fitting on the gas valve. Be carefull and DO NOT touch the black part of the ignitor with your hand. It could ruin the ignitor with the oil on you hand.
If I can assist you further, please let me know.
Thanks
Vic
Jul 05, 2009 | Whirlpool LGR5636L Gas Dryer
Whirlpool gas (Propane) dryer
Hi, Remove the small plastic cover on the front lower right hand corner. Start the dryer and see id=f the ignitor glows. If the ignitor glows and shuts down before igniting the flame, follow these instructions. UNPLUG the dryer. This model you need to remove the two screws under the lint screen. Now use a flat blade screw drive and insert it in the gap between the top and the front panel and pry the top up. Now locate and remove the screws on the inside of the front panel in upper corners. The front should lift off. You will see the two black coils on the gas valve. When you remove the three wire coil, make sure the sleeve inside it gets put back on the post the coils slides onto.
Thanks
Vic
Jun 19, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool Gas Dryer LGR4634EQ2 is not getting hot, I cleaned the vent,I don`t know whats nexts to try?
You may have damaged the glow bar gas ignitor when cleaning the dryer.. it's a ceramic element that gets brittle after it has been used. And if you bang into it with a vacuum hose or tool or whatever while you're cleaning it, it can crack or break....try cycling the dryer and watch the ignitor while it attempt to heat up... if there isn't any glow at all, its the ignitor... it's a simple job to swap it out...
Let me know if that doesn't work...
KEN
May 09, 2009 | Whirlpool Dryers
My dryer doesnt heat.
hi there,
check the ignitor and the coils on the burner assy.
Sep 30, 2008 | Whirlpool LEQ8000JQ Electric Dryer
Gas dryer not heating up
Flash, did you check the thermal fuse in the back? On a gas dryer the drum will still turn if it's blown. check out the picture and post back.
Mar 29, 2007 | Whirlpool LGR3624JQ Gas Dryer
Dryers Logo
136 people viewed this question
Top Dryers Experts
