Question about Samsung Televison & Video
I have a samsung mod.# LNT4661FX/XAA and i have a very dark picture with bright red color and when the images move in the picture i see trails following the movement.
  • 597 Answers
There seem to be a convergence problem affecting the television.
There are two ways you can fix the problem which are, you either replace the t-com board of the television, or you adjust the convergence from the menu of the television.
My best option is for you to replace the t-com board of your television and it will be in good condition once again.
Take care
Posted on Sep 09, 2010
I have a samsung lcd lnt4661fx/xaa tv and the picture is all blurry, how does this get fixed and how much will it cost me
Does it improve when the set warms up? Is it the entire screen or just the left or right side? These sets are notorious for faulty LCD panel tabs which causes blurry/delayed picture problems.
Mar 11, 2013 | Samsung Televison & Video
Tip
I have a 46" Samsung LNT4661FX / XAA LCD TV. I pulled the back off and noticed 2...
For this tutorial, I will be addressing a common problem experienced by many Samsung LCD, flat panel TV owners these day... "My Samsung TV keeps clicking for 20 minutes before it comes on" or "When I press the power button on my Samsung, nothing happens" or "When I turn my Samung TV on, there are white dots on the screen" or "When I turn my Samsung TV on, there are multi-color vertical lines on the screen"... there may be more, but these are the most common I know of. The models are numerous and seem to stretch from 08' - 09'. If you are having this issue and want to fix it yourself, read on.
TOOLS: #2 Philips Screwdriver, Wire Cutters, Soldering Iron, Desolder wick (with Rosin), Rosin Core Solder, Replacement parts (will be determined after disassembly).
The first thing we need to do is unplug the TV and move it to a good work location. You will need a soft place to place the TV, perhaps on a carpeted floor or on a blanket placed over the kitchen table ;).
Remove the 4 screw for the stand (RED area) and then pull the TV off the stand and place the TV face down on you soft work surface. Remove the 4 large screws (GREEN area) and the rear cover screws (YELLOW areas). Now remove the rear cover (screw location may vary depending on your exact model, so please make sure have them all out first).
Depending on your model, you may have a metal shield covering the boards. If not, you can skim ahead...
There are 2 major boards that will be front and center inside your TV. On the left we have the SMPS... this is where we will be working. So, we need to remove the shield cover to get to it.
Now that we have the cover off, we are able to take a closer look and locate the faulty parts. Have a look at the upper right corner of the SMPS (Switch Mode Power Supply). You will see a cable going over to the main board on the right... in this area you will find the problem.
The faulty parts are capacitors. The tops are generally swollen and often have blackened material exposed or leaking from their bulging tops.
You will need to identify the electrical value of the parts and locate suitable replacement parts (try Radio Shack). The values may be 1000uF 10v, or 2200uF 10v... whatever they may, you replacement part have an identical uF value but a higher v value... ex: Original, 1000uF 10v -> Replacement, 1000uF 16v. This will help prevent this problem from reoccurring.
Once you have the replacement parts, you are all set to install them. So, unplug the connection on the SMPS and remove the screws from the board. Heat up that soldering iron and remove the capacitors. Use the Desolder wick to clean up the pads, this will allow you to insert the new capacitors with ease. Be careful, these parts have polarity. This means that they need to be installed the same way you removed them... positive to positive and negative to negative. Each capacitor has a negative terminal, each mount location has a negative hole and it is indicated by the wide black band. After you insert each part, fold the legs over on the solder side of the board so that the part does not fall out and stays in position. Once you have all the parts reinstalled, solder them in. Make sure you make a clean electrical connection. Now use your wire cutters to trim the excess legs. Be sure to trim them close so that they don't touch any other electrical connections on the board.
Your SMPS is now fixed and ready to go... reinstall it into the TV and connect the wire harnesses back up to the SMPS. Double check your work. Are all the connectors back in place? Ok, now you should test your work before putting the whole TV back together. Prepare the AC cord, use an extension cord if needed. You will need to flip the TV up on to its top edge (upside down, screen facing you). Plug the AC cord into the TV and press the power button. Do you see the Video/Input indicator or RF snow on the screen? If so, well done! If not, unplug the TV and check you work.
You are now ready to reassemble the TV and return it to service.
** If you need some assistance in the soldering area, please have a look at my Tip "Soldering on the kitchen table, Class 101". I cover the actual soldering of a capacitor in more detail there.
If you have found this helpful, spread the word and/or leave me some feedback.
on Jan 19, 2011 | Televison & Video
Purple dots on HD LCD samsung model LNT4661FX/XAA when on.
hi,
your lcd micron tube in the panel had already worn out.
got to replace the panel
Jan 27, 2010 | Samsung LNT4642H 46 in. LCD Television
http://www.youtube.com/watch?v=Mm51C_RDIZE
-and-
http://www.youtube.com/watch?v=BNHHrgX_6cs
Jan 27, 2010 | Samsung Televison & Video
Samsung HLS5086WX-XAA after 1 years it's showing dark
Light Engine or the DMD board 1-800-638-3328
Jan 14, 2010 | Televison & Video
I am having a problem with my Samsung LNT4661FX/XAA
http://techreport.com/search_google.x?cx=010312586752609289257%3Avgpois-b0yw&cof=FORID%3A11&q=LNt4661fx&sa=#692
check this link for more info on the power supply problem.
May 01, 2009 | Televison & Video
Dark picture
do you get all three colors? red, blue and green?
Dec 16, 2007 | Panasonic PT-51G44 51" Rear Projection...
JVC tv AV-27D304
Roger, if your contrast (sometimes called picture) and brightness controls are at max you can increase the tubes brightness by turning the "screen control" clockwise, be advised a little turn goes a long ways, don`t crank it too far or you will get retrace lines, you will have to remove the back from the set and follow the red wire down from the tube to the "flyback transformer" on the front of the flyback are 2 controls, focus and screen, do not move the focus control, this should fix your problem.
Nov 20, 2007 | JVC AV-48WP30 48" Rear Projection...
Tv has bright green color
you are having a problem in your video circuit and your tunner section if the green is smooth also have the deflection ic checked.but this set needs to be taken to a qualified tech repairs could cost about $1oo.00 good luck.
Nov 16, 2006 | Samsung TXK2554 25" TV
Televison & Video Logo
700 people viewed this question
Henry  Thomas
Henry Thomas
