Question about Kenmore 24902 Top Load Washer
Agitator will move while empty, but when you put a load of clothes in it will not move...
    President:
  • 1,033 Answers
Sounds like the (agitating dogs) are worn out. These are little arms with grippers at the end that grab the agitator . It spins free one way but the grippers grab the base of the agitator and spins it the other way. This is how you get the agitating motion. You can buy these at a repair shop for about $5. The cap at the top of the agitator will need to be taken off, just unscrew it. once it'a off you can see at the bottom a bolt that will need to be removed, once it is removed you can the pull the whole assembly out. The agitating dogs will be at the base of the shaft. These are made of a plastic/resin and wear out due to being old or overloading. There are diagrams on the net to show you exactly what they look like, search (agitating dogs.
Posted on Sep 09, 2010
Washer won't agitate
I would start by checking the belt on the motor could be slipping when u put full load in washer. also check that pulleys are not loose.
Apr 19, 2014 | Miele W1903A Front Load Washer
How much clothes do I put in the washer?
A good place to star it filling drum 3/4 full. You want to see the clothes moving freely during agitation. if the clothes move in one brick together, decrease load size
Jan 21, 2013 | Kenmore Washing Machines
Washer won't agitate with clothes in. Will agitate when empty with water
It's a whirlpool top load and 17 years old.
I checked the lid switch, water level switch and they are okay. I replaced the motor coupling. The old one was chewed up and crumbling.
When I put everything back together and turned it on to check if it would spin, I heard a buzzing sound and after a few minutes there was a burning smell.
What should I check to diagnose this problem? would help to have make or model numbers to show age of machine
Nov 26, 2012 | Whirlpool Washing Machines
What is the agitator
The agitator is the large part inside a top load washer tub that moves the clothes around while they wash and rinse.
Sep 26, 2011 | Whirlpool Washing Machines
Hi, I have a WA75T65GW1 7.5kg top load washer. I run a favourites program with cold water cycle, auto level and fast spin. The cycle is getting stuck all the time between rinse and spin cycle, bowl is...
This problem will often occur with a light load of clothes. The beeping is usually the unbalanced load alarm. Often, redistributing the clothes around the agitator and moving the agitator manually up and down and side to side to center it again will fix the problem. You may need to advance a new cycle to where it spins out to empty the washer and run the laundry again.
Jul 30, 2011 | Fisher and Paykel Washing Machines
Clothes mover of whirlpool top-loading washer is loose. Agitates.
You need to replace the agitator dogs inside the clothes mover (agitator). take of the top then the cover, remove th bolt and take the top half off. you should see four "dogs" that need to be replaced.
Jan 25, 2009 | Whirlpool LSQ9600L Top Load Washer
Just spins during the wash cycle
Sounds like the agitator got dislogged during moving. In some machines the design allows for the agitator to move up and down alittle too much. Try this and this is only a guess. With the machine empty push down firmly on the agitator and move it back and forth as you do. You might hear a little "pop". If it does, try running the machine again. If it works problem solved, if not tell what happened.
Jul 17, 2007 | Whirlpool GSC9455 Top Load Washer
Kenmore 24902 Top Load Washer Logo
66 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
