Question about Husqvarna Chain Saw 20" Bar
I put a chain on my 257 and tighten it and bolt on the cover. then i start it up and rev it for about 2-3 seconds. when i check the chain it is hanging about 1/2 in. below the bar. after sitting for about 3-4 minutes the chain tightens up tighter than i had it before. i've taken it to four different shops. what's wrong?
    Brigadier General:
  • 4,088 Answers
Sounds like the chain oiling system is plugged or has failed. Remove the bar and chain--start the engine and see if oil oozes from the engine side port where the bar fits up to. If ok, then check the small oil passages that run from the large holes in the drive end of the bar out to the chain groove on each edge--they commonly get plugged with sawdust and dirt. If there are small thin plates located on either side of the bar at the drive end, make sure that the one with a slot which couples oil feed from the engine to the bar is installed next to the engine. When adjusting the chain, make sure you can turn it by hand when everything is tightened. Be sure to oil the chain manually before running it the first time. Run the engine at speed and hold the bar tip near some cardboard for a couple of moments--it should throw off a thin line of oil. Hope this helps!
Posted on Sep 09, 2010
The chain has come off. I put it back but it is too loose. How do I tighten it
Should be a screw next to the bar. you can tighten it and it will tighten the chain. Keep in mind that the 2 bolts holding the bar and cover in place have to be loose to do this.
May 27, 2016 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
How do I set timing on a 2.3 Suzuki aerio engine
wow no job stated.
04 (2.3L) ill take a wild guess and say, you might be fiddling the cam
and doing something there, new cam, new lifters, new chain, new head, ? what?
FSM means factory service manual, ever heard of one?
the FSM is just lousy 4 bucks why not read that first. and not mess it up.
https://suzukipitstopplus.com/Products/1004-2004-aerio-service-manual.aspx
you said SET, so i can only assume its all apart. right then
you want to Instal the chain and time it, right so here are the fsm steps
no photos. log in and read the FSM for that.
  1. Check that match mark on crankshaft timing sprocket is in match with timing mark on lower crankcase.
  2. Install crankshaft timing sprocket as shown in figure.
  3. Apply oil to bush of idler sprocket and install idler sprocket and sprocket shaft.
  4. Install first timing chain by aligning dark blue plate of first timing chain and match mark on idler sprocket.
  5. Bring yellow plate of first timing chain into match with match mark on crankshaft timing sprocket.
  6. Apply engine oil to sliding surface of timing chain tensioner and then install it as shown in figure. Tighten tensioner nut to 18 ft. lbs. (25 Nm).
  7. With latch of tensioner adjuster No.1 returned and plunger pushed back into body, insert stopper into latch and body. After inserting it, check to make sure that plunger will not come out.
  8. Install timing chain tensioner adjuster No.1. Tighten the timing chain tensioner adjuster No. 1 bolt to 8 ft. lbs. (11 Nm).
  9. Pull out stopper from adjuster No.1.
  10. Apply engine oil to sliding surface of timing chain guide No.1 and then install it. Tighten guide bolts to 6.5 ft. lbs. (9 Nm).
  11. Check that dark blue and yellow plates of first timing chain are in match with match marks on sprockets respectively.
  12. Install second timing chain as follows:
    • Check that match mark on crank timing sprocket is in match with timing mark on lower crankcase.
    • Check that arrow mark on idler sprocket faces upward.
    • Check that knock pins of intake and exhaust camshafts are aligned with timing marks on cylinder head.
    • Install second timing chain by aligning yellow plate of second timing chain and match marks on idler sprocket.
    • Install sprockets to intake and exhaust camshafts by aligning dark blue plate of second timing chain, match marks on intake sprocket and exhaust sprocket respectively. NOTE As an arrow mark is provided on both sides, camshaft timing sprocket has no specific installation direction.
  • Install intake and exhaust camshaft timing sprocket bolts. To install it, fit a spanner to hexagonal part at the center of camshaft to hold it stationary. Tighten the camshaft timing sprocket bolt to 57.5 ft. lbs. (80 Nm).
  • Push back plunger into tensioner body and hold it at the position by inserting stopper into body.
  • Install timing chain tensioner adjuster No.2 with new gasket. Tighten the timing chain tensioner adjuster No. 2 bolts to 8 ft. lbs. (11 Nm) and No. 2 nut to 33 ft. lbs. (45 Nm).
  • Pull out stopper from timing chain tensioner adjuster No.2.
  • Turn crankshaft two rotations clockwise then align timing mark on crankshaft and timing mark on cylinder block.
  • Check that timing marks of cylinder head and cylinder block are in match with match marks on sprockets respectively.
  • Apply oil to timing chains, tensioner, tensioner adjusters, sprockets, and guides.
  • Install timing chain cover. Reverse removal sequence to install timing chain cover noting the following points:
    • Apply sealant "A" and "B" to area as shown.
      • "A": Sealant 99000-31250
      • "B": Sealant 99000-31140
    • Apply sealant amount to the following areas.
      • "a": 0.12 inches (3mm)
      • "b": 0.08 inches (2mm)
      • "c": 0.24 inches (6mm)
      • "d": 0.63 inches (16mm)
      • "e": 0.55 inches (14mm)
      • "f": 2.56 inches (65mm)
      • "g": 2.87 inches (73mm)
      • "h": 0.16 inches (4mm)
    • Apply engine oil to oil seal lip, then install timing chain cover. Tighten bolts and nut to 8 ft. lbs. (11 Nm).
      NOTE Before installing timing chain cover, check that pin is securely fitted.
    • Before installing timing chain cover, check that pin is securely fitted.
  • Install alternator belt idler pulley. Tighten nut to 30.5 ft. lbs. (42 Nm).
  • Install alternator belt tensioner. Tighten bolts to 18.5 ft. lbs. (25 Nm).
  • Install water pump pulley.
  • Install A/C compressor bracket (if equipped). Tighten bracket bolts to 40 ft. lbs. (55 Nm).
  • Install cylinder head cover with new gaskets and seal washers and tighten nuts to 8 ft. lbs. (11 Nm).
  • Install oil pan.
  • Install crankshaft pulley using pulley holder tool. Tighten the crankshaft pulley bolt to 108.5 ft. lbs. (150 Nm).
  • Install engine assembly.
  • Install all remaining components in the reverse order of the removal procedure.
did that cover it, surely not.
but if you get the FSM and read it or log in , you will not miss the photos and the complex sealing bs on this motor.
Oct 18, 2014 | 2004 Suzuki Aerio
Chain came off
Take off your chain guard, should be 2 bolts holding the chain bar in place. Then make sure there isnt another bolt or screw you missed, pop off cover put chain on, replace chain guard and tighten chain. It should be that simple
Jul 22, 2012 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Need diagram how to install timing chain 2004 Malibu overhead cam
Procedure is pasted below. Please let me know if you have questions.
Removal & Installation2.2L Engine
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Drain the cooling system.
  3. Drain the engine oil.
  4. Remove or disconnect the following:
    NOTE The timing chain has 2 matching colored links and 1 uniquely colored link.
    Negative battery cable, PCV hose, Fuel line bracket, Ignition coil and module assembly Ground strap from camshaft cover, Camshaft cover, Front fender liner, Accessory drive belt Crankshaft balancer pulley, Accessory drive belt tensioner, Front cover-to-water pump bolt Remaining front cover bolts, Front cover
  5. Rotate the engine until the crankshaft sprocket mark aligns with the matching colored link (2) at the 5 o-clock position.
  6. Confirm that the INT diamond on the intake camshaft sprocket is aligned with the uniquely colored link at (1) the 2 o-clock position.
  7. Confirm that the EXH triangle on the exhaust camshaft sprocket is aligned with the matching colored link (3).
  8. Remove or disconnect the following:
    NOTE Use a 24 mm wrench to hold the camshafts to prevent them from turning.
    Timing chain tensioner, Fixed timing chain guide access plug, Fixed timing chain guide Upper timing chain guide, Exhaust camshaft sprocket, Timing chain tensioner guide Intake camshaft sprocket, Timing chain through the top of the cylinder head Crankshaft sprocket
    Fig. Lining up the crankshaft sprocket mark with the colored link in the 5 o-clock position (2).
    Fig. Aligning the intake camshaft sprocket mark with the colored link in the 2 o-clock position (1).
    Fig. Aligning the exhaust camshaft sprocket (3).
To install:
  1. Install the crankshaft sprocket with the timing mark in the 5 o-clock position.
  2. Assemble the intake camshaft sprocket to the timing chain with the timing mark lined up with the uniquely colored link (1). Hand tighten a new intake camshaft sprocket bolt.
  3. Lower the timing chain through the opening in the cylinder head.
  4. Route the timing chain around the crankshaft sprocket and line up the first marching colored link (2) with the timing mark on the crankshaft sprocket.
  5. Install the exhaust camshaft sprocket with a new bolt loosely onto the exhaust camshaft.
  6. Align the timing mark on the sprocket with the last matching colored (3).
  7. If necessary, align the camshaft as follows:
    1. Using a 24 mm wrench, first turn the intake camshaft until the alignment feature on the back of the camshaft sprocket seats in the notch in the front of the intake camshaft.
    2. Turn the crankshaft 45 degrees in either direction.
    3. Turn the intake camshaft to the appropriate location.
    4. Turn the crankshaft back to top dead center (TDC).
  8. When the sprocket seats in on the camshaft, tighten the sprocket bolt hand tight.
  9. Verify all of the colored links and the appropriate timing marks are still aligned.
  10. Install the fixed timing chain guide. Tighten the bolts to 133 inch lbs. (15 Nm).
  11. Install the upper timing chain guide. Tighten the bolts to 89 inch lbs. (10 Nm).
  12. Using a 24 mm wrench to hold the camshafts, tighten the camshaft sprocket bolts 63 ft. lbs. (85 Nm) plus 30 degrees.
  13. Measure the timing chain tensioner from end to end. A new tensioner should be supplied in the fully compressed non-active state. A tensioner in the compressed state will measure 2.83 inches (72 mm) front end to end. A tensioner in the active state will measure 3.35 inches (85 mm) from end to end.
  14. If the timing chain tensioner is not in the compressed state, perform the following steps:
    1. Remove the piston assembly from the body of the timing chain tensioner by pulling it out.
    2. Install the bottom half of the Tensioner tool J-45027-2 into a vise.
    3. Install the notch end of the piston assembly into the bottom half of the tensioner tool.
    4. Using the top half of the Tensioner tool J-45027-1, turn the ratchet cylinder into the piston.
    5. Install the compressed piston assembly back into the timing chain tensioner body until it stops at the bottom of the bore. Do not compress the piston assembly against the bottom of the bore.
  15. Install the timing chain tensioner assembly. Tighten to 66 ft. lbs. (75 Nm).
  16. Release the timing chain tensioner by compressing it approximately 0.08 inches (2mm). Feed a rubber-tipped tool down through the cam drive chest to reset on the cam chain. Give the tool a sharp jolt diagonally downwards to release the tensioner.
  17. Install the timing chain oiling nozzle.
  18. Install the timing chain guide bolt access hold plug with silicone sealant on the threads. Tighten the plug to 59 ft. lbs. (90 Nm).
  19. Install or connect the following:
    Camshaft cover. Tighten the bolts to 89 inch lbs. (10 Nm). Front cover with new gasket. Tighten the bolts to 18 ft. lbs. (25 Nm). Accessory drive belt tensioner. Tighten the bolts to 33 ft. lbs. (45 Nm). Crankshaft balancer pulley using a new bolt. Tighten the bolt to 74 ft. lbs. (100 Nm) plus 75 degrees. Accessory drive belt, Front fender liner, Ground strap to camshaft cover Ignition coil and module assembly, Fuel line bracket, Air intake assembly, Negative battery cable
  20. Refill the cooling system to the correct level.
  21. Refill the engine with oil to the correct level.
  22. Start the engine and check for leaks.
    Fig. Compressing the timing chain tensioner-2.2L engine.
Oct 06, 2011 | 2004 Chevrolet Malibu
I replaced the right side head on my 2001 mustang gt and i need to know how to set up the timming so it will run right
Hi, this engine user copper links on the chain align the copper links with the marks shown on the diagram below. Please let me know if you have more questions, and thanks for using FixYa.
To install:
  1. Compress the timing chain tensioner plunger in a soft jaw vise and install a retaining clip to hold the plunger in place.
  2. Remove the tensioner.
  3. If the copper links are not visible on the timing chains, mark one link on each end of the chain.
  4. Install the left and right timing chain guides and tighten the bolts to 89 inch lbs. (10 Nm).
  5. Position the lower end of the left timing chain on the crankshaft sprocket, aligning the copper link with the timing mark on the outer flange of the crankshaft sprocket.
  6. Position the timing chain on the left camshaft sprocket with the camshaft sprocket timing mark aligned with the copper link.
  7. Position the left timing chain tensioner arm on the dowel pin and install the timing chain tensioner. Tighten the bolts to 18 ft. lbs. (25 Nm).
  8. Remove the retaining clip from the tensioner plunger.
  9. Position the lower end of the right timing chain on the crankshaft sprocket, aligning the copper link with the timing mark on the outer flange of the crankshaft sprocket.
  10. Position the timing chain on the right camshaft sprocket with the camshaft sprocket timing mark aligned with the copper link.
  11. Position the left timing chain tensioner arm on the dowel pin and install the timing chain tensioner. Tighten the bolts to 18 ft. lbs. (25 Nm).
  12. Remove the retaining clip from the tensioner plunger.
  13. Ensure correct alignment of all timing chain links and sprocket timing marks.
  14. Install the camshaft roller followers and tighten the camshaft sprocket bolts. See the procedure under Camshaft.
  15. Install the crankshaft sensor ring on the crankshaft.
    Fig. Timing chain link and sprocket timing mark alignment-4.6L engine
  16. Apply sealant to the front cover mating surface as shown.
    Fig. Sealant application to the front cover mating surface-4.6L engine
  17. Install a new gasket on the front cover, then install the front cover and hand tighten the bolts.
  18. Tighten the front cover bolts in the sequence shown to 18 ft. lbs. (25 Nm).
  19. Tighten the front cover-to-oil pan bolts in the sequence shown to 15 ft. lbs. (20 Nm), plus an additional 60 degrees
    Fig. Front cover bolt tightening sequence-4.6L engine
    Fig. Front cover-to-oil pan bolt tightening sequence-4.6L engine
  20. Lubricate the engine front cover and oil seal lip with clean engine oil and install the seal using a seal installer.
  21. Apply sealant to the Woodruff key slot in the crankshaft pulley, then press on the crankshaft damper.
  22. Tighten the crankshaft damper as follows:
    1. Step 1: 66 ft. lbs. (90 Nm).
    2. Step 2: Loosen the bolt one full turn.
    3. Step 3: 37 ft. lbs. (50 Nm).
    4. Step 4: 90 degrees.
  23. Connect the crankshaft position sensor connector.
  24. Install the power steering pump and tighten the bolts to 18 ft. lbs. (25 Nm).
  25. Install the wiring harness retainer to the power steering stud bolt.
  26. Install the power steering pump pulley shield.
  27. Install the water pump pulley.
  28. Install the J bracket to the engine front cover stud bolt.
  29. Install both left and right camshaft position sensor connectors.
  30. Install both left and right radio interference capacitors.
  31. Connect the hoses from the coolant crossover.
  32. Install the valve covers. See the procedure under Cylinder Head.
  33. Install the right side idler pulley.
  34. Install the accessory drive belt.
  35. Install the coolant degas bottle.
  36. Connect the negative battery cable.
  37. Fill the crankcase with clean engine oil.
  38. Start the engine. Check for leaks and proper operation.
Aug 14, 2011 | Ford Mustang Cars & Trucks
Aligning the valve timing mareks except twincam engine
Timing Chain, Sprockets, Front Cover and Seal REMOVAL AND INSTALLATION Crankshaft Damper and Front Oil Seal
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Remove or disconnect the following:
    • Negative battery cable
    • Accessory drive belt
    • Cooling fans
    • Crankshaft pulley and damper, using a holding fixture as shown
    • Front crankshaft seal Fig. 1: Crankshaft pulley removal tool - V8 9301jg12.gif
    To install:
  3. Install oil seal replacer tool JD-235 to the oil seal. Use the nut and bolt provided with the tool to fully seat the seal to the timing cover.
  4. For dampers which DO NOT utilize a spit locking ring:
    1. Apply a thin, even coating of Loctite® 648 to the damper bore. Do not apply it to the end faces or to the crankshaft.
    2. Install the crankshaft damper onto the crankshaft. Wipe off any Loctite that has squeezed out from the front of the damper.
    3. Install the locking tool to the damper. Tighten the bolt to 59 ft. lbs. (80 Nm), plus an 80 degree turn.
  5. For dampers which utilize a spit locking ring:
    1. Install a new O-ring seal to the damper.
    2. Install the crankshaft damper.
    3. Apply petroleum jelly to the damper bore and O-ring seal.
    4. Install the damper onto the crankshaft.
    5. Install the split locking ring onto the crankshaft, inside the center bore of the damper.
    6. Install the locking tool to the damper.
    7. Tighten the damper bolt to 266-285 ft. lbs. (364-386 Nm).
    8. Remove the locking tool from the damper.
  6. Install or connect the following:
    • Cooling fans
  7. Start the engine and check for leaks.
Timing Cover
  3. Remove or disconnect the following:
    • Upper radiator hose
    • Water pump pulley
    • Accessory drive belt tensioner
    • Idler pulley
    • Crankshaft damper
    • Engine appearance covers
    • Mass Air Flow (MAF) meter
    • Air intake assembly
    • Ignition coils
    • Canister purge valve
    • Valve covers
    • Variable Valve Timing (VVT) solenoids
    • Engine harness retaining clips
    • Timing cover
    To install: Fig. 2: Sealant application points - V8 9301jg23.gif
    Fig. 3: Timing cover torque sequence-V8 9307jg01.gif
  4. Apply sealant to the 8 joints on the engine face as shown.
  5. Install or connect the following:
    • Timing cover with new seals. Tighten the bolts in sequence to 96-120 inch lbs. (11-13 Nm).
    • VVT solenoids
    • Valve covers
    • Ignition coils
    • MAF meter
    • Crankshaft damper
    • Idler pulley
    • Water pump pulley
  6. Fill the cooling system.
Timing Chain 6 CYLINDER
    • Valve cover
    • Timing chain cover
    • Variable Valve Timing (VVT) sensor
    • Crankshaft Position (CKP) sensor
  3. Rotate the crankshaft until the triangular arrow indent on the driveplate is visible through the access hole.
  4. Install the Crankshaft Setting Peg JD 216 into the CKP sensor location.
  5. Install the Camshaft Locking tool JD 215 on the camshafts.
  6. Remove or disconnect the following:
    • Camshaft sprocket mounting bolt by loosening it
    • VVT mounting bolt by loosening it
    • Camshaft Locking tool JD 215
    • Primary timing chain tensioner and backing plate
    • Primary timing chain guide
    • VVT unit and exhaust camshaft sprocket
    • Secondary timing chain tensioner and guide
    NOTE: Keep all valvetrain components in order for assembly. To install:
  7. Prepare the timing chain tensioners for installation by using a paperclip or other wire to unseat the check valves and compressing the pistons into their bores.
  8. Install or connect the following:
    • Secondary timing chain guide. Tighten the bolt to 89-124 inch lbs. (10-14 Nm).
    • Secondary timing chain tensioner. Tighten the bolt to 89-124 inch lbs. (10-14 Nm).
    • VVT, secondary timing chain and exhaust cam sprocket
    • Primary timing chain guide. Tighten the bolt to 10-12 ft. lbs. (13-16 Nm).
    • Primary timing chain tensioner and backing plate. Tighten the bolts to 89-124 inch lbs. (10-14 Nm).
    • Primary timing chain slack, eliminate it by placing a wedge between the primary timing chain tensioner and the guide shoe
    • Secondary timing chain by applying counterclockwise force to the exhaust camshaft sprocket. Fig. 4: Apply force in a counterclockwise direction when tightening the sprocket mounting bolts - 6 cylinder 9301jg03.gif
    • Exhaust and intake VVT sprocket bolts. Tighten them to 85-92 ft. lbs. (115-125 Nm).
  9. Remove the tools and wedges.
  10. Install or connect the following:
    • CKP sensor
    • VVT sensor
    • Coolant outlet pipe
    • ECT sensor connector
    • Radiator and heater hoses
    • Valve cover
  11. Fill the cooling system.
  12. Start the engine and check for leaks.
Jan 28, 2011 | 1999 Jaguar XK8
How to replace water pump 2003 alero. 3400 engine.
Removal & Installation 2.2L Engine To Remove:
  1. Disconnect the battery ground cable.
  2. If equipped with an automatic transmission, remove the exhaust manifold..
  3. Drain the cooling system.
  4. Raise and safely support the vehicle.
  5. Remove or disconnect the following:
    • Right front wheel and tire assembly.
    • Access plate on the water pump sprocket from the timing cover.
  6. Install J 43651 water pump sprocket holder or equivalent to the water pump sprocket.
  7. Use the access plate bolts to attach J43651 to the engine front cover.
    • Bolts that secure the sprocket to the water pump.
    • Bolt that secures the engine block to the water pump.
    • Bolt that secures the engine front cover to the water pump.
    • Feed pipe that joins the thermostat housing to the water pump. chevy_cav_02-04_wp.gif
    • 2 Bolts that secure the water pump to the engine block.
    • Water pump.
To Install:
  1. Use a threaded stud in the hub to align the water pump sprocket.
  2. Install or connect the following:
    • Water pump.
    • 2 bolts that secure the water pump to the engine block.
    • Front cover bolt and the bolt that secures the engine block to the water pump. Tighten the bolts to 15 ft lbs (20 Nm).
    • 2 of the bolts that secure the water pump sprocket to the water pump.
  3. Remove the threaded stud.
  4. Install the last bolt.
    • Tighten the bolts to 89 in lbs (10 Nm).
  5. Remove J 43651.
  6. Install the access plate on the water pump sprocket to the timing cover.
  7. Install the access plate bolts.
    • Tighten the bolts to 18 in lbs (10 Nm).
  8. Install the front fender liner.
  9. Install the right front tire and wheel.
  10. If equipped with an automatic transmission, install the exhaust manifold.
  12. Connect the battery ground cable.
2.4L Engine To Remove:
  1. Disconnect the negative battery cable
  2. Drain the engine coolant.
  3. Remove the exhaust manifold.
  4. Remove the coolant intake pipe as follows:
    1. Remove the coolant inlet pipe bolts.
    2. Remove the wheel and tire assembly.
    3. Remove the engine splash shield.
    4. Remove the bolts from the transaxle-to-engine block brace and remove the brace.
    5. Remove the radiator hose from the coolant inlet pipe.
    6. Remove the coolant inlet pipe to oil pan bolt.
    7. Remove the coolant inlet pipe, thermostat and seal.
  5. Lower the vehicle.
  6. Disconnect the heater hose quick connect from the heater outlet pipe.
  7. Remove the front timing chain cover and the chain tensioner.
  8. Unfasten the water pump-to-cylinder block bolts.
  9. Remove the water pump-to-timing chain housing nuts.
  10. Remove the water pump and cover mounting bolts and nuts.
  11. Remove the water pump and cover as an assembly. Separate the two pieces after removal.
  12. Clean the mating surfaces.
To Install:
  1. Install the water pump cover to the water pump assembly.
  2. Install and hand tighten the pump cover mounting bolts.
  3. Install water pump cover assembly.
  4. Install and hand tighten the cover-to-block mounting bolts.
  5. Install and hand tighten the water pump-to-timing chain housing nuts.
    • Tighten the water pump-to-timing chain housing mounting nuts to 19 ft lb (26 Nm).
    • Tighten the water pump cover-to-water pump mounting bolts to 124 in lb (14 Nm).
    • Tighten the water pump cover-to-engine block bolts starting with the bottom bolt first to 19 ft lb (26 Nm).
  6. Install the heater hose to the water pump pipe.
  7. Using new gaskets, install the exhaust manifold.
  8. Install the oil level indicator and tube.
  9. Connect the brake vacuum tube to the cam housing.
  10. Raise and safely support the vehicle.
  11. Install the catalytic converter.
  12. Install the coolant inlet pipe.
    • Tighten the inlet pipe-to-oil pan bolt to 19 ft lb (26 Nm). Tighten the coolant inlet pipe bolt to 124 in lb (14 Nm).
  13. Install the timing chain and tensioner.
  14. Lower the vehicle.
  15. Connect the oxygen sensor.
  16. Fill cooling system and check the system for leaks.
3.4L Engine To Remove:
  3. Loosen the water pump pulley bolts.
    • Drive belt.
    • Water pump pulley bolts and pulley.
    • Water pump bolts, pump and gasket.
    • Clean the water pump mating surfaces.
To Install:
  1. Install or connect the following:
    • Water pump gasket and pump.
    • Water pump bolts.
      1. Tighten the water pump bolts to 89 in lbs (10 Nm).
    • Water pump pulley and bolt until snug.
    • Drive belt.
  2. Tighten the water pump pulley bolts to 18 ft. lbs (25 Nm).
  3. Fill the cooling system.
  4. Check for leaks.
  5. Connect the battery ground cable.
Aug 31, 2010 | 2003 Oldsmobile Alero
My 2001 jeep grand Cherokee will not start don?t know why no codes are coming up put new cam sen, crank sen, coil pack, new ecu, new coolant temp sen, it turns over but will not run has injector pulse and...
Timing Chain, Sprockets, Front Cover and Seal REMOVAL & INSTALLATION 2.5L and 4.0L Engines
    • Cooling fan and shroud
    • Crankshaft damper
    • Accessory brackets
    • Front cover
    • Oil slinger
  3. Rotate the crankshaft so that the timing marks are aligned. Fig. 1: Timing chain alignment marks — 2.5L and 4.0L engines 7924pg20.gif
  4. Remove the timing chain and sprockets. To install:
  5. For 2.5L engines, turn the timing chain tensioner lever to the unlock (down) position. Pull the tensioner block toward the tensioner lever to compress the spring. Hold the block and turn the tensioner lever to the lock (up) position. Fig. 2: Timing chain tensioner — 2.5L engines 7924pg19.gif
  6. Install the timing chain and sprockets with the timing marks aligned. Tighten the camshaft sprocket bolt to 80 ft. lbs. (108 Nm) for 2.5L engines or to 50 ft. lbs. (68 Nm) for 4.0L engines.
  7. For 2.5L engines, release the timing chain tensioner.
    • Oil slinger
    • New front crankshaft seal to the front cover
    • Front cover, using a new gasket
    • Timing Case Cover Alignment and Seal Installation Tool 6139 in the crankshaft opening to center the front cover Fig. 3: Timing Case Cover Alignment and Seal Installation Tool 6139 — 2.5L and 4.0L engines 7924pg21.gif
  9. Tighten the front cover bolts as follows:
    1. Step 1: Cover-to-block 1⁄4 inch bolts to 60 inch lbs. (7 Nm)
    2. Step 2: Cover-to-block 5⁄16 inch bolts to 16 ft. lbs. (22 Nm)
    3. Step 3: Oil pan-to-cover 1⁄4 inch bolts to 85 inch lbs. (9.5 Nm)
    4. Step 4: Oil pan-to-cover 5⁄16 inch bolts to 11 ft. lbs. (15 Nm)
    • Crankshaft damper. Tighten the bolt to 80 ft. lbs. (108 Nm).
  11. Start the engine and check for leaks.
Jul 30, 2010 | 2001 Jeep Grand Cherokee
Cannot move the chain by hand after the bar has been tightened.
First be sure the chain is on going in the right direction. When looking at the bottom of the bar the sharp tooth should be going towards the motor. When you put chain back on are the chain teeth properly engaged in the sprocket on the motor. Remove the cover again, check that teeth are in sprocket. Make sure pin from adjuster screw is engaged in the hole in the bar. Before you tighten the cover bolts, make sure chain will turn by hand. If not adjust the adjusting screw. Once adjusted, tighten cover bolts. Check again after tightening bar.
Jul 04, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Had plug in saw 2 weeks and it dose not work /// it spins but dose not move blade just loud clicking noise
ok i assume it is an electric chain saw? chain usually gets loose and can jump off clutch sprocket . to remedy this there should be atleast one nut or bolt sometimes two nuts or bolts depending on brand and model on the side cover where bar and chain inter the clutch area remove those and cover will lift off second there is a screw that faces front next to bar should be a regular slotted screw head loosenit all the way up till bar gets loose and remove bar by pulling away from saw this will come off veryeasy and chain shoouls fit on teeth of clutch sprocket and fit back onto bar tighten screw till chain tightens up on bar then replace cover and nuts on side cover but do not tighten the with one hand put tension on chain by pulling down on it while tightening screw till chain feels elastic snapping back to bar then toghten up nuts . chain should have no more then 1/4 inch slack around bar this is the correct tension youshould maintain.
Mar 18, 2010 | Poulan Garden
Husqvarna Chain Saw 20" Bar Logo
53 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
