Question about LG LSC121PMA Split System Air Conditioner
Error code ck 33 - LG LSC121PMA Split System Air Conditioner
  • 2,133 Answers
Excessive rise of standard compressor discharge temperature. If over 105°C check refrigerant charge
Posted on Jan 04, 2011
Wont start acts like not getting fuel
ck fuel fulefilter thean pump hard to say not knowing why you did what you did but i wood ck theam
Mar 04, 2015 | Cars & Trucks
What is Code 33 on Onan Generator Model12.5 HDKCB11506B?
You may be reading the code wrong, Code 33 shows up as blink 3 pause blink 3. This means it has a lower level code fault. To access the real code. Press the stop button 3 times fast within 5 seconds and re-post what the code is please. It may blink pause then blink again, that is the lower fault code that will help diagnose the problem.
Feb 10, 2015 | Onan Generator, 4000W, Gasoline
Frigidare ATF8000FSO error code 33
Hello edward, thanks for your post!
I see your Frigidaire washer is displaying an error code "33". However, it appears "33" is an invalid error code. Let's attempt resetting your range. You can do this by unplugging it or flipping the household circuit breaker to the off position for roughly ten minutes. This usually clears false error codes.
If resetting the power does not correct the issue, could you please inform me of the new error code or if your washer continues to display "33". I look forward to assisting you. -Matt
Oct 01, 2014 | Frigidaire Washing Machines
1992 Dodge d350 gas
Code 41 is for the Alternator field curcuit and the 33 is for the A/C curcuit .. Ck your battery grounds and for corrosion at the alternator connections . Also ck the A/C compressor relay and the ignition power relay ( or replace them they are cheep) Both codes have to do with low votage
Aug 05, 2012 | 1992 Dodge Ram 350
At&t sierra error code 33
Try a reset, if that doesn't work check your wi-fi setting. If all else fails goto an apple store
Apr 10, 2012 | Tablets & eReaders
I have a error code 33, what error code is 33
Hi, These are some codes to your DLP HDTV.
Error Code Probable Cause
12 No error detected
22 Recovery from momentary Reset
32 Lamp Cover open
33 Air Filter Cover open
34 Lamp abnormality
35 Chassis Fan failure
36 Exhaust (Back Cover) or Lamp Ballast Fan failure
37 Engine (DMD or Lamp) Fan failure
38 Excess Lamp Temperature
39 Excess DMD Temperature
41 Short Detected
44 DVI Cable (between Chassis and Engine) disc
Jul 20, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
HP 5500n 59.ck error code
HP LASER PRINTER 2300 ERROR 59.B, 59.C
1. The Alienation motor error.
2. Replace the alienation motor.
3. Replace the D.C. controller board.
May 15, 2009 | Office Equipment & Supplies
Heating & Cooling Logo
47 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
