Question about Canon L120 Fax Laser Printer
I have a faxphone l120 every time i try to send a fax is say tx cancelled and goes to check scan platform i need instructions that are dumby proof
  • 385 Answers
Hey! If you take out the cover thats covering the recieving paper,Look in there and u will see a black lever with a green sticker on it!You should see a thin glass covering a whitish area,Push that up untill you hear the clicking sound! Enjoy!
Posted on Jan 06, 2011
Canon L120 - What does this error message mean?
Check Scan Platform, means:
The scanning platform is dirty, or not set into scanning position.
Solution
Clean the scanning area, or lift the scanning platform into place.
Nov 26, 2011 | Canon L120 Fax Laser Printer
My fax machine does not send or receive faxes any more. it has manuel in the window, i don't recall seeing this in my window before.
it can be a problem of the parametr RX and Tx try to change velocity of tx and then Rx if the problem not solved you must change the NCU board
Oct 08, 2010 | Canon FAXPHONE L80 Laser
What does coms error 00E8 mean?
Canon FAXPHONE L120 Laser Printer Please follow the instruction as given below may this will help u any
Error Codes
An error code is a four-digit code displayed on the LCD or in the bottom row of a TX Result Report or an RX Result Report when an error occurs.
See the table below for individual error codes.
Error Code Description Action 0001 The sender may not be using a G3 fax machine. Make sure the sender's machine is compatible with your machine 0070 Reception was manually canceled on the machine. Ask the sender to resend the document if necessary. 0071 The machine's memory is full. Print, send, or delete any documents stored in memory. 0080 The recipient's machine did not respond within 35 seconds. Resend the document. Ask the other party to check their machine. If you are making an overseas call, add a pause to the number. 008D The recipient's machine has run out of paper. Ask the recipient to make sure that paper is loaded in their machine. 00A0 Transmission was manually canceled on the machine. Resend the document if necessary. 00A1 There is a document jam. Clear the document jam. 00FF All redialing attempts have failed. Check if the recipient's number is correct or the telephone cable is properly connected, and try again.
Aug 18, 2010 | Canon L120 Fax Laser Printer
Cant fax, getting a msg "check scan.platform" Thank you, Z
When you remove plastic cover, wich is above paper cass. you will be able to see long black plastic with white scanner section.In the midlle is handle.
You need to open and very vell close it - THIS IS SCANING PLATFORM.
If does not help you have problem with main pcb.
Jun 15, 2010 | Canon L120 Fax Laser Printer
Trying to send a fax and get the TX #0259 what does it mean and what do i do to be able to send the fax
tx/rx/#0259 is just the number of the fax sent or recieved and the next one will be 0260,it has nothing to do with the fax sending!Make sure the line is connected in the L on the fax and that there is a dailing tone!Good Luck!
Apr 07, 2010 | Canon FAXPHONE L80 Laser
How do I print a confiramtion page to make sure my
Press Funktion and then report-activity reports will be displayed press ok.Or you can go to funktion-datarigestration-scroll to reports,press ok,select TX report,select output yes.Then after you send a fax a tx report of the fax you send will be printed out.
Dec 08, 2009 | Canon FaxPhone L75 Plain Paper Laser
Canon Fax-L120/L100
Check the manual for how to clean the scan platform (glass).
Jul 02, 2008 | Canon L120 Fax Laser Printer
Faxphone L120
According to the Basic Guide for the L120 (page 8-4), you lift the paper stack cover and pull it out completely. Once it is out, there is a small 'handle' at the top center of the opening. Pull down on this to lower the scanning platform into the document delivery area. Reverse this procedure when complete.
May 01, 2008 | Canon FAXPHONE L170 Plain Paper Laser
Check scan platform
Two things cause this, a dirty scanner or after the user cleaned the scanner it was reassembled incorrectly Directions are in chapter 8-4 of the “Basic Guide”
Apr 02, 2008 | Canon L120 Fax Laser Printer
Coulnd't send a fax
I had the same problem and called canon helpline.
They said to unplug the machine from the mains, then take out the plastic guard where the paper tray is fitted. There is a lever just above the paper tray. Make sure that it is pressed up completely. Then reconnect to mains.
I tried it and it worked.
Dec 27, 2007 | Canon FAX-L1000 Plain Paper Laser
Canon L120 Fax Laser Printer Logo
288 people viewed this question
old marine
old marine
