Question about Casio FX-9750GPlus Calculator
I'm trying to graph in radians on a casio fx-9750ga plus, but it doesn't show up on my screen. what should i do?
  • Casio Master
  • 7,993 Answers
To get results in radians you must configure the angle unit to be degree.
  1. In Run screen press [SHIFT][MENU] to access (SETUP).
  2. Use Down arrow to highlight the line Angle :
  3. Press F2 key to select the TAB Radian.
  4. Once you do that all values (input of trigonometric functions and polar graph functions OR output of inverse trigonometric functions) are in radians.
If your function is periodic (and all trigonometric functions are) set the window dimensions Xmin = negative (2 or 3)P and Xmax) = (2 or 3) PI. Adjust if necessary to a smaller domain.
Posted on Sep 11, 2010
  • k24674 Sep 11, 2010
    If the functions you are drawing are cosines and sines, restrict the range to Ymin =negative (1.1) and Ymax= 1.1. If there are factors multiplying a sine or cosine then you will have to multiply the values above by the largest absolute value of the factors.
  • k24674 Sep 13, 2010
    Sorry but this "To get results in radians you must configure the angle unit to be degree." is nonsense. It should read "To get results in radians you must configure the angle unit to be radian".
How do I graph sinx on my Casio fx-9750GII calculator?
Turn calculator ON
If you see no icons, press Menu
Press 3 (Graph) draw your function. (more on that later).
If the first line of the display show Graph Func : Y= you should be able to draw your function.
If it says anything else, press F3 TYPE to select the graph type and select functional by pressing F1 key Y=.
After the graph type is set to Y=, type the second member of your function y= f(x) on the first line. Make sure the = sign after Y1= remains highlighted after you move cursor. Otherwise select the function by pressing F1:SEL. Press F6 Draw.
Be careful with trigonometric functions. If angle unit is radian, set window Zoom to standard. If angle unit is degree, you must open the Window utility and set Xmin=-190, Xmax = 190 to see at least a period.
Feb 21, 2013 | Casio CE CASI FX-9750GII-L-IH GRAPHING...
My casio fx 9750gii wont let me solve sin graphs
If your angle unit is set to degrees and your window dimensions are the standard ones (-10, 10) for Xmin, Xmax , then you will not see much of the graph. In that case you should set Xmin=-180, Ymax=+180 and Ymin=-1.2 and Ymax=1.2
If the angle unit is set to radians, then the standard window dimensions will show the characteristic graph.
Thus, change the angle unit or change the windows dimensions.
Mar 29, 2012 | Casio FX-115ES Scientific Calculator
My fx-9750GA PLUS wont graph lines, cicles or paraballas
Sure it does! Did you ask it to graph?Here are some screen captures to help you find your way.
To draw functions (regular, parametric, polar, sequences) use the application graph: Highloghted on 1st screen capture. The second screen captures shows you the functions y=f(x). enter a legal expression and press F6 Draw. To set TYPE press the key under TYPE.
To draw conics (circles, parabolas, hyperbolas, and ellipses) use the CONiCS applications. (See 3rd screen ). On 4th capture the equation highlight is one for the parabola. y=x^2
Scroll down or up examining the small graphs. They will show you which equation form to choose.
For the circles
Jun 19, 2011 | Casio FX-9750GPlus Calculator
I have a casio fx-9750GA PLUS. how do you do standard deviation with a set of numbers?.
Here are the capabilities of the calculator.
In stat enter the values in List1 and the frequencies in List2
Press the key corresponding to the CALC tab
Press the 1-var tab and you get the results as seen on the screen with title 1-variable.
Other screens show some two-varaible stats or regressions.
Jun 01, 2011 | Casio FX9750GII Graphic Calculator
How do I change radians to degrees in the fx-9750G PLUS graphing calculator?
Press MENU, then select RUN and press EXE.
Press SHIFT MENU to access the SetUp.
Move cursor to highlight Angle.
In the botton of screen you see the Deg TAB. Activate it by pressing F1.
Here is a screen capture.
Oct 19, 2010 | Casio FX-9750GPlus Calculator
Degree and radian function Casio fx-9750GA Plus
May 06, 2010 | Casio FX-9750GPlus Calculator
How do I graph an equation such as y= 5x + 2?
Turn calculator ON. If you do not see several icons press [MENu].
Use arrow to select the [GRAPH] application and press [EXE].
In the entry screen, the line with Y1= is highlighted. If it is not, use arrow to highlight it.
Press the right arrow, the highlighting disappears leaving you with Y1= and the blinking cursor.
At the position of the cursor enter 5 [X, theta,T] key under the [ALPHA]. On the screen appears 5X, complete you equation +2.
Press [EXE] to store function.
If you want to draw other functions, it is time to do so on that screen.
When done press [F6:Draw}.
If the screen does not show a lot of the function, you can use the arrow keys to pan the graph.
You can also press [SHIFT][V-Window] to set the window limits.
Hope it helps.
Oct 10, 2009 | Casio FX-9750GPlus Calculator
Factorial abbrevation on casio fx-9750GA PLUS can't find it!!!!
There is no direct or shifted keystroke for nCr nPr and ! on casio long ago.
You can access to those function using OPTN button; here is how to do...
press OPTN, F6(>), F3(PROB), F3(nCr)
Jun 13, 2009 | Casio FX-300MS Calculator
Casio fx-9750GA can't find Ran or Int
Turn calculator on. Select [RUN] [EXE].
In run screen press [OPTN] [F6:-->] [F4:NUM] then select the function you want to use. You have ABS, Int, Frac, Rnd, Intg.
Hope it helps.
Feb 15, 2009 | Casio CFX-9850G Plus Calculator
Casio FX-9750GPlus Calculator Logo
313 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
