Everything on my monitor is wavy, sort of out of focus
  • 62 Answers
Usually focus problems comes from the monitor and rarely from the display adapter. If possible, check your monitor by connecting it to another PC or laptop and try to use the same resolution and refresh rate as on your system. If the same fault appears then you should contact a service for the monitor repair. Another way of testing is to start your OS in safe mode by pressing F8 key before the OS starts booting and select Safe mode. If image will appear correctly then it could be the graphic card's fault, in that case try to reinstall the video driver or use another card.
If this is the solution for your problem, please rate my post, otherwise give us more details.
Regards,
Andras
Posted on Sep 09, 2010
Compaq Presario sr1720nx has wavy video. You can see everything okay it's just that the video is wavy and kinda taxing on your eyes. It does this with every monitor I hook it up to. I've also tried a...
Is it wavy all the time or just when windows is booted up? Try booting up in low res mode or safe mode and see if the problem continues. What is the monitor refresh rate set at? Try lowering the refersh rate. The on board video/video card may be going bad. Lowering the refresh rate may reduce the wavy picture. If it has a video card you could try installing a different card. If it has onboard video try installing a video card. Make sure you drivers are up to date.
Sep 08, 2009 | Compaq Computers & Internet
Screen Out of Focus with Wavy Lines - Perfect Focus Will Not Corr
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 06, 2009 | Samsung HCM4215W 42" Rear Projection...
Monitor has dark wavy lines on edges
Hi...there,
Well... sure it fixable, but it is going to cost you a bundles... Since you own this monitor for about 10 yrs. It's time for you to give yourself a new LCD monitor for the Holidays... :) Have nice day!
Oct 13, 2008 | HP Computers & Internet
Images are blurry. icons, everything
1. remove the monitor dome. adjust the LOT Focus. ( lot top side preset)
2. remove the G4 wire focus ( neck base ) cleen and fixed.
3. replaced the neck base.
4. last and final replaced the lot.
Oct 12, 2008 | ViewSonic G220f (Beige) 21" CRT Monitor
Wavy screen
Try using a different refresh rate. I've found that when you change it down to 60 hertz that the issue usually goes away.
Jan 07, 2008 | Acer AL1715 (Black, Silver) 17" LCD...
Xerox 17 XL765 LCD monitor Wavy lines but pitcure is good
i had this same prob. For me it wasn't the monitor but the video card and or mobo. I tried monitors on other comps adn worked just fine. Tried comp on 4 monitors and same prob. bought new mobo and problem solved. New prob fixing mobo and or video card
Oct 27, 2007 | Gateway FPD2275W LCD Monitor
Horizontal lines dark background Problem - Compaq FS7600 17" Flat-Glass Monitor
1 it is generally due to poor focusing. 2 check crt base for loose or focus control wire loose. 3 if monitor is very old then crt might be weak. good luck.
Oct 03, 2007 | Compaq FS7600 17" Flat Glass Monitor
Canon 2080C scanner software causing monitor issues
Some sort of feedback through the scanner it seems Delete the scanner software and reinstall. Check Canon website for software updates Consult the Tech support team whilst you are there
May 31, 2007 | Canon DR 2080C Path-Through Scanner
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
